Seguidores: golf_1990, josusanchez5b, Jastur, r11ourense, MerioE, davidddgt, jose.a.llamas, gato125, Pkt, byChule, Hovig, SorianoFco, jygalvan, CubanPitbull, corderazo, israher, iDavid9669, nyro, pirulo79, Edu1589, ramargo75, javi.ferrer, kikelin, aleejandroogm, Trimmer, car212121, LeoST, Besaygf, kinipc, Rasekfighter, Romera, MartinLeon, camamaleon, Aceroinox1a, jramis, Juanquique, josele77, marlop, Peje, Pedrost, bailyibz, wiki88, teltronik, gogua, sirkez, carlosgzlez, mcecho, genialsoft, aironsam14, JoseCa, Dandy_gsi, vanscampa, Joseibz, trekam, La_jungla, jorgecrackets, aigort, msmdraven, IRO, Jorge75016, alejandro_javier, ivan0909, jmfcoto, viktor_ct_95, maxxg2, olgalberto1, danifusi, Josepo79, er_trompe, miyobe, jande, Petri, itz18, jagman, serguey79, rafapadilla93, Mate, undernok, lead, lead, csabafr2013, jluis, olmeras, LeidenSpain, osjamil, Valerofr150, flope63, Herrdoktor, pocososinos, carrasco13, pichonclv, C.reina, Daner84, inamarlo, aguscalderon, BaZZ, yujakantabro, Fonek, LARABA, juanmaroger, juanmac, Kipu, IvanMc2, garrafa2, Linker89, mihai G, Igor, bronce702, creasy1977, Gsclosada, lebowski, jaro_84, charly425, leonfr76, DBS83, joseanvazquez501, M3rs, borgio, NOCIVOX, FcoJ.M.N., VillaSB, t4alberto, lytry32.hc, david_gz, Kasky, diegol147, jasoriab, jninomo, jmiturbe, chetelopez, utopia95, Dreziel, jonatan1988, xsoldadito, Illan, Fernandoestrada, jd_zuri, Juande667, xjuliox, Bettor, solanomor01, Chinyero, volkov, braulioT, Maikermx, iNowack, D83, MORKAS, dRoXe, JaviMarquez, danitre, Davi_TGI, DiegoR, ertate, cuenka16, nicotzioras, Spok68, urbion, linxes, kukikukarron, Talnoseque, Hyperr, VapaV, jfermar, Moigijon, slyjay73, DuckToy, nachomart, Iosu21, sbarri, sebasresa, Beiró, Llisus, agus_piscis10, Action SVG, Alc16, Trivi83, eyebee, riclanico, Per3zo, Qore, lolorm, abollao, Alvi, sergi303, Xilenos, barret, Gus_Fring, malloc, TomH30, jmofcb, paco_22_22, luigi323, Chelazo, dani10s, victor david, Yeiem93, Luiggi7, Guillen222, yoflipo, nenazojuanma, nitro_g4074, Senuto, gabivvamesia, javichu312, richard_11, Yery, Ivensound, El_pelos44, rvicario76, Mr.Chuflas, subaru_3, eruizm, Gomez89, barubita, Nicoplas, javibmw, el_noi_80, kapi21, satoo, barrosdepor, camaon99, craken, Flow-Rider, Castro87, Kikedecefe, xexpir, Cristian2014mx, _Juansp, jornefra, cucci, Pablitofr, Pablitofr, Rober_SR, kevinhtbs, chocoleitos, RamonLaC, cesarsl, drnrd, conquepoquico, hectordrums, Neuw84, bertoco, dondani96, cupralex, Octacon, pablomus85, josean-opc, davidap13, Raaz, erlanz, canijo82, MarcosRG86, Alianma, SinName, mSx, evomaoleon, BertopenST, a.cuadros71, Lumara, Gendos22, borjayadri2, litllevill, Jandrew, galelir, Josep20, borjiguez, THC77, di360, Juanjocantabria, grijan 2.0, copii92, JDMG, Morales92, nadiia.bcn93, yo_javi89, yurkli, Atajunen, carlo13, Desertcuervo, floppy666, amg129, manjerico, Franr50, iNFeCTeD, Rotemburgero, Link, kivamz, dj_ferrix, manu5, Vagabundo, aaronfdez, Manzi, Perilla, juanaco, pepetgi, pistoleromtb, cp_jj, diepecu2, Freddy169, Welmonk, JaquetónST, alrodri, LuisNM, Rekoba, bizu, ginyu 83, ephreon, rr7mo, Def89, CrisFRST5F, Mohoska, gilen44, ayl, SantiPMI, Jesús Peinado, 05kar, Lata8, Adrián pcg, Warelio, carlosVACA, trazas, barris31, danieleon, enriquevalera, antonioagui95, tito68, Sarge86, victorvOrtiz, bigpicha, ericoperico, JulinM, AlvaroRamlo, josermancol, Davidv, flotter, V de Viana, zainao, LeónST, rubiotuning, RacingSport
Notapor levorg el 21 Ene 2018, 18:18
mierescity escribió:a ver si alguien me puede hechar una mano.estoy intentando hacer este mod en un fr plus my18 y en el ultimo paso no puedo seguir por que no me sale ese menu,el que me sale es diferente.este es el mod;
Cerrar ventanillas al detectar lluvia Todos los modelos
Si te dejas el coche con las ventanillas bajadas y se pone a llover, el coche cierra automáticamente las ventanillas. Coche cerrado.
1 - Módulo 09 - Centralita electrónica. Code (31347)
2 - Adaptación
3 - Control de acceso 2 Hasta MY16 o entrar en ZV Komfort Desde MY17 y posteriores
4 - Regenschliessen ein aus -- (Cambiar valor a Activado)
5 - Menuesteuerung regenschliessen -- (Cambiar valor a Activado)
6 - Regenschliessen art (Modo de cierre) -- (Cambiar valor a Permanente)
7 - Ir al componente RLHS
8 - Codificación extendida (Modo Bytes)
9 - Byte 0 -- (Activar Bits 1 y 2)
donde pone ir al componente RLHS,en mi coche me sale esto:
nadie me puede hechar un cable con esto?
bueno,pues visto que nadie sabe o dice nada,aconsejo editar el post de modificaciones de la primera pagina,ya que este mod NO sirve para todos los modelos,al menos tal y como esta puesto,para los my18 no funciona.
Hola @mierescity, puede que tenga que ver con el tipo de sensor de lluvia con el que viene el Leon. Creo que para que el mod funcione hay que poner este:
viewtopic.php?f=8&t=114823&hilit=Cierre+lluvia+Ventanillas#p1842971
Tengo un golf con el sensor de cuatro puntos y si que funciona lo de cerrar las ventanillas con lluvia (eso sí, lo hice con vagcom no con obdeleven).
En este mensaje, levorg ha recibido un agradecimiento de:
mierescity (21 Ene 2018, 21:40)
levorg
Agradecido: 206 veces
Notapor csabafr2013 el 21 Ene 2018, 18:38
Sabéis como reactivar en la pantalla el esc que a desaparecidos después de actualizar la radio
csabafr2013
Notapor MORKAS el 21 Ene 2018, 19:48
miceor escribió:No tiene porque ser perjudicial. Primero mira la carga que te muestra en el primer apartado que puse.
El sistema de regeneración se dispara dependiendo de la carga.
Primero freno y luego acelerador.
Creo que los pasos son los correctos, el mio es gasolina. Cuando investigué esto lo hice en el coche de un amigo para probar y a base de buscar en muchos sitios al final funcionó, pero no he vuelto a realizarlo desde entonces.
Supongo que para cancelarlo, se podrá hacer desde el dispositivo, ya que permaneces conectado con el en todo momento.
Yo lo dejé terminar, aunque en varias ocasiones estube a punto de darlo por finalizado, pensando que se habia quedado pillado al tardar tanto.
Muchas gracias..esta bien saber esto..por si un dia no nos regenera....
MORKAS
Agradecido: 368 veces
Notapor Joandc el 21 Ene 2018, 21:45
2 - Adaptación
A mi me pasa lo mismo, no aparece la opción RLHS :cry: . Si no recuerdo mal, lo del sensor era para cerrar tambien el techo.
Salud i benzina
Joandc
Notapor Valerofr150 el 21 Ene 2018, 22:24
2 - Adaptación
A mi tampoco me funciona y es un my17
Enviado desde mi MI 6 mediante Tapatalk
Valerofr150
Notapor ranaxperience el 22 Ene 2018, 15:29
2 - Adaptación
Yo tengo un Xperience MY18 y si pude hacerlo, lo único que no me cierra es el techo panorámico, pero dicen que entonces tendría que cambiar el sensor y paso. En los MY 18 quizás cambia algo, yo también miro el foro de los Ateca, pero en este caso segui el de MIceor saludos
ranaxperience
Notapor ranaxperience el 22 Ene 2018, 15:38
Buenas a todos, ya poca cosa me queda por hacer en mi xperience MY18.
Cuando tenga tiempo haré el montaje del altavoz central y subwofer y con el OBDeleven, alguien sabe como hacer para que los retrovisores no se abran al abrir coche, que solo se habrán al darle al contacto, lo he buscado y no encuentro nada.
También intente lo del al poner marcha atrás que la luz ambiental de las puertas se pusiera en blanco, pero no lo he conseguido.
Y cierre ventanillas con lluvia, va bien pero el techo no cierra, pero eso ya dicen que es cosa del sensor y no de programación.
Mis mods:
Cierre ventanillas
Paneles fondo carbono
Alarma
Cierre retros un solo toque
Detección señales
Cornering
Aceleración directa
Actualización mapas gps
reducción oscilación arrancada en fuerte
Reprogramación a 220 CV y repro del DSG
Saludos a todos y si puedo ayudar en algo se intentara
ranaxperience
Notapor ranaxperience el 22 Ene 2018, 15:45
Ah me olvidaba que tampoco tengo claro en un MY 18 hay forma de activar en la pantalla el visualizador SPORT
ranaxperience
Notapor cvillajos el 22 Ene 2018, 15:58
ranaxperience escribió:Buenas a todos, ya poca cosa me queda por hacer en mi xperience MY18.
Mis mods:
Cierre ventanillas
Alarma
Detección señales
Cornering
Aceleración directa
Si está por ahí la info. Creo recordar que hay dos vías, actualzando firmware y parametrizando centralitas (proceso complejo) o cambiando unos canales de adaptación que no recuerdo donde estaba el post (proceso simple, pero no recuerdo 100%).
ranaxperience (22 Ene 2018, 16:04)
cvillajos
Agradecido: 3572 veces
Notapor cvillajos el 22 Ene 2018, 16:00
ranaxperience escribió:Ah me olvidaba que tampoco tengo claro en un MY 18 hay forma de activar en la pantalla el visualizador SPORT
Negativo. Es una función que requiere código SWAP (y esto es independiente del MY, al menos que yo sepa)
ranaxperience (22 Ene 2018, 16:05)
cvillajos
Notapor Genzo el 22 Ene 2018, 16:54
Mis mods:
Cierre ventanillas
Alarma
Detección señales
Cornering
Aceleración directa
Si además quieres que los espejos no se abran siempre que abras el coche con el mando y que sólo lo hagan al poner contacto. (Sólo en vehículos cuyas unidades de puertas "La 42 y la 52" cuya Versión de software sea : 0032. En anteriores hay que actualizar las centralitas)
8 - En Adaptación, entrar en Spiegelverstellung
9 - Signalisierung_Spiegelanklappung -- (Cambiar valor a Desactivado)
Funciona tanto si tenemos hecho el mod de cierre con un toque, como si no lo tenemos hecho.
Son muchas paginas y muuuucha información, pero hay que leer y todo se encuentra.Un saludo.
:nekora:
En este mensaje, Genzo ha recibido 2 agradecimientos de:
Bettor (22 Ene 2018, 17:41), ranaxperience (22 Ene 2018, 17:06)
Genzo
Agradecido: 61 veces
Notapor ranaxperience el 22 Ene 2018, 17:40
Mis mods:
Cierre ventanillas
Alarma
Detección señales
Cornering
Aceleración directa
Realizado y funcionando, muchas gracias.
En la lista me deje:
- Litros a repostar.
- Desactivación luces diurnas desde menú
- Apagar luces con freno de mano puesto.
- 5 intermitentes
Creo que ya le he sacado provecho al aparatito.
En este mensaje, ranaxperience ha recibido un agradecimiento de:
linxes (23 Ene 2018, 00:55)
ranaxperience
Notapor linxes el 23 Ene 2018, 00:58
Mis mods:
Cierre ventanillas
Alarma
Detección señales
Cornering
Aceleración directa
- 5 intermitentes
Una duda que tengo después de leer el hilo completo, creo. Es que no veo si ¿se puede activar la detección de sueño del conductor con alguna codificación? Es que es una cosa que no pedi en la casa pero estaría bien tener.
linxes
Notapor ertate el 23 Ene 2018, 04:38
Mis mods:
Cierre ventanillas
Alarma
Detección señales
Cornering
Aceleración directa
- 5 intermitentes
Pues no amigo, para activar la deteccion de cansancio es necesario un codigo unico para cada coche que puedes adquirir en la seat previo pago. se puede activar incluso despues de adquirir el coche.
En este mensaje, ertate ha recibido 2 agradecimientos de:
craken (21 Feb 2018, 16:35), linxes (23 Ene 2018, 10:25)
ertate
Agradecido: 128 veces
Notapor Dvd83 el 23 Ene 2018, 10:52
Hola buenas, alguien me podrías echar una mano, en cuanto a que tengo un Seat Leon St mk18 y este día le instale una unidad de Navegación Plus y pese a que todo va bien, y va como un tiro y es una pasada A la hora de codificar con la cámara y el asistiendo de cambio de carril y señales de trafico, así como del ACC día error. Ahora solo sale error al conectar el ACC con la mantea.
Si alguien sabe como casar estas codificaciones o como solucionar el error...
Muchas gracias
Dvd83
