Seguidores: golf_1990, josusanchez5b, Jastur, r11ourense, MerioE, davidddgt, jose.a.llamas, gato125, Pkt, byChule, Hovig, SorianoFco, jygalvan, CubanPitbull, corderazo, israher, iDavid9669, nyro, pirulo79, Edu1589, ramargo75, javi.ferrer, kikelin, aleejandroogm, Trimmer, car212121, LeoST, Besaygf, kinipc, Rasekfighter, Romera, MartinLeon, camamaleon, Aceroinox1a, jramis, Juanquique, josele77, marlop, Peje, Pedrost, bailyibz, wiki88, teltronik, gogua, sirkez, carlosgzlez, mcecho, genialsoft, aironsam14, JoseCa, Dandy_gsi, vanscampa, Joseibz, trekam, La_jungla, jorgecrackets, aigort, msmdraven, IRO, Jorge75016, alejandro_javier, ivan0909, jmfcoto, viktor_ct_95, maxxg2, olgalberto1, danifusi, Josepo79, er_trompe, miyobe, jande, Petri, itz18, jagman, serguey79, rafapadilla93, Mate, undernok, lead, lead, csabafr2013, jluis, olmeras, LeidenSpain, osjamil, Valerofr150, flope63, Herrdoktor, pocososinos, carrasco13, pichonclv, C.reina, Daner84, inamarlo, aguscalderon, BaZZ, yujakantabro, Fonek, LARABA, juanmaroger, juanmac, Kipu, IvanMc2, garrafa2, Linker89, mihai G, Igor, bronce702, creasy1977, Gsclosada, lebowski, jaro_84, charly425, leonfr76, DBS83, joseanvazquez501, M3rs, borgio, NOCIVOX, FcoJ.M.N., VillaSB, t4alberto, lytry32.hc, david_gz, Kasky, diegol147, jasoriab, jninomo, jmiturbe, chetelopez, utopia95, Dreziel, jonatan1988, xsoldadito, Illan, Fernandoestrada, jd_zuri, Juande667, xjuliox, Bettor, solanomor01, Chinyero, volkov, braulioT, Maikermx, iNowack, D83, MORKAS, dRoXe, JaviMarquez, danitre, Davi_TGI, DiegoR, ertate, cuenka16, nicotzioras, Spok68, urbion, linxes, kukikukarron, Talnoseque, Hyperr, VapaV, jfermar, Moigijon, slyjay73, DuckToy, nachomart, Iosu21, sbarri, sebasresa, Beiró, Llisus, agus_piscis10, Action SVG, Alc16, Trivi83, eyebee, riclanico, Per3zo, Qore, lolorm, abollao, Alvi, sergi303, Xilenos, barret, Gus_Fring, malloc, TomH30, jmofcb, paco_22_22, luigi323, Chelazo, dani10s, victor david, Yeiem93, Luiggi7, Guillen222, yoflipo, nenazojuanma, nitro_g4074, Senuto, gabivvamesia, javichu312, richard_11, Yery, Ivensound, El_pelos44, rvicario76, Mr.Chuflas, subaru_3, eruizm, Gomez89, barubita, Nicoplas, javibmw, el_noi_80, kapi21, satoo, barrosdepor, camaon99, craken, Flow-Rider, Castro87, Kikedecefe, xexpir, Cristian2014mx, _Juansp, jornefra, cucci, Pablitofr, Pablitofr, Rober_SR, kevinhtbs, chocoleitos, RamonLaC, cesarsl, drnrd, conquepoquico, hectordrums, Neuw84, bertoco, dondani96, cupralex, Octacon, pablomus85, josean-opc, davidap13, Raaz, erlanz, canijo82, MarcosRG86, Alianma, SinName, mSx, evomaoleon, BertopenST, a.cuadros71, Lumara, Gendos22, borjayadri2, litllevill, Jandrew, galelir, Josep20, borjiguez, THC77, di360, Juanjocantabria, grijan 2.0, copii92, JDMG, Morales92, nadiia.bcn93, yo_javi89, yurkli, Atajunen, carlo13, Desertcuervo, floppy666, amg129, manjerico, Franr50, iNFeCTeD, Rotemburgero, Link, kivamz, dj_ferrix, manu5, Vagabundo, aaronfdez, Manzi, Perilla, juanaco, pepetgi, pistoleromtb, cp_jj, diepecu2, Freddy169, Welmonk, JaquetónST, alrodri, LuisNM, Rekoba, bizu, ginyu 83, ephreon, rr7mo, Def89, CrisFRST5F, Mohoska, gilen44, ayl, SantiPMI, Jesús Peinado, 05kar, Lata8, Adrián pcg, Warelio, carlosVACA, trazas, barris31, danieleon, enriquevalera, antonioagui95, tito68, Sarge86, victorvOrtiz, bigpicha, ericoperico, JulinM, AlvaroRamlo, josermancol, Davidv, flotter, V de Viana, zainao, LeónST, rubiotuning, RacingSport
Notapor daniani el 16 Mar 2018, 15:23
ertate escribió:Buenas.
Tal como esta descrito el mod de alarma gratis en coches sin alarma solo os saltará la alarma en caso de que os rompan un cristal y abran desde el interior pero en caso de apertura mecánica (es decir, forzando la cerradura) no saltaría. Para que salte también en ese caso tendríais que hacer lo siguiente :
Módulo 9
Codificación extendida(bytes)
Byte 12
DESACTIVAR bit 6
Y ya os saltaría en caso de forzar, pero al abrir con la llave (con el mando seguirá igual que siempre) solo se abre la puerta del conductor y tenéis 15 segundos antes de que salte la alarma para dar al contacto y para abrir las demás puertas tendréis que pulsar el botón de desbloqueo que tenemos en la puerta del conductor tal y como viene explicado en el apartado de la alarma antirrobo del manual del coche.
Hola! He estado probando (MY'17) y no me funciona, seguro que hago algo mal. Ya tenía previamente la alarma oem activada, me funciona abriendo desde dentro la puerta. He mirado en el byte 12 y solo tengo activo el bit 1, el 6 nunca lo he tocado así que está desactivado de serie.
Pruebo a abrir la puerta con la llave y se me abren todas la puertas, pero no suena la alarma al cabo de los 15 segundos que indicáis.
Veis algo mal?
daniani
Agradecido: 9 veces
Notapor ertate el 16 Mar 2018, 23:28
Módulo 9
Byte 12
DESACTIVAR bit 6
Veis algo mal?
si se te abren todas las puertas al abrir con la llave no te salta la alarma ya que el cierre centralizado la desconecta al reconocer esa apertura como voluntaria.
Es raro que en tu coche venga ya desactivado ese bit, intenta encontrar a alguien con un vagcom mas bien actual y entra con el en el modulo9, long coding, byte12 para ver si incluye la descripcion de cada bit de ese apartado y ver si coincide con la descripcion de modelos anteriores.
que solo tengas activado el bit 1 tambien es diferente al de los modelos mas antiguos que (por lo enos hasta donde yo conozco) lo suelen traer desactivado de serie y si n o traes alarma solo tiene activado el 6.
estas seguro de que has entrado en el byte correcto????
ertate
Agradecido: 128 veces
Notapor daniani el 16 Mar 2018, 23:39
Módulo 9
Byte 12
DESACTIVAR bit 6
Veis algo mal?
Cuando he dicho bit 1 me he equivocado quería decir el primer bit, que ahora veo que es el bit 0. Por defecto todos venían desactivados, solo activé el bit 0 para activar la alarma mediante obd.
He probado también modificando para que solo se abra la puerta del conductor (imagino que te refieres a eso) y tampoco suena.
Volveré a intentar y revisar todo por si hay algo mal.
Gracias por la ayuda
daniani
Agradecido: 9 veces
Notapor ertate el 17 Mar 2018, 00:48
daniani escribió:
Módulo 9
Byte 12
DESACTIVAR bit 6
Veis algo mal?
a lo que me refiero es que al desactivar el bit 6 ya no se abren todas las puertas al abrir desde el bombin de la puerta, o por lo menos ese es el comportamiento que tiene en el MY15 y es el comportamiento que se describe en el apartado de la alarma en el manual del coche.
creo que seria interesante ver la descripcion de los bit de tu centralita para ver si los han cambiado o modificado el orden en el que aparecen y actuar ahi viendo que es lo que se esta tocando.
ertate
Notapor visen3 el 20 Mar 2018, 11:58
Hola buenas
Tengo un amigo con un Leon mk3 sport Fr Aut. al que le he hechos varias mods con obdeleven, las siguientes:
Alarma gratis claxon
Aceleracion directa
cambio fondo pantalla carbono
Espejos cierran automaticamente al cerrar el coche
Espejo derecho baja con marcha atras
VIM
y ahora me dice que tiene un problema, y es que cuando se pone en marcha y el coche bloquea las puertas automaticamente con el cierre centralizado no puede bajar la ventanilla del copiloto a no ser que desbloquee el cierre centralizado.
A alguien mas le ha pasado, se sabe a que se debe, y cual es la solucion?
gracias
visen3
Notapor stewei el 20 Mar 2018, 13:04
@visen3 Pues lo suyo es que quedes con tu amigo, le hagas una diagnosis al coche y verifiques qué unidades están dando problemas y qué problemas. Una vez lo tengas claro, postéalos aquí a ver si te podemos echar una mano.
En principio, es la primera vez que escucho este tipo de error. ¿puede que se le haya desconfigurado la apertura confort?
Ya nos contaras,
Un saludo :ok:
stewei
Agradecido: 465 veces
Notapor Papa_Het el 20 Mar 2018, 14:25
Buenos días a todos,
En primer lugar agradecer al autor y colaboradores de éste hilo, es un currazo y nos ayuda mucho a todos los pardillos que empezamos con esto del obd eleven.
Yo tengo una duda: Soy incapaz de activar el coming home/leavin home, lo intente con vag com, ahora con obd eleven y nada...he comprobado que todos los apartados de iluminación de comfort estén activados correctamente, he reseteado de fabrica la iluminacion desde infotainment y nada. Comentar que consegui algo parecido con vag com diciendole al coche las luces que queria que se comportaran como luz interior y funcionó (luego volvi a ponerlo todo en su sitio), pero querria activarlo correctamente, para poder ponerle los segundos y modificarlo a mi gusto.
Os comento que en el menu de la radio me salen los segundos del ch/lh pero no me sale ninguna opcion para activarlo o desactivarlo.
Mi coche es un Leon x-perience 1.8TSI, DE 2015.
A ver si me puede echar alguien un cable, gracias de antemano.
Papa_Het
Notapor Trimmer el 20 Mar 2018, 14:38
buenas, llevo un tiempo con estos fallos que borro pero siguen saliendo, alguna idea de por donde pueden ir los tiros? tengo configurados los 5 destellos en modo confort, referente a intermitentes solo tengo lamparas leds traseras pero el coche no marca nada de lampara fundida, por cierto es un octavia my16ImagenImagen
Trimmer
Notapor Gerni9 el 20 Mar 2018, 15:01
Hola buenas. Que vaya por delante que he buscado en el buscador y no me ha salido ningún resultado. Me gustaría saber cómo se hace el Mod de test de agujas para un Leon mk1 del 2005. Es para un compañero del curro que le gusta lo de las agujas jejejej. Gracias.
Gerni9
Notapor cvillajos el 20 Mar 2018, 15:14
Gerni9 escribió:Hola buenas. Que vaya por delante que he buscado en el buscador y no me ha salido ningún resultado. Me gustaría saber cómo se hace el Mod de test de agujas para un Leon mk1 del 2005. Es para un compañero del curro que le gusta lo de las agujas jejejej. Gracias.
Pues no estoy 100% pero creo que el MKI no tiene esa opción :roll: Solo a partir de MKII (y no todos)
De todas formas si conoces los pasos (aunque sea con otro interfaz, como VagCom, por ejemplo) solo es cuestión de traducir a pasos OBDeleven.
Gerni9 (20 Mar 2018, 15:17)
cvillajos
Agradecido: 3572 veces
Notapor cvillajos el 20 Mar 2018, 15:19
Trimmer escribió:buenas, llevo un tiempo con estos fallos que borro pero siguen saliendo, alguna idea de por donde pueden ir los tiros? tengo configurados los 5 destellos en modo confort, referente a intermitentes solo tengo lamparas leds traseras pero el coche no marca nada de lampara fundida, por cierto es un octavia my16[ Imagen ][ Imagen ]
Si has puesto las LED a posteriori (y aunque no te dé aviso de luz fundida) prueba a cambiar el tipo de luz en los canales de adaptación de los intermitentes y/o su regular su intensidad.
Si no ya sería cuestión de mirar la instalación. Creo yo...
cvillajos
Notapor Trimmer el 20 Mar 2018, 15:21
el tema que intermitente lateral son de los espejos y ya son leds de por si
Trimmer
Notapor Gerni9 el 20 Mar 2018, 15:25
Creo haber leído a alguien que lo consiguió adaptando los módulos del Vagcom al Obdeleven pero no estoy seguro. Hace tiempo que no entraba en el post y madre mía 314 páginas... como para leer todas :shock: a ver si alguien lo ha conseguido o lo sabe.
Gerni9
Notapor M3rs el 22 Mar 2018, 04:08
teltronik escribió:
M3rs escribió:
teltronik escribió:
M3rs escribió:
cvillajos escribió:
M3rs escribió:
Pero tengo desactivado lo del navegador...y el error me persiste mirare en el historial imagino que observando las modificaciones tengo q encontrar alguna que no se ha vuelto a dejar como estaba no? Si pongo restaurar estoy haciendo q todo lo que en su dia hice vuelva a su lugar?
Ahora mismo he bajado y me encontrado con varias modificaciones pero no me especifica como otras pongo alguna de ellas .
NO le des a restaurar o puedes tener problemas posteriormente: viewtopic.php?f=40&t=121684&hilit=Reset
La manera de deshacer un cambio es revisando el historial y cambiando a mano. Alguna modificación de LongCoding no habrás revertido correctamente o no te la habrá aceptado si no te has logado con el Security Access.
Pues menos mal he estado a nada de darle....
Longcoding que es eso? Hay cosas que me dice que son en el historial como cuando quisenponer el off road pero todos esos numeros no me dice nada en su dia toque y ni recuerdo que modificacion podria estar haciendo ya ves la fecha... imagino q a todo esto tampoco es un problema no? Para itv ?
Gracias por el tiempo ehh! Soy un pez nuevo para esto y me lanze al ver que todo esto era tan fácil... jajaja
Eres de barcelona?
Si soy de barcelona
ahora e estado trasteando otra vez y paso de arriesgarme mas hace un momento ya ni me dejaba apagar la radio ! No toco nada más q la lió jajaja
Si quieres yo stoy en san boi!!!y miramos
Pues me harías un favor! Como puedo contactar contigo teltronik???
M3rs
Notapor jasoriab el 22 Mar 2018, 12:42
En la última beta que han actualizado hoy, versión 0.9.3.0 de la aplicación por fin han solucionado el problema del envío del historial con dispositivos Android 8.x vía correo, Drive, etc.
Probado en mi móvil, con Android 8.1, y ya por fin vuelve a funcionar esta utilísima opción.
En este mensaje, jasoriab ha recibido 4 agradecimientos de:
DVD_1982 (22 Mar 2018, 13:02), MORKAS (22 Mar 2018, 19:15), Petri (23 Mar 2018, 07:38), stewei (22 Mar 2018, 19:12)
jasoriab
Agradecido: 2019 veces
