Seguidores: golf_1990, josusanchez5b, Jastur, r11ourense, MerioE, davidddgt, jose.a.llamas, gato125, Pkt, byChule, Hovig, SorianoFco, jygalvan, CubanPitbull, corderazo, israher, iDavid9669, nyro, pirulo79, Edu1589, ramargo75, javi.ferrer, kikelin, aleejandroogm, Trimmer, car212121, LeoST, Besaygf, kinipc, Rasekfighter, Romera, MartinLeon, camamaleon, Aceroinox1a, jramis, Juanquique, josele77, marlop, Peje, Pedrost, bailyibz, wiki88, teltronik, gogua, sirkez, carlosgzlez, mcecho, genialsoft, aironsam14, JoseCa, Dandy_gsi, vanscampa, Joseibz, trekam, La_jungla, jorgecrackets, aigort, msmdraven, IRO, Jorge75016, alejandro_javier, ivan0909, jmfcoto, viktor_ct_95, maxxg2, olgalberto1, danifusi, Josepo79, er_trompe, miyobe, jande, Petri, itz18, jagman, serguey79, rafapadilla93, Mate, undernok, lead, lead, csabafr2013, jluis, olmeras, LeidenSpain, osjamil, Valerofr150, flope63, Herrdoktor, pocososinos, carrasco13, pichonclv, C.reina, Daner84, inamarlo, aguscalderon, BaZZ, yujakantabro, Fonek, LARABA, juanmaroger, juanmac, Kipu, IvanMc2, garrafa2, Linker89, mihai G, Igor, bronce702, creasy1977, Gsclosada, lebowski, jaro_84, charly425, leonfr76, DBS83, joseanvazquez501, M3rs, borgio, NOCIVOX, FcoJ.M.N., VillaSB, t4alberto, lytry32.hc, david_gz, Kasky, diegol147, jasoriab, jninomo, jmiturbe, chetelopez, utopia95, Dreziel, jonatan1988, xsoldadito, Illan, Fernandoestrada, jd_zuri, Juande667, xjuliox, Bettor, solanomor01, Chinyero, volkov, braulioT, Maikermx, iNowack, D83, MORKAS, dRoXe, JaviMarquez, danitre, Davi_TGI, DiegoR, ertate, cuenka16, nicotzioras, Spok68, urbion, linxes, kukikukarron, Talnoseque, Hyperr, VapaV, jfermar, Moigijon, slyjay73, DuckToy, nachomart, Iosu21, sbarri, sebasresa, Beiró, Llisus, agus_piscis10, Action SVG, Alc16, Trivi83, eyebee, riclanico, Per3zo, Qore, lolorm, abollao, Alvi, sergi303, Xilenos, barret, Gus_Fring, malloc, TomH30, jmofcb, paco_22_22, luigi323, Chelazo, dani10s, victor david, Yeiem93, Luiggi7, Guillen222, yoflipo, nenazojuanma, nitro_g4074, Senuto, gabivvamesia, javichu312, richard_11, Yery, Ivensound, El_pelos44, rvicario76, Mr.Chuflas, subaru_3, eruizm, Gomez89, barubita, Nicoplas, javibmw, el_noi_80, kapi21, satoo, barrosdepor, camaon99, craken, Flow-Rider, Castro87, Kikedecefe, xexpir, Cristian2014mx, _Juansp, jornefra, cucci, Pablitofr, Pablitofr, Rober_SR, kevinhtbs, chocoleitos, RamonLaC, cesarsl, drnrd, conquepoquico, hectordrums, Neuw84, bertoco, dondani96, cupralex, Octacon, pablomus85, josean-opc, davidap13, Raaz, erlanz, canijo82, MarcosRG86, Alianma, SinName, mSx, evomaoleon, BertopenST, a.cuadros71, Lumara, Gendos22, borjayadri2, litllevill, Jandrew, galelir, Josep20, borjiguez, THC77, di360, Juanjocantabria, grijan 2.0, copii92, JDMG, Morales92, nadiia.bcn93, yo_javi89, yurkli, Atajunen, carlo13, Desertcuervo, floppy666, amg129, manjerico, Franr50, iNFeCTeD, Rotemburgero, Link, kivamz, dj_ferrix, manu5, Vagabundo, aaronfdez, Manzi, Perilla, juanaco, pepetgi, pistoleromtb, cp_jj, diepecu2, Freddy169, Welmonk, JaquetónST, alrodri, LuisNM, Rekoba, bizu, ginyu 83, ephreon, rr7mo, Def89, CrisFRST5F, Mohoska, gilen44, ayl, SantiPMI, Jesús Peinado, 05kar, Lata8, Adrián pcg, Warelio, carlosVACA, trazas, barris31, danieleon, enriquevalera, antonioagui95, tito68, Sarge86, victorvOrtiz, bigpicha, ericoperico, JulinM, AlvaroRamlo, josermancol, Davidv, flotter, V de Viana, zainao, LeónST, rubiotuning, RacingSport
Notapor Peje el 01 Mar 2018, 07:40
Joandc escribió:
fegavo escribió:
Peje escribió:
fegavo escribió:
Peje escribió:
fegavo escribió:Luces dia (DRL) apagadas con el freno de mano puesto Todos los modelos
Esta modificación es muy interesante porque nos permite dejar las luces de día (DRL) apagadas mientras tengamos el freno de mano puesto con contacto y sin el. Muy útil en condiciones de batería baja.
1 - Módulo 09 - Centralita electrónica. Code (31347)
2 - Adaptación
3 - Luz de circulación diurna Hasta MY16 o entrar en Aussenlicht_Front Desde MY17 y posteriores
4 - Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten -- (Cambiar valor a Activado)
Buenas, he hecho esta mod en un MY18, pero no funciona “correctamente”. Solo se apagan las luces diurnas cuando está la ruleta en posición 0, en auto no se apagan. Ha alguien más le ha pasado?
Yo lo tengo hecho en un MY18 y se apagan con freno de mano puesto
El mío también, pero solo lo hace si la ruleta de luces está en posición 0.
Si esta en Auto y es de noche, obviamente no lo hace, si es de dia lo hace, da igual donde este la ruleta, tambien hice el Mod para que aparezca en pantalla la opcion de quitar las luces diurnas.
Hay dos mod al respecto de lo que estais hablando, uno para freno mano y otro para posicion 0 de ruleta, no los he mirado detenidamente, porque solo hice la del freno de mano y la de la pantalla, pero no creo que sean iguales, hay que tenerlo en cuenta.
Pues ayer cuando lo hice por la tarde, aun no era de noche y juraría que solo lo hacia cuando tenia puesto la ruleta en posición "0". El tuyo es un my18 full led?
Yo lo he hecho en un MY17 y solo funciona con la posición 0 del conmutador de luces, en auto no se apagan (que es lo que yo buscaba) habrá que continuar investigando.
Hoy lo he comprobado mejor y si es asi, solo funciona con selector en 0, me falta comprobar con la opcion de pantalla a ver que e lo que hace.
Un saludo y perdonaz por el equívoco...
Un saludo...
Peje
Agradecido: 9 veces
Notapor levorg el 01 Mar 2018, 10:36
Peje escribió:
Joandc escribió:
fegavo escribió:
2 - Adaptación
Yo tengo desactivadas las DRL desde pantalla y con el selector de luces en auto permanecen apagadas. En caso de ser necesarias las luces se encienden todas, DRL incluidas.
levorg
Agradecido: 206 veces
Notapor cholvete el 01 Mar 2018, 10:38
Hola!
Tengo idea de comprarlo próximamente pero tengo un par de dudas.
Lleva idea de usar solo los Mods automaticos, me da miedo trastear ya que no entiendo mucho, y echando un vistazo a los mods automáticos que aparecen, creo que solo me interesan 3 o 4, lo recomendáis comprar igual aunque solo te interesen tan pocos mods?
A parte de esto, hay más mods haciéndolos de forma manual que automáticos o son los mismos nada más que de esta forma te consumen créditos?
Gracias!
Cholvete 2.0 :cuñao: ---------------------- SEAT LEON SC FR 1.8 TSI 180 CV :enamorado:
cholvete
Agradecido: 147 veces
Notapor jasoriab el 01 Mar 2018, 11:00
cholvete escribió:Hola!
Gracias!
Creo que sí merece la pena tenerlo. Aparte de los mods, puedes hacer chequeos cuando quieras, comprobando si tiene alguna avería memorizada.
Además, si en la familia tienes algún otro coche del grupo VAG, lo puedes usar en él. Si no me equivoco, no hay límite de coches en los que se puede usar.
En este mensaje, jasoriab ha recibido un agradecimiento de:
cholvete (01 Mar 2018, 11:02)
jasoriab
Agradecido: 2019 veces
Notapor levorg el 01 Mar 2018, 11:06
Gracias!
Ademas de para codificar te vale para diagnosticar, e incluso para ver parametros en tiempo real.
De modo "manual" puedes cambiar todo lo que admita cambios (y conozcas la codificacion claro). En modo automatico dependes de que el desarrollador incorpore mas mods y pierdes un poco el control de lo que se modifica, y ademas cuesta creditos como comentas.
En este mensaje, levorg ha recibido un agradecimiento de:
cholvete (01 Mar 2018, 11:48)
levorg
Notapor cholvete el 01 Mar 2018, 11:49
Gracias!
Me explicas que es eso de parámetros en tiempo real? No tengo casi idea de todo esto y mejor informarme lo máximo posible antes de comprar.
cholvete
Notapor Llopis54 el 01 Mar 2018, 12:06
Hola chicos una pregunta tengo un st fr de este año y quería haceros una pregunta tengo intención de comprarme el obdeleven para abrir cosas que el coche no trae es un advanced trae por así decirlo de todo pero sin activar algunas cosas bueno a la pregunta que me lio ¿ si modifico algo como por ejemplo poner el cuadro de carbono , el reconocer señales o la alarma y tal , se pierde la garantía ? Es que me tiene con la duda eso ... gracias !
Llopis54
Notapor cvillajos el 01 Mar 2018, 12:52
Llopis54 escribió:Hola chicos una pregunta tengo un st fr de este año y quería haceros una pregunta tengo intención de comprarme el obdeleven para abrir cosas que el coche no trae es un advanced trae por así decirlo de todo pero sin activar algunas cosas bueno a la pregunta que me lio ¿ si modifico algo como por ejemplo poner el cuadro de carbono , el reconocer señales o la alarma y tal , se pierde la garantía ? Es que me tiene con la duda eso ... gracias !
El tema de la garantía está archi-comentado seguro que si usas el buscador encuentras Información suficiente :ok:
cvillajos
Agradecido: 3572 veces
Notapor Llopis54 el 01 Mar 2018, 12:55
Gracias ! Buscare información sobre ello ! :cafe:
Llopis54
Notapor cvillajos el 01 Mar 2018, 12:59
Gracias!
Mediciones de datos en tiempo real que se envían por el CanBus (o datos transformados en función de cierta fórmula).
Por ejemplo, la curva de par... Yo la semana pasada​ hice la medición en 4a (tenia ganas ya de sacarla pero no encontraba momento ni lugar...) y me dió un pico de 273NM teóricos y bastante sostenido por encima de 250NM desde 1400rpm hasta más allá​ de 4000rpm. No es un banco de pruebas, pero me da una idea.
Otras métricas: %motor, posición del pedal del acelerador, voltaje de la batería, presiones y temperaturas varias, etc...
cholvete (01 Mar 2018, 13:07)
cvillajos
Notapor levorg el 01 Mar 2018, 13:01
Gracias!
Pues dentro de cada modulo (motor, frenos, centralita electrónica, etc.) hay un apartado llamado "datos en tiempo real" (además de los de adaptación y codificación extendida, que son los que te permiten codificar funciones) en el que puedes seleccionar diferentes canales y medir cosas como por ejemplo, tiempos de inyección, de encendido, presión del turbo, posición del pedal del acelerador, temperaturas en admisión y escape, etc. etc., hay cientos.
Por cierto, aprovecho para comentar que el estado de carga de la batería (para los que no tenemos función SOC activada en el cuadro, a partir de MY17) se puede ver en el apartado de datos en tiempo real del módulo 19, creo recordar que era algo como "estado carga batería"(concretamente, se puede ver la carga máxima que admite la batería en Ah, la actual tambien en Ah, y con el cociente sacas el % de carga).
En este mensaje, levorg ha recibido 3 agradecimientos de:
cholvete (01 Mar 2018, 13:07), Guibegmar (01 Mar 2018, 13:27), yak54 (01 Mar 2018, 21:35)
levorg
Notapor teltronik el 01 Mar 2018, 21:30
Gracias!
Y no hay ninguna manera de activar eso en el Fis?
teltronik
Agradecido: 18 veces
Notapor yak54 el 01 Mar 2018, 21:41
@cholvete los mods manuales no consumen créditos. Yo prefiero hacerlos yo mismo, así veo que modifico.
La operativa es fácil si eres meticuloso, si vas a tocar el módulo 09 haces una copia de seguridad del 09 y te la envías al mail. Yo apunto en una libreta lo que cambio con el mod y como estaban los valores antes de tocar, así no tendrás problemas.
Eso si, los mods de uno en uno, por lo menos al principio.
Enviado desde mi Redmi 4 mediante Tapatalk
En este mensaje, yak54 ha recibido un agradecimiento de:
eibon (07 Mar 2018, 18:26)
yak54
Agradecido: 116 veces
Notapor levorg el 01 Mar 2018, 23:20
Gracias!
Lo planteé inicialmente así pero no hubo huevos. No contento con esto, recorrí datos reales de varios módulos hasta que me encontré con lo que comentaba antes.
levorg
Notapor gogua el 03 Mar 2018, 09:56
hola
como se hace backup de las centralitas ??
EDITO: https://www.youtube.com/watch?v=lZTvl2vli3Q
- Seat Leon MK1 - FR TDI 150cv (2004)
- Seat Leon MK3 - X-Perience TDI 184cv DSG (MY16)
Galeria MK3
En este mensaje, gogua ha recibido un agradecimiento de:
DVD_1982 (03 Mar 2018, 19:07)
gogua
Agradecido: 171 veces
Nuevo León por Madrid
Foro: Presentaciones
Autor: Pampanilla
Respuestas: 0
Hilo del León mkIV e-hybrid
Foro: General
Autor: vkr84
Respuestas: 610
SEAT Leon 1.0 TSI S&S Style XS 81 kW 110CV
Autor: Waltry
Respuestas: 5
LEON ST Special Edition
Autor: Buils2
Respuestas: 6
León Cupra 290
Autor: Beet
Respuestas: 5
