Seguidores: golf_1990, josusanchez5b, Jastur, r11ourense, MerioE, davidddgt, jose.a.llamas, gato125, Pkt, byChule, Hovig, SorianoFco, jygalvan, CubanPitbull, corderazo, israher, iDavid9669, nyro, pirulo79, Edu1589, ramargo75, javi.ferrer, kikelin, aleejandroogm, Trimmer, car212121, LeoST, Besaygf, kinipc, Rasekfighter, Romera, MartinLeon, camamaleon, Aceroinox1a, jramis, Juanquique, josele77, marlop, Peje, Pedrost, bailyibz, wiki88, teltronik, gogua, sirkez, carlosgzlez, mcecho, genialsoft, aironsam14, JoseCa, Dandy_gsi, vanscampa, Joseibz, trekam, La_jungla, jorgecrackets, aigort, msmdraven, IRO, Jorge75016, alejandro_javier, ivan0909, jmfcoto, viktor_ct_95, maxxg2, olgalberto1, danifusi, Josepo79, er_trompe, miyobe, jande, Petri, itz18, jagman, serguey79, rafapadilla93, Mate, undernok, lead, lead, csabafr2013, jluis, olmeras, LeidenSpain, osjamil, Valerofr150, flope63, Herrdoktor, pocososinos, carrasco13, pichonclv, C.reina, Daner84, inamarlo, aguscalderon, BaZZ, yujakantabro, Fonek, LARABA, juanmaroger, juanmac, Kipu, IvanMc2, garrafa2, Linker89, mihai G, Igor, bronce702, creasy1977, Gsclosada, lebowski, jaro_84, charly425, leonfr76, DBS83, joseanvazquez501, M3rs, borgio, NOCIVOX, FcoJ.M.N., VillaSB, t4alberto, lytry32.hc, david_gz, Kasky, diegol147, jasoriab, jninomo, jmiturbe, chetelopez, utopia95, Dreziel, jonatan1988, xsoldadito, Illan, Fernandoestrada, jd_zuri, Juande667, xjuliox, Bettor, solanomor01, Chinyero, volkov, braulioT, Maikermx, iNowack, D83, MORKAS, dRoXe, JaviMarquez, danitre, Davi_TGI, DiegoR, ertate, cuenka16, nicotzioras, Spok68, urbion, linxes, kukikukarron, Talnoseque, Hyperr, VapaV, jfermar, Moigijon, slyjay73, DuckToy, nachomart, Iosu21, sbarri, sebasresa, Beiró, Llisus, agus_piscis10, Action SVG, Alc16, Trivi83, eyebee, riclanico, Per3zo, Qore, lolorm, abollao, Alvi, sergi303, Xilenos, barret, Gus_Fring, malloc, TomH30, jmofcb, paco_22_22, luigi323, Chelazo, dani10s, victor david, Yeiem93, Luiggi7, Guillen222, yoflipo, nenazojuanma, nitro_g4074, Senuto, gabivvamesia, javichu312, richard_11, Yery, Ivensound, El_pelos44, rvicario76, Mr.Chuflas, subaru_3, eruizm, Gomez89, barubita, Nicoplas, javibmw, el_noi_80, kapi21, satoo, barrosdepor, camaon99, craken, Flow-Rider, Castro87, Kikedecefe, xexpir, Cristian2014mx, _Juansp, jornefra, cucci, Pablitofr, Pablitofr, Rober_SR, kevinhtbs, chocoleitos, RamonLaC, cesarsl, drnrd, conquepoquico, hectordrums, Neuw84, bertoco, dondani96, cupralex, Octacon, pablomus85, josean-opc, davidap13, Raaz, erlanz, canijo82, MarcosRG86, Alianma, SinName, mSx, evomaoleon, BertopenST, a.cuadros71, Lumara, Gendos22, borjayadri2, litllevill, Jandrew, galelir, Josep20, borjiguez, THC77, di360, Juanjocantabria, grijan 2.0, copii92, JDMG, Morales92, nadiia.bcn93, yo_javi89, yurkli, Atajunen, carlo13, Desertcuervo, floppy666, amg129, manjerico, Franr50, iNFeCTeD, Rotemburgero, Link, kivamz, dj_ferrix, manu5, Vagabundo, aaronfdez, Manzi, Perilla, juanaco, pepetgi, pistoleromtb, cp_jj, diepecu2, Freddy169, Welmonk, JaquetónST, alrodri, LuisNM, Rekoba, bizu, ginyu 83, ephreon, rr7mo, Def89, CrisFRST5F, Mohoska, gilen44, ayl, SantiPMI, Jesús Peinado, 05kar, Lata8, Adrián pcg, Warelio, carlosVACA, trazas, barris31, danieleon, enriquevalera, antonioagui95, tito68, Sarge86, victorvOrtiz, bigpicha, ericoperico, JulinM, AlvaroRamlo, josermancol, Davidv, flotter, V de Viana, zainao, LeónST, rubiotuning, RacingSport
Notapor ertate el 14 Mar 2018, 17:53
stewei escribió:
ertate escribió:
stewei escribió:@ertate Gracias! Lo he mirado y veo que dicha captura @xagico lo tiene como desconectado, y en la descripción da la sensación de que para que haga esa función debe de estar activado. No recuerdo que MY es su golf.
En mi caso, es un MY16, pero viendo que el brico de la alarma también es compatible con MY anteriores, supongo que los MY16 tienen la misma descripción. Que extraño todo...
Si es estaño, mi coche de serie lo trae activado y probé a abrir la puerta con la llave y no salto la alarma, así que lo desactive y desde entonces si abro con la llave el comportamiento es el que se indica en el manual
@ertate ok ok, entonces puede ser que en nuestros leones sea justo lo contrario el efecto de desactivarlo. Yo lo acabo de mirar y también lo tengo activo de serie. En ese bit en su día solo activé el 0, que es el necesario para activar la alarma. ¿has hecho algún scan desde entonces por si arroja alguna unidad algún tipo de error?
Pues no lo recuerdo jejejeje esta noche lo miro y te lo digo :ok:
En este mensaje, ertate ha recibido un agradecimiento de:
stewei (14 Mar 2018, 17:54)
ertate
Agradecido: 128 veces
Notapor MORKAS el 14 Mar 2018, 18:59
Saludos de nuevo...no se si estara ya por el post...pero, se puede hacer que los espejos se plieguen de un toque, en los coches con kessy?, incluso al tocar la manilla de la cerradura y que se cierre el coche, que se plieguen tambien?, sin dejar pulsado?, gracias
MORKAS
Agradecido: 368 veces
Notapor Garret3071 el 14 Mar 2018, 19:09
MORKAS escribió:Saludos de nuevo...no se si estara ya por el post...pero, se puede hacer que los espejos se plieguen de un toque, en los coches con kessy?, incluso al tocar la manilla de la cerradura y que se cierre el coche, que se plieguen tambien?, sin dejar pulsado?, gracias
Si, es igual que con el mando. Yo lo tengo y tocando la manera de cierran
Garret3071
Notapor MORKAS el 14 Mar 2018, 19:13
Es cierto..cuando probe lo del bit 6, lo tenia activado de serie...
MORKAS
Notapor Genzo el 14 Mar 2018, 22:50
Buenas, si, yo lo tengo en el mio asi, tocas la manilla cierra el coche y pliega espejos, y luego metes la mano, abres el coche pero los espejos se abren al poner el contacto. Saludos.
Aprovecho para preguntar, como puedo saber si funciona el mod de los 4 intermitentes en frenada brusca, he intentado en una explanada pero no consigo que salten, sabeis a que velocidad hay que ir para que se activen al frenar de golpe? Gracias.
:nekora:
Genzo
Agradecido: 61 veces
Notapor MORKAS el 14 Mar 2018, 23:01
Gracias..acerca de los intermitentes..tampoco he podido probar...da un poco de yuyu..jeje...
Es decir..tu llevas el mod de lo de contacto?...he seguido las instrucciones del mod en el de un compi de curro...y no llego a ver los campos ....miraré otra vez cuando coincida
MORKAS
Notapor dRoXe el 14 Mar 2018, 23:07
Quizas debe entrar el abs para que salten
dRoXe
Agradecido: 90 veces
Notapor ertate el 14 Mar 2018, 23:24
@MORKAS @stewei he escaneado el coche y no hay fallos, a mi me da la sensación de que esa captura que hay en el PDF de @xagico es de como debe quedar una vez montada la alarma incluida los volumetricos. si te fijas ya aperece marcada la instalacion de la sirena electronica de la alarma y el sensor volumetrico. Lo malo es que creo si dejamos ese bit activado en caso de que fuercen la cerredura se desactivaria la alarma.
En este mensaje, ertate ha recibido 3 agradecimientos de:
MORKAS (15 Mar 2018, 00:10), stewei (15 Mar 2018, 06:40), XaGiCo (14 Mar 2018, 23:51)
ertate
Notapor ismiwis el 14 Mar 2018, 23:33
Hola buenas,
¿Sabéis si es posible configurar que se cierren los espejos al quitar el contacto del coche o apagarlo?
Gracias.
ismiwis
Coche: Leon MK3 1.5 TGI 130cv
Notapor joselexperience el 14 Mar 2018, 23:43
hay alguna lista de las cosas que se pueden cambiar con el OBDeleven ,por ejemplo se puede cambiar en los que tenemos el DSG el cambio de una marcha a la siguiente a unas rpm del motor algo superior,me explico,suponiendo que en D ahora hace los cambios de una marcha a otra en torno a las 2200 rpm de motor,se puede modificar con el OBDeleven que los cambios los haga a 2600 rpm ,porque todavia no tengo claro lo que se puede modificar en el coche con el OBDeleven
joselexperience
Notapor ertate el 14 Mar 2018, 23:50
joselexperience escribió:hay alguna lista de las cosas que se pueden cambiar con el OBDeleven ,por ejemplo se puede cambiar en los que tenemos el DSG el cambio de una marcha a la siguiente a unas rpm del motor algo superior,me explico,suponiendo que en D ahora hace los cambios de una marcha a otra en torno a las 2200 rpm de motor,se puede modificar con el OBDeleven que los cambios los haga a 2600 rpm ,porque todavia no tengo claro lo que se puede modificar en el coche con el OBDeleven
Al principio de este hilo (no recuerdo si en la primera o la segunda pagina) hay un listado de mods disponibles para obdeleven creado y actualizado por @miceor a fecha del 5 de noviembre de 2017
ertate
Notapor tevaadarelsol el 14 Mar 2018, 23:54
Efectivamente, se encienden al saltar el ABS, comprobado por mí
En este mensaje, tevaadarelsol ha recibido un agradecimiento de:
MORKAS (15 Mar 2018, 00:09)
tevaadarelsol
Agradecido: 199 veces
Notapor XaGiCo el 14 Mar 2018, 23:57
Buenas
Después de verificar datos y poner en práctica el caso.
Es normal.
La codificación según avanza el PDF se va completando.
A mi con el keyless hasta que no abro la puerta no empieza a sonar pero solo al abrir manualmente después del tiempo de rearmé de la Alarma.
Lo veo como un pequeño seguro para los cacos que fuerzan cerraduras.
En este mensaje, XaGiCo ha recibido 3 agradecimientos de:
ertate (15 Mar 2018, 00:16), MORKAS (15 Mar 2018, 00:10), stewei (15 Mar 2018, 06:42)
XaGiCo
Agradecido: 163 veces
Notapor ertate el 15 Mar 2018, 00:02
Buenas
Es normal.
Buenas @xagico
Entonces lo correcto seria llevar el bit 6 DESACTIVADO??
MORKAS (22 Mar 2018, 12:06)
ertate
Notapor XaGiCo el 15 Mar 2018, 00:05
Buenas
Es normal.
Buenas @xagico
Si !
ertate (15 Mar 2018, 00:16), MORKAS (15 Mar 2018, 00:13), stewei (15 Mar 2018, 06:42)
XaGiCo
