Seguidores: golf_1990, josusanchez5b, Jastur, r11ourense, MerioE, davidddgt, jose.a.llamas, gato125, Pkt, byChule, Hovig, SorianoFco, jygalvan, CubanPitbull, corderazo, israher, iDavid9669, nyro, pirulo79, Edu1589, ramargo75, javi.ferrer, kikelin, aleejandroogm, Trimmer, car212121, LeoST, Besaygf, kinipc, Rasekfighter, Romera, MartinLeon, camamaleon, Aceroinox1a, jramis, Juanquique, josele77, marlop, Peje, Pedrost, bailyibz, wiki88, teltronik, gogua, sirkez, carlosgzlez, mcecho, genialsoft, aironsam14, JoseCa, Dandy_gsi, vanscampa, Joseibz, trekam, La_jungla, jorgecrackets, aigort, msmdraven, IRO, Jorge75016, alejandro_javier, ivan0909, jmfcoto, viktor_ct_95, maxxg2, olgalberto1, danifusi, Josepo79, er_trompe, miyobe, jande, Petri, itz18, jagman, serguey79, rafapadilla93, Mate, undernok, lead, lead, csabafr2013, jluis, olmeras, LeidenSpain, osjamil, Valerofr150, flope63, Herrdoktor, pocososinos, carrasco13, pichonclv, C.reina, Daner84, inamarlo, aguscalderon, BaZZ, yujakantabro, Fonek, LARABA, juanmaroger, juanmac, Kipu, IvanMc2, garrafa2, Linker89, mihai G, Igor, bronce702, creasy1977, Gsclosada, lebowski, jaro_84, charly425, leonfr76, DBS83, joseanvazquez501, M3rs, borgio, NOCIVOX, FcoJ.M.N., VillaSB, t4alberto, lytry32.hc, david_gz, Kasky, diegol147, jasoriab, jninomo, jmiturbe, chetelopez, utopia95, Dreziel, jonatan1988, xsoldadito, Illan, Fernandoestrada, jd_zuri, Juande667, xjuliox, Bettor, solanomor01, Chinyero, volkov, braulioT, Maikermx, iNowack, D83, MORKAS, dRoXe, JaviMarquez, danitre, Davi_TGI, DiegoR, ertate, cuenka16, nicotzioras, Spok68, urbion, linxes, kukikukarron, Talnoseque, Hyperr, VapaV, jfermar, Moigijon, slyjay73, DuckToy, nachomart, Iosu21, sbarri, sebasresa, Beiró, Llisus, agus_piscis10, Action SVG, Alc16, Trivi83, eyebee, riclanico, Per3zo, Qore, lolorm, abollao, Alvi, sergi303, Xilenos, barret, Gus_Fring, malloc, TomH30, jmofcb, paco_22_22, luigi323, Chelazo, dani10s, victor david, Yeiem93, Luiggi7, Guillen222, yoflipo, nenazojuanma, nitro_g4074, Senuto, gabivvamesia, javichu312, richard_11, Yery, Ivensound, El_pelos44, rvicario76, Mr.Chuflas, subaru_3, eruizm, Gomez89, barubita, Nicoplas, javibmw, el_noi_80, kapi21, satoo, barrosdepor, camaon99, craken, Flow-Rider, Castro87, Kikedecefe, xexpir, Cristian2014mx, _Juansp, jornefra, cucci, Pablitofr, Pablitofr, Rober_SR, kevinhtbs, chocoleitos, RamonLaC, cesarsl, drnrd, conquepoquico, hectordrums, Neuw84, bertoco, dondani96, cupralex, Octacon, pablomus85, josean-opc, davidap13, Raaz, erlanz, canijo82, MarcosRG86, Alianma, SinName, mSx, evomaoleon, BertopenST, a.cuadros71, Lumara, Gendos22, borjayadri2, litllevill, Jandrew, galelir, Josep20, borjiguez, THC77, di360, Juanjocantabria, grijan 2.0, copii92, JDMG, Morales92, nadiia.bcn93, yo_javi89, yurkli, Atajunen, carlo13, Desertcuervo, floppy666, amg129, manjerico, Franr50, iNFeCTeD, Rotemburgero, Link, kivamz, dj_ferrix, manu5, Vagabundo, aaronfdez, Manzi, Perilla, juanaco, pepetgi, pistoleromtb, cp_jj, diepecu2, Freddy169, Welmonk, JaquetónST, alrodri, LuisNM, Rekoba, bizu, ginyu 83, ephreon, rr7mo, Def89, CrisFRST5F, Mohoska, gilen44, ayl, SantiPMI, Jesús Peinado, 05kar, Lata8, Adrián pcg, Warelio, carlosVACA, trazas, barris31, danieleon, enriquevalera, antonioagui95, tito68, Sarge86, victorvOrtiz, bigpicha, ericoperico, JulinM, AlvaroRamlo, josermancol, Davidv, flotter, V de Viana, zainao, LeónST, rubiotuning, RacingSport
Notapor ateopoeta el 26 Nov 2017, 13:40
teltronik escribió:Buenas noches compañero como bien dices en el enunciado del mod monitoriza puertas capo y maletero ya está ....si no lleva sensores.. si te rompen un cristal no suena alarma, si te fuerzan la puerta no suena alarma hasta que no hay una apertura.
Hola compañero. Si fuerzan la puerta o rompen el cristal, casi casi seguro que el siguiente paso va a ser abrir la puerta. Momento en que sonara la "alarma OEM". La alarma "real" de fábrica cuesta 300e y monitoriza con detectores la presencia dentro del coche. Para estar dentro del coche, en cualquier caso o entras arrastrandote por la ventana rota (raro), o abres la puerta. Así que esta "alarma gratis OEM" me pareció mejor opción, al solo tener que pagar el OBDeleven que además me sirve para modificar más parámetros.
En este mensaje, ateopoeta ha recibido 2 agradecimientos de:
eibon (28 Nov 2017, 09:24), MORKAS (29 Nov 2017, 14:23)
ateopoeta
Agradecido: 17 veces
Notapor ateopoeta el 26 Nov 2017, 13:42
mierescity escribió:queria consultaros algo.la cuestion es que he seguido al pie de la letra las instrucciones que pone el compañero para activar la alarma oem y la cuestion es que supuestamente esta todo correctamente activado pero cuando hago la prueva para ver si suena,no suena nada de nada.mi coche esta fabricado en octubre es un my18 y este tema ya me tiene un poco mosca.alguien me puede hechar un cable? mi version de vag com es la 17.8...
Igual lo tienes correctamente activado pero no lo has comprobado bien. A ver si hay suerte...
Para comprobar si funciona quita el contacto del coche, quédate dentro y cierra con el mando a distancia (botón de la llave), espera al menos 30-40 segundos para que se "arme" la alarma. Y entonces abre la puerta desde dentro (desde el tirador de la puerta).
Para parar la alarma dale al botón de abrir el coche de la llave mando a distancia.
Espero que sea eso.....Suerte!
En este mensaje, ateopoeta ha recibido un agradecimiento de:
eibon (28 Nov 2017, 09:25)
ateopoeta
Notapor mierescity el 26 Nov 2017, 13:49
ya lo he hecho.lo he comprobado de todas formas posibles y nada de nada.no funciona
mierescity
Coche: Leon MK2 2.0 FR 200cv
Notapor ira92 el 26 Nov 2017, 15:08
Buenas, tengo un mk3 Fr del 2014 con navegador. Me llegó el OBDELEVEN el viernes y he estado haciendo varias modificaciones. No entiendo en el modulo de luces nivelación de faros en la adaptación modo presentacion. Tras hacer el escáner a mi me salía inactivo por defecto pero los full led cuando pongo el coche en marcha hace la nivelación. No tengo sensor de luces. Además con las luces le di Establecer los valores de fábrica. Antes de darle a confirmar me salto error nivelación de luces porque al poner La Luz larga el haz de luz no subía. Una vez confirmado los ajustes despareció el mensaje, volviendo a subir el haz de luz como siempre.
Antes esto último, los faros se quedan regulados como salen de fábrica no? Noto que las luces alumbran más y en principio Nadir se me ha quejado de que voy deslumbrando.
Punto 2: he activado la función leaving home siguiendo los pasos sin tener sensor pero al abrir el coche no se encienden. Cuando salgo del coche si tengo que dar una ráfaga de luz larga para que se queden encendidos el tiempo que esté marcado en la iluminación. Alguna solución para activar la función Leaving home?
Punto 3: al tener el navegador en la pantalla 5,8, cuando quiero activar el lodo off road después de adaptación no me parece la función car functions gen 2. Como puedo activar este modo?
Punto 4: yo tengo activado el plegado automático de los espejos para cerrar con un solo toque pero no se me activa el modo de cerrar espejos y cristales con un solo toque. Alguna solución?
Muchas gracias y perdonen la parrafada.
ira92
Notapor cvillajos el 26 Nov 2017, 15:58
ira92 escribió:Buenas, tengo un mk3 Fr del 2014 con navegador. Me llegó el OBDELEVEN el viernes y he estado haciendo varias modificaciones. No entiendo en el modulo de luces nivelación de faros en la adaptación modo presentacion. Tras hacer el escáner a mi me salía inactivo por defecto pero los full led cuando pongo el coche en marcha hace la nivelación. No tengo sensor de luces. Además con las luces le di Establecer los valores de fábrica. Antes de darle a confirmar me salto error nivelación de luces porque al poner La Luz larga el haz de luz no subía. Una vez confirmado los ajustes despareció el mensaje, volviendo a subir el haz de luz como siempre.
- Punto 1: Ni idea, nunca he tocado esa centralita.
- Punto 2: hay un hilo de detalle del MOD aquí: https://www.clubseatleon.net/viewtopic.php?f=8&t=114335&p=1994817&hilit=Coming+home+leaving#p1994817, quizá tengas/encuentres más info en él.
- Punto 3: tu Infotaiment es MIB gen1, no tienes esos canales de adaptación.
- Punto 4: creo que no conozco a nadie al que le suban las ventanillas con un toque de mando.
cvillajos
Agradecido: 3573 veces
Notapor Genzo el 26 Nov 2017, 19:40
Tienes activado para que el claxon funcione sin contacto... a alguien le he leido que tenia que ponerlo tambien. A ver si asi suena la flauta.
:nekora:
Genzo
Agradecido: 61 veces
Notapor teltronik el 26 Nov 2017, 23:19
Siento si te he ofendido con el comentario no era mi intencion....solo era a nivel informativo q este mod...no detecta rotura...solo entrada ...nada mas es añadir ese pequeño comentario....ya q abra compañero q activaran creyendo q si rompen un cristal suena.....(para abrir la guantera,no hace fata abrir una puerta)
teltronik
Agradecido: 18 veces
Notapor mierescity el 27 Nov 2017, 12:18
ahora que me lo dices,pues no,no tengo el claxon activado sin contacto...lo probare y os comento si al final me funciono.muchas gracias
mierescity
Notapor ateopoeta el 27 Nov 2017, 12:50
NO NO, NADA DE OFENDIDO!!!
no se si es que mi texto parecía algo que no era.
Me parece lógico explicar todo lo mejor posible para que no haya confusiones.
ateopoeta
Notapor teltronik el 27 Nov 2017, 19:41
perfecto!!!
teltronik
Notapor yujakantabro el 27 Nov 2017, 22:02
ateopoeta escribió:Acabo de activar alarma OEM en leon fabricado en agosto según las instrucciones del foro Ateca y funcionó.
Copio el proceso (Gracias XMadMax de cluseatateca.com):
https://www.clubseatateca.com/threads/c ... post-96932
ACTIVAR ALARMA OEM
Esto sirve para vehículos sin la alarma original, y monitoriza la apertura de puertas, capó y portón, haciendo sonar el claxon del coche si se produce una apertura sin haber sido recibido autorización del código de la llave. (Rotura de cristales y apertura desde dentro, apertura forzada con palanca, etc...).
Ya funciona la alarma (08/03/2017), en negrita los cambios respecto a como estaba anteriormente.
1. Ir a Módulo 09 - Centralita electrónica
2. Entrar en Codificación (pulsar arriba a la derecha, modo Bytes)
3. Ir al Byte 12
4. Activar Bit 0
5. Confirmar (V), código 31347
6. Ir atrás, a Adaptación, mismo módulo
7. Entrar en protección antirrobo
8. en DWA Alarmverzoegerung, cambiar valor a "Driver door contact thatcham"
9. en DWA Camper Modus, cambiar valor a "Activado"
10. en Ueberwachung Innenentriegelungshelbel, cambiar valor a "Activado"
11. (opcional) en Sirenen Alarmzahl, poner el número de veces que pitará cuando salte la alarma, puedes poner 1 o 10, por defecto ya está a 10.
12. en Akustischer Alarm Signalhorn, cambiar valor a "Activado"
13. en Diebstahlwarnanlage, cambiar valor a "Activado"
14. Confirmar, código 31347
15.
16. Para hacer que además, suene el claxon al abrir/cerrar:
17. Ir a Sonar el claxon al abrir y/o cerrar el coche
Las posibilidades de detección que tiene la alarma OEM:
• Alguien rompe una ventanilla, pasa el brazo y abre la puerta con el tirador de puerta.... la alarma suena.
• Alguien rompe la ventanilla del conductor, pasa el brazo y abre el capó con el tirador de capó.... la alarma suena
• Alguien fuerza el capó con palanca... la alarma suena
• Alguien fuerza el portón trasero con palanca... la alarma suena
El el de m17 hay un paso más que hay que realizar al igual que en los ateca
Busca aquí la diferencia.
yujakantabro
Notapor xsoldadito el 28 Nov 2017, 01:56
ACTIVAR ALARMA OEM
3. Ir al Byte 12
4. Activar Bit 0
15.
Yo hice esto y el mio es un MY18 tambien y funciona correctamente:
Ir al Byte 12
Activar Bit 0
Submenú - Señales de respuesta
Akustische Rueckmeldung global (Cambiar valor a "activado")
Akustische Rueckmeldung Signalhorn (Cambiar valor a "activado")
xsoldadito
Notapor eibon el 28 Nov 2017, 09:32
ACTIVAR ALARMA OEM
3. Ir al Byte 12
4. Activar Bit 0
15.
Ir al Byte 12
Activar Bit 0
El mío también es un MY18 y siguiendo estos mismos pasos me funciona la alarma OEM perfectamente. He de decir que el claxon sin el contacto ya me venía activado de fábrica.
Verba volant scripta manent
Usa el corrector ortográfico, el carril de la derecha y los intermitentes,
te zumbarán menos los oídos :ok: .
eibon
Notapor mierescity el 28 Nov 2017, 14:02
ACTIVAR ALARMA OEM
3. Ir al Byte 12
4. Activar Bit 0
15.
Ir al Byte 12
Activar Bit 0
a mi me salen todos los pasos bien excepto el ultimo,que no me sale el modulo/canal Diebstahlwarnanlage para poder activarlo.podria ser que se llamara de otra forma?? o que no estubiera en el modulo de adaptacion? es que no me lo explico... Diebstahlwarnanlage es el nombre exacto?? que que ni con el buscador me sale...
mierescity
Notapor GVM el 28 Nov 2017, 14:37
A mi me sale, MY18 tambien con alarma de serieImagen
GVM
Agradecido: 86 veces
