Favoritos: CrAfTy, neraka, fegavo, guirimg, El_Peyote, ositoerik, titosmart, VÍBORAfjvl, davix16, dmesanun, frhedie, tuning_69, gark81, rafaseten, Gerni9, hctlp, pocososinos, Maxpako, trakasjesus, blankiblau, luis77, Vilo, NikolaieV, crujipoyo, marcosgumiel, cvillajos, mikomiko, jorgecrackets, FrA1l3, Ucralek, juanpeeisafr, PwrDwnSys, Xperience, hectordrums, kossel, Myvodoo, estepi, Sdocid, JoRoGe, Mate, javieret69, dmejias, -alberto-, ferre7, Will Wallace, davrolo, Koltrix, Lotar, Jkirk, javierpg1990, Alleya, jafeor, Qore, Kasky, Dreziel, jotavc, craken, tonnety, Coabil, solnauj, jajereal, PabloAthletic, Peje, Trivi83, jordi-duck, dani10s, PULIDIN PULIDO, damsolu, Leoncity, Pepeulo, pantufle, barrosdepor, pepetgi, ManuelC, frigolin, jpmartinez, danihd, kapi21, ralebo, Bass8V, Juanjocantabria, _Juansp, lagucam, ISMAEL.K, gogorios, Piro25, toniRG, Warelio, JMR9, davidvalt, Jastur, imvand, LEMY69, CofKa, debian, theoldboy, charly425, pistoleromtb, Chinyero, rob3r7o, daviid_trivi, AbelR, javi.ferrer, Eibol, dct, amarvalbu, jevi19, Ralux, Ibiza.elbudi, CrisFRST5F, ericoperico, Serranolera
Seguidores: golf_1990, josusanchez5b, Jastur, r11ourense, MerioE, davidddgt, jose.a.llamas, gato125, Pkt, byChule, Hovig, SorianoFco, jygalvan, CubanPitbull, corderazo, israher, iDavid9669, nyro, pirulo79, Edu1589, ramargo75, javi.ferrer, kikelin, aleejandroogm, Trimmer, car212121, LeoST, Besaygf, kinipc, Rasekfighter, Romera, MartinLeon, camamaleon, Aceroinox1a, jramis, Juanquique, josele77, marlop, Peje, Pedrost, bailyibz, wiki88, teltronik, gogua, sirkez, carlosgzlez, mcecho, genialsoft, aironsam14, JoseCa, Dandy_gsi, vanscampa, Joseibz, trekam, La_jungla, jorgecrackets, aigort, msmdraven, IRO, Jorge75016, alejandro_javier, ivan0909, jmfcoto, viktor_ct_95, maxxg2, olgalberto1, danifusi, Josepo79, er_trompe, miyobe, jande, Petri, itz18, jagman, serguey79, rafapadilla93, Mate, undernok, lead, lead, csabafr2013, jluis, olmeras, LeidenSpain, osjamil, Valerofr150, flope63, Herrdoktor, pocososinos, carrasco13, pichonclv, C.reina, Daner84, inamarlo, aguscalderon, BaZZ, yujakantabro, Fonek, LARABA, juanmaroger, juanmac, Kipu, IvanMc2, garrafa2, Linker89, mihai G, Igor, bronce702, creasy1977, Gsclosada, lebowski, jaro_84, charly425, leonfr76, DBS83, joseanvazquez501, M3rs, borgio, NOCIVOX, FcoJ.M.N., VillaSB, t4alberto, lytry32.hc, david_gz, Kasky, diegol147, jasoriab, jninomo, jmiturbe, chetelopez, utopia95, Dreziel, jonatan1988, xsoldadito, Illan, Fernandoestrada, jd_zuri, Juande667, xjuliox, Bettor, solanomor01, Chinyero, volkov, braulioT, Maikermx, iNowack, D83, MORKAS, dRoXe, JaviMarquez, danitre, Davi_TGI, DiegoR, ertate, cuenka16, nicotzioras, Spok68, urbion, linxes, kukikukarron, Talnoseque, Hyperr, VapaV, jfermar, Moigijon, slyjay73, DuckToy, nachomart, Iosu21, sbarri, sebasresa, Beiró, Llisus, agus_piscis10, Action SVG, Alc16, Trivi83, eyebee, riclanico, Per3zo, Qore, lolorm, abollao, Alvi, sergi303, Xilenos, barret, Gus_Fring, malloc, TomH30, jmofcb, paco_22_22, luigi323, Chelazo, dani10s, victor david, Yeiem93, Luiggi7, Guillen222, yoflipo, nenazojuanma, nitro_g4074, Senuto, gabivvamesia, javichu312, richard_11, Yery, Ivensound, El_pelos44, rvicario76, Mr.Chuflas, subaru_3, eruizm, Gomez89, barubita, Nicoplas, javibmw, el_noi_80, kapi21, satoo, barrosdepor, camaon99, craken, Flow-Rider, Castro87, Kikedecefe, xexpir, Cristian2014mx, _Juansp, jornefra, cucci, Pablitofr, Pablitofr, Rober_SR, kevinhtbs, chocoleitos, RamonLaC, cesarsl, drnrd, conquepoquico, hectordrums, Neuw84, bertoco, dondani96, cupralex, Octacon, pablomus85, josean-opc, davidap13, Raaz, erlanz, canijo82, MarcosRG86, Alianma, SinName, mSx, evomaoleon, BertopenST, a.cuadros71, Lumara, Gendos22, borjayadri2, litllevill, Jandrew, galelir, Josep20, borjiguez, THC77, di360, Juanjocantabria, grijan 2.0, copii92, JDMG, Morales92, nadiia.bcn93, yo_javi89, yurkli, Atajunen, carlo13, Desertcuervo, floppy666, amg129, manjerico, Franr50, iNFeCTeD, Rotemburgero, Link, kivamz, dj_ferrix, manu5, Vagabundo, aaronfdez, Manzi, Perilla, juanaco, pepetgi, pistoleromtb, cp_jj, diepecu2, Freddy169, Welmonk, JaquetónST, alrodri, LuisNM, Rekoba, bizu, ginyu 83, ephreon, rr7mo, Def89, CrisFRST5F, Mohoska, gilen44, ayl, SantiPMI, Jesús Peinado, 05kar, Lata8, Adrián pcg, Warelio, carlosVACA, trazas, barris31, danieleon, enriquevalera, antonioagui95, tito68, Sarge86, victorvOrtiz, bigpicha, ericoperico, JulinM, AlvaroRamlo, josermancol, Davidv, flotter, V de Viana, zainao, LeónST, rubiotuning, RacingSport
Notapor MORKAS el 24 Jun 2018, 14:31
levorg escribió:
MORKAS escribió:Hola, saludos compañeros,no se si se habra comentado ya por algun sitio del foro, pero, os habeis dado cuenta, de que en ciertas centralitas electronicas (BCM), modulo 09, en los ultimos modelos, cuando haces algun mod, o haces una copia de seguridad, la codificacion extendida, modo bytes, esta toda en "0"?, sin embargo, si que te deja modificar bits...no es raro?, sera cosa del obd11?, aunque ocn VCDS u otro soft tambien le pasa....
Es un poco molesto ,pues, siempre puedes recuperar una cnfiguracion, copiando y pegando esa codificacion, en mi coche, asi lo hago, y sin problemas, pero en estas ultimas BCM, no se puede entonces?. gracias
A mi me paso al activar la alarma OEM. La verdad es que acojona un poco tocar cuando toda la codificación aparece con ceros, pero bueno, te apuntas lo que has tocado para deshacerlo en caso necesario y listo!
Si..bueno..en historial salen los cambios...pero seria bueno restaurar de una vez copiando el coding total....
MORKAS
Agradecido: 368 veces
Notapor dRoXe el 25 Jun 2018, 01:33
levorg escribió:
Escribano escribió:Hola buenas yo queria hacer una pregunta que no he visto si esta por algun lado me podriais ayudar?
Lo que quiero saber es mi leon es MY17 y tiene freno de mano electrico queria saber si con el obdleven se podria retraer los embolos para poder cambiar las pastillas. O me tendria que comprar un vagcom.
Si que se puede mediante aplicacion (consume créditos) llamada "brake pads replacement".
Supongo que investigando dentro del módulo de frenos se podrá encontrar la adaptacion/codificacion equivalente, pero eso ya lo desconozco.
En el segundo mensaje en el que estan todos los mods, puedes encontrar para hacerlo manualmente
Esta en los mods de apartado mecánica
Aqui tienes
Abrir/Cerrar embrague Haldex (Mecánica)  Todos los modelos
Activándolo se abren las pinzas y una vez cambiadas puedes volver a cerrarlas.
1 - Módulo 03 - Electrónica de los frenos. Code (40168/20103)
2 - Ajustes básicos
3 - Abrir embrague Haldex
4 - Embrague Haldex cerrar -- No activado (Por defecto)
dRoXe
Agradecido: 90 veces
Notapor lafu1988 el 25 Jun 2018, 08:56
Aqui tienes
2 - Ajustes básicos
Para los que tenemos freno de mano manual, funciona? No,verdad?
lafu1988
Agradecido: 217 veces
Notapor dRoXe el 25 Jun 2018, 09:41
Aqui tienes
2 - Ajustes básicos
No, ya que vuestros frenos son mecanicos completamente
dRoXe
Notapor miceor el 25 Jun 2018, 15:58
Funciona en cualquiera de los casos. Una cosa es el freno de mano y otra el sistema general de frenos.
Funciona tanto el cambio de pastillas como la purga de liquido de frenos.
Todos llevan el sistema electrónico preparado para ello, tanto es así que por ejemplo la función de secado de frenos por ejemplo realiza una aproximación de las pastillas a los discos cada vez que arrancas el coche, al igual que el sistema de asistencia en pendiente activa los frenos posteriores cuando así se requiera sin la intervención de l conductor sobre el pedal del freno.
miceor
Agradecido: 1256 veces
Notapor lafu1988 el 25 Jun 2018, 18:16
miceor escribió:Funciona en cualquiera de los casos. Una cosa es el freno de mano y otra el sistema general de frenos.
Bueno saberlo y más confirmarlo de la mano de @miceor. Muchas gracias.
Los cambios de pastillas será coser y cantar.
lafu1988
Notapor fernan34 el 26 Jun 2018, 01:03
chicos ¿nadie sabe como hacerle el ajuste básico al cuadro de instrumentos? me da por saco ver el fallo ahi siempre que le paso el obd11, tambien me aparecen otros 2 de datos predictivos del trayecto, que tras borrarlos, vuelven a aparecer al poco tiempo.
fernan34
Notapor MORKAS el 26 Jun 2018, 01:07
fernan34 escribió:chicos ¿nadie sabe como hacerle el ajuste básico al cuadro de instrumentos? me da por saco ver el fallo ahi siempre que le paso el obd11, tambien me aparecen otros 2 de datos predictivos del trayecto, que tras borrarlos, vuelven a aparecer al poco tiempo.
Todavia no entiendo porque has de hacer ajustes del cuadro..es que lo has cambiado o algo?..y los datos predictivos, seran esporadicos..posiblemente de algun mod que hayas hecho....señales quizas?..:-/
MORKAS
Notapor fernan34 el 26 Jun 2018, 15:46
joer, es que al haberlo comprado de 2a mano, a saber lo que activo el elemento. lo de las señales lo lleva si, pero no se si eso venia de serie o no.
fernan34
Notapor MORKAS el 26 Jun 2018, 15:54
fernan34 escribió:joer, es que al haberlo comprado de 2a mano, a saber lo que activo el elemento. lo de las señales lo lleva si, pero no se si eso venia de serie o no.
Lo de las señales..si es del 2015 o 2014..no habia ese extra.
MORKAS
Notapor cvillajos el 26 Jun 2018, 16:04
Muy pocos Leones vienen con las señales de tráfico activadas de fabrica porque es necesaria una configuración muy concreta de extras y packs que casi nadie coje. Lo mas seguro es que lo activase a posteriori.
Lo raro son lo de los fallos: En el FIS nos sale a casi todos el error de "Faltan datos" (algunos privilegiados con una A5 con referencia concreta no lo tienen y otros con parametrizaciones tampoco), pero de errores en la centralita ni rastro.
Puede que lo configurase mal en su día y tengas esa "herencia".
Busca y compara en el censo de centralitas las A5, 5F y 17 de alguien con tu misma configuración y señales activadas para ver si hay algo diferente (al menos en lo relativo a esta funcionalidad).
viewtopic.php?f=8&t=120732
cvillajos
Agradecido: 3575 veces
Notapor fernan34 el 27 Jun 2018, 05:45
muchas gracias, haber si doy con la tecla...
fernan34
Notapor Paliciu el 27 Jun 2018, 14:34
Paliciu escribió:Buenas!! Hice copias de seguridad...y ahora no las encuentro :zoquete: si alguien con mi modelo tiene la configuración base me la podría pasar??
Encontrada la copia de seguridad, lo que no sé es como subirlo a la biblioteca... (No vi ningún modelo como el mío)
Tengo una duda, tengo que ir metiendo uno a uno los parámetros o puedo meter directamente todo a la vez para dejarlo "de fábrica".
PALICIU - 2.0 TDI FR ADVANCE 184CV KIT AERO COMPLETO viewtopic.php?f=43&t=118879
Paliciu
Agradecido: 26 veces
Notapor Rmormol el 27 Jun 2018, 15:59
levorg escribió:
Chelazo escribió:Disculparme pero alguien me sabría decir el correo para ponerme en contacto con los de OBDELEVEN gracias
Correo no sé si tienen, pero puedes intentar contactarles
por facebook https://m.facebook.com/obdeleven.
Además, a través de la aplicación tienes un apartado de ayuda con un montón de FAQs (dentro de ese apartado hay como una especie de chat en el que puedes preguntar cosas pero no estoy seguro de si contesta un bot o una persona).
Contestan personas a mi me contestaron por ese apartado de ayuda
Última edición por cvillajos el 27 Jun 2018, 16:01, editado 1 vez en total
Razón: Edición quotes
Rmormol
Notapor cvillajos el 27 Jun 2018, 16:01
Lamentablemente uno a uno, no hay funcionalidad de "cargar de golpe" todo un backup o algo así...
Sobre la copia de seguridad, pues súbela... Luego ya @stewei o @javigody verán si vale o no el formato o si tienes que ajustar algo. Lo importante es la info que vaya dentro, que le pueda servir a otro compi "en problemas".
cvillajos
Usuarios navegando por este Foro: Google [Bot], SentiBot y 6 invitados
