Seguidores: golf_1990, josusanchez5b, Jastur, r11ourense, MerioE, davidddgt, jose.a.llamas, gato125, Pkt, byChule, Hovig, SorianoFco, jygalvan, CubanPitbull, corderazo, israher, iDavid9669, nyro, pirulo79, Edu1589, ramargo75, javi.ferrer, kikelin, aleejandroogm, Trimmer, car212121, LeoST, Besaygf, kinipc, Rasekfighter, Romera, MartinLeon, camamaleon, Aceroinox1a, jramis, Juanquique, josele77, marlop, Peje, Pedrost, bailyibz, wiki88, teltronik, gogua, sirkez, carlosgzlez, mcecho, genialsoft, aironsam14, JoseCa, Dandy_gsi, vanscampa, Joseibz, trekam, La_jungla, jorgecrackets, aigort, msmdraven, IRO, Jorge75016, alejandro_javier, ivan0909, jmfcoto, viktor_ct_95, maxxg2, olgalberto1, danifusi, Josepo79, er_trompe, miyobe, jande, Petri, itz18, jagman, serguey79, rafapadilla93, Mate, undernok, lead, lead, csabafr2013, jluis, olmeras, LeidenSpain, osjamil, Valerofr150, flope63, Herrdoktor, pocososinos, carrasco13, pichonclv, C.reina, Daner84, inamarlo, aguscalderon, BaZZ, yujakantabro, Fonek, LARABA, juanmaroger, juanmac, Kipu, IvanMc2, garrafa2, Linker89, mihai G, Igor, bronce702, creasy1977, Gsclosada, lebowski, jaro_84, charly425, leonfr76, DBS83, joseanvazquez501, M3rs, borgio, NOCIVOX, FcoJ.M.N., VillaSB, t4alberto, lytry32.hc, david_gz, Kasky, diegol147, jasoriab, jninomo, jmiturbe, chetelopez, utopia95, Dreziel, jonatan1988, xsoldadito, Illan, Fernandoestrada, jd_zuri, Juande667, xjuliox, Bettor, solanomor01, Chinyero, volkov, braulioT, Maikermx, iNowack, D83, MORKAS, dRoXe, JaviMarquez, danitre, Davi_TGI, DiegoR, ertate, cuenka16, nicotzioras, Spok68, urbion, linxes, kukikukarron, Talnoseque, Hyperr, VapaV, jfermar, Moigijon, slyjay73, DuckToy, nachomart, Iosu21, sbarri, sebasresa, Beiró, Llisus, agus_piscis10, Action SVG, Alc16, Trivi83, riclanico, Per3zo, Qore, lolorm, abollao, Alvi, sergi303, Xilenos, barret, Gus_Fring, malloc, TomH30, jmofcb, paco_22_22, luigi323, Chelazo, dani10s, victor david, Yeiem93, Luiggi7, Guillen222, yoflipo, nenazojuanma, nitro_g4074, Senuto, gabivvamesia, javichu312, richard_11, Yery, Ivensound, El_pelos44, rvicario76, Mr.Chuflas, subaru_3, eruizm, Gomez89, barubita, Nicoplas, javibmw, el_noi_80, kapi21, satoo, barrosdepor, camaon99, craken, Flow-Rider, Castro87, Kikedecefe, xexpir, Cristian2014mx, _Juansp, jornefra, cucci, Pablitofr, Pablitofr, Rober_SR, kevinhtbs, chocoleitos, RamonLaC, cesarsl, drnrd, conquepoquico, hectordrums, Neuw84, bertoco, dondani96, cupralex, Octacon, pablomus85, josean-opc, davidap13, Raaz, erlanz, canijo82, MarcosRG86, Alianma, SinName, mSx, evomaoleon, BertopenST, a.cuadros71, Lumara, Gendos22, borjayadri2, litllevill, Jandrew, galelir, Josep20, borjiguez, THC77, di360, Juanjocantabria, grijan 2.0, copii92, JDMG, Morales92, nadiia.bcn93, yo_javi89, yurkli, Atajunen, carlo13, Desertcuervo, floppy666, amg129, manjerico, Franr50, iNFeCTeD, Rotemburgero, Link, kivamz, dj_ferrix, manu5, Vagabundo, aaronfdez, Manzi, Perilla, juanaco, pepetgi, pistoleromtb, cp_jj, diepecu2, Freddy169, Welmonk, JaquetónST, alrodri, LuisNM, Rekoba, bizu, ginyu 83, ephreon, rr7mo, Def89, CrisFRST5F, Mohoska, gilen44, ayl, SantiPMI, Jesús Peinado, 05kar, Lata8, Adrián pcg, Warelio, carlosVACA, trazas, barris31, danieleon, enriquevalera, antonioagui95, tito68, Sarge86, victorvOrtiz, bigpicha, ericoperico, JulinM, AlvaroRamlo, josermancol, Davidv, flotter, V de Viana, zainao, LeónST, rubiotuning, RacingSport
Notapor teltronik el 05 Ene 2018, 21:02
kuldas escribió:Alguien que tenga activado los intermitentes en contrafase con DLR le funciona correctamente. A mí en el passat b8 no me va. Luz diurna solo si que va perfectamente, pero en auto me da error el coche y él posición ni se enciende y también da fallo. He hecho varias codificaciones y nada de nada. La última que hice fue esta:
y porque no pruebas de cambiar el valor de Dimmwert...en vez de 0, pon 35!!!
lo as probado?...a modo de prueba te lo comento...vaya a ser que tu centralita no acepte 0..(a modo de prueba)
En este mensaje, teltronik ha recibido un agradecimiento de:
kuldas (05 Ene 2018, 21:14)
teltronik
Agradecido: 18 veces
Notapor kuldas el 05 Ene 2018, 21:19
Con 35 no he probado, de hecho con más de 28, que viene de origen, no he probado, porque la idea es que se apague cuando se ilumina el intermitente, si lo pongo a 35 iluminara más, o así debería ser...
He probado a dejarlo como está de origen quitando solo el valor de 28 de dimmwert y poniéndolo a 0, para que se apague el dlr de ese lado y solo se ilumine el intermitente, pero tampoco ha funcionado, me daba "corto a positivo".
kuldas
Coche: Leon MK2 2.0 16v 140cv
Agradecido: 9 veces
Notapor teltronik el 06 Ene 2018, 01:16
Ok......por ponerlo a 0,te dava corto?
kuldas (06 Ene 2018, 09:51)
teltronik
Notapor kuldas el 06 Ene 2018, 09:53
Todas las variaciones que hice, incluido poner ese valor a 0 daba corto.
Lo que puedo hacer, es ir subiendo hasta el 22 o así que es cuando se enciende el DLR, para probar con otros valores a ver si alguno no da error.
kuldas
Agradecido: 9 veces
Notapor teltronik el 06 Ene 2018, 12:43
apartir de cuando no te daba corto? 1?
lo mismo en lichtfunktion tienes que cambiar a otro parametro si quieres que se apague las DRL
teltronik
Notapor Shadows el 06 Ene 2018, 14:47
Asi lo tengo yo y funciona perfetamente
Adjuntos
Seat Leon FR 1.8 TSI 180 DSG7 + S9+
repro a 210 CV
Shadows
Notapor kuldas el 06 Ene 2018, 15:16
Ufff, yo no tengo esos valores modificados. Yo seguí el mod que sigue:
Tú ahí me pones otros parámetros a variar. Probaré luego si puedo.
Dame un pantallazo de las últimas opciones de ambos módulos. Lo equivalente a estos míos. A mí para cada faro en los parámetros del mod que te puse cambia el calor de origen.
ImagenImagen
kuldas
Agradecido: 9 veces
Notapor cuenka16 el 06 Ene 2018, 15:23
kuldas escribió:Estos son :
[ Imagen ][ Imagen ]
Con esta mod que es lo que hace exactamente??
cuenka16
Notapor kuldas el 06 Ene 2018, 15:27
Es mi codificación de origen. Lo que intento es luces dlr en contrafase con intermitentes.
kuldas
Agradecido: 9 veces
Notapor Shadows el 06 Ene 2018, 16:17
Las modificaciones que te he mandado son las que he hecho y funciona dlr en contrafase con intermitentes
repro a 210 CV
Shadows
Notapor kuldas el 06 Ene 2018, 19:15
Pues a mí esa modificación que me pones no me va. Será otra centralita, otro MY o no se. Seguiré investigando, gracias.
kuldas
Agradecido: 9 veces
Notapor MORKAS el 07 Ene 2018, 01:04
Saludos...hoy he hecho copia de seguridad de un Passat de un compi de trabajo..y cambiado alguna cosilla...y mi sorpresa...cuando en casa voy a echar un ojo ..a esas copias..y me sale "historial vacio"....que le pasará a la app?.. :-(
MORKAS
Agradecido: 368 veces
Notapor stewei el 07 Ene 2018, 22:02
MORKAS escribió:Saludos...hoy he hecho copia de seguridad de un Passat de un compi de trabajo..y cambiado alguna cosilla...y mi sorpresa...cuando en casa voy a echar un ojo ..a esas copias..y me sale "historial vacio"....que le pasará a la app?.. :-(
Yo tambien he tenido problemas haciendo backups. Por ejemplo, haciendo backup de la unidad 03 me sale que tiene 44 adaptaciones, y una vez hecha, solo aparecen 41.....
En este mensaje, stewei ha recibido un agradecimiento de:
MORKAS (10 Ene 2018, 02:43)
stewei
Agradecido: 465 veces
Notapor Joandc el 08 Ene 2018, 20:38
Saludos, ésta tarde he hecho mis primeros mods, bueno, más bien los ha hecho la aplicación del Obdeleven :aplauso: :aplauso:
- Litros a repostar en el Fis
- Intermitentes de confort
- Luces dia apagadas con freno mano
- Mostrar velocidad ventilador en el climatizador en modo auto
Todos ok
Salud i benzina
Joandc
Notapor maxim el 08 Ene 2018, 21:25
Me gustaría comprar el OBDeleven pero me esta asustando el tema de la copia de de seguridad, ¿desde cuando están fallando? Yo lo primero que quiero hacer cuando lo tenga es hacer la copia si ella me da rollo tocar nada...
S@lu2
maxim
Agradecido: 17 veces
