León Mk3 - Actualización infotainment
- Seguidores: 183
- Favoritos: 41
- Vistas: 572.466
Favoritos: BADS, Daruma, ositoerik, dmesanun, YeSL, pocososinos, jasoriab, JaviMarquez, crujipoyo, Arkan7, Cristianibias, pepeiyo69, Angel J, Xaggy, edumachuca, abollao, -alberto-, Rickymax, ferre7, Pedritoleon, Rivesgti, Alleya, davidalba, Xiguito_Corito, craken, JDCLEONFR, nemura, danihd, cenkkaya, Kisszabo, castell_lkpg, pistoleromtb, Raulportela, Martelinko, albert_naga, Adrian Anton, Gravilhas75, chaiser, popez, ruli68, denniisg2000
Seguidores: kenny_fonseca, ncx, Lavadora, juancete, jesusFR, Hysteria, MaximusRoco, Manu1986, Jorge75016, davidbj, bIxu, miyobe, MORKAS, aironsam14, jramis, kimudj, Maikermx, Javizormo, gogua, Melonkid, Kikote8, maxinew, aigort, carlosgzlez, corderazo, Lionxp, jande, Edu1589, msmdraven, Arkan7, jeroc, inamarlo, edumachuca, Josepo79, lead, camamaleon, davidmd, carrasco13, clavelstreet, mikomiko, josele77, car212121, itz18, golf_1990, LeidenSpain, vecnte, Andy_G, csabafr2013, leonfr76, Trimmer, genialsoft, Enerts, leonfrrojito, Horus, paco_22_22, ruben88, Valerofr150, molvi_mabad, Pekee69, Dav2k6, IbiFR, il_munyo, craken, ruben91mad, papo-182, el_padrino, zeratul, kaiserssosse, lytry32.hc, sbarri, ghitus, DesmoSimon, ruli68, Mramos1985, tonielfilas, braulioT, davidalba, JaviMarquez, osjamil, egarense69, fexposru, Pedrost, Illan, chetelopez, juanacho21, cuenka16, pepeiyo69, VapaV, balbu, juan7777, mams69, Helrique, Kike77, volkov, jluis, loeches, Tom70, Dconnect, Trivi83, MilleMiglia, linxes, sergi303, hector37, D83, quiquito30lv, ElFon, DALOFER17, davidap13, kigua, JOTTA, Senuto, jd_zuri, Alvi, damsolu, Leon pucelano, javi_archi, danihd, alcoleazgz, miguel23and, xarlio, jdieztec, mitxuni, Kisszabo, Gendos22, xexpir, canijo82, Brandenor, cenkkaya, kennit0, Chelazo, bertoco, benitogomez, carlosVACA, Peje, NOECUBI1, AAAJDA, trazas, martija, borjiguez, JoseXS, ferbarroso14, Wespa, Cloud_ganora, Berbe15, Valengti, Chrohu, Atajunen, Victorzabal, jrm82, carlo13, iNFeCTeD, paralaxon, ateopoeta, pepo55, ribasxisco, Raulribarroja, ivanti, lopezm0, Rubén Flp, Warelio, Vagabundo, Rekoba, Octacon, matiaso, Alianma, Raulportela, Éugen91, Rivesgti, Mcm90, DaniR86, Gravilhas75, JuanNur78, el_Asturiano, Mr.Chuflas, albert_naga, juanfrancia, Seket, algabe, pistoleromtb, ebcuatro, [GuErRa], Mario Leon, tito68
Re: Actualización infotainment
hola para actualizar el infotainment he mirado y tengo el hardware:H24 y el software:0241. Puedo hacer la actualizacion sin problema? necesito tambien OBD para corregir problemas? gracias
sergiofr78 - Nuev@ por aqui
Hello,
Sorry I do not speak Spanish. Probably the answer is in the thread
I have a HW041 but with a screen 6.5"(Pack navigation PRO) ... Witch one should I used?
Thank you and sorry again for this question.
Gizmo - Nuev@ por aqui
Alguien que me pueda echar una manilla por favor.
He actualizado mi Infotaiment a version 897 mi unidad HIGH y el menu SETUP del clima no sale el salpicadero y en el menu car sale un leon 5 puertas y no un ST FR como el mio.
Alguien que sepa como arreglarlo con VAGCOM?
Saludos y gracias,
Saludos y gracias,
abollao - Nuev@ por aqui
Muchisimas gracias
Lo del mirror link ya lo tengo solucionado
lo que no entiendo es donde tego que ir para configurar ese 3-7-3
fito escribió:Esto lo colgue en otro hilo y viene a ser el resumen de lo mismo
si que es cierto que para cambiar la apariencia del coche la conbinacion es 3-7-3 y yo tuve que poner 3-7-2
Solucionado , gracias cvillajos
Desinstale todo con cache incluido e instale denuevo y me costo dos veces y a la tercera funciono
Pantalla cambiada a 8 "
Actualizado infotaiment ok , o eso creo .... JAJAJA
Asi que error 1555 borrado . modo ingeniero activo , ...
Ahora tengo que activar el Mirror link , el VIM , y el menu del clima en el infotaiment que no sale pero eso creo que puede ser por las unidades , ... , lo estoy mirando
Con OBDeleven :
Modulo 5F
- Vehicle configuration -- Opciones
----- Mirror_link -- (Function off_HMI off)
Cambiarlo a Function On_HMI On
Si no os deja cambiarlo, entramos a Cambiar sesión dentro de la 5F y cambiamos a Modo desarrollador.
Cuando aparezca de nuevo en pantalla, reiniciar el Infotainment para que lea los parámetros nuevos.
Trosk - Nuev@ por aqui
aprietatuercas1974 escribió:Tomy61 escribió:num. de pieza 5QA035824
HARD: H24
SOFW: 0245
CODEC 2101.0.0.10
esto se puede actualizar a algo mejor? este no es 5f
esta es una std con version 0245
insisto en los interesados se pongan en contacto conmigo por m.p para hablar el tema,unos cuantos usuarios ya estan al dia
yo tengo este mismo problema y no me sale la versión del navegador en la informacio del avegador del leon
jesus19811leonst - Nuev@ por aqui
Me quedo por aquí recabando información. Gracias.
JOTTA - Aqui + que con la novi@
- Agradecido: 55 veces
abollao escribió:Hola,
Saludos y gracias,
Ese si es un tema extraño..a ver si alguien sabe arreglarlo...has probado a encender el clima con la rueda de velocidad?, te saldrá el circulito en medio de la pantalka, de color amarillo..si lo tocas...creo que te aparecera el salpicadero...
- Agradecido: 368 veces
MORKAS escribió:abollao escribió:Hola,
Saludos y gracias,
Este tema está super explicado desde los inicios de las actualizaciones, hay que leer un poquito
Lo tienes aqui: viewtopic.php?f=9&t=118140&start=600#p1928908
Te lo resumo, pero mirate bien mirado el post anterior que te he indicado.
OTROS FALLOS Y ERRORES
Si ves que la figura de tu coche en la sección CAR no se ajusta a lo que deberia de salir (Otro formato de coche) y además en la sección SETUP del climatizador no te aparece el gráfico o en el OPS.
Lo puedes solucionar de la siguiente manera:
En el módulo 08:
Codificación Modo Texto
Derivado del vehiculo --- (Cambiar a OFFROAD)
Techo ---- (Cambiar a Panorámico)
Luego en el módulo 5f
Car_derivate --- (Cambiar a 3)
Resetear ajustes de System y Car y reiniciar el Infotainment.
Esto es para un modelo ST, para otros probar otras combinaciones.
- Agradecido: 1256 veces
Hola
¿Dónde puedo encontrar el último firmware para MIB2 6.5?
klez - Nuev@ por aqui
Disculpas..error de novato..jijiji
miceor escribió:MORKAS escribió:abollao escribió:Hola,
Saludos y gracias,
En el módulo 08:
MORKAS escribió:Disculpas..error de novato..jijiji
Saludos y gracias,
En el módulo 08:
Con VAGCOM no tuve manera de solucionarlo, he tenido que comprar ODBEleven y ahora esta funcionando.
A todo esto estuvo echandome un cable @javigody.
Gracias por contestar.
miceor escribió:MORKAS escribió:Disculpas..error de novato..jijiji
Pues siento decir, que ese metodo ami , no me funciona..algo raro debo de tener en la unidad.jejeje
snaky90 escribió:Del Hardware: H31 / Software: 0363 veo que en el hilo no se comenta nada ¿alguno por casualidad que tambien tenga ese?
Yo también tengo ese S/H
Alguien sabe si se puede actualizar? Gracias
Mei - Primeros Pasos
- Agradecido: 11 veces
Hola!
Tengo el siguiente infotainment (adjunto foto), imagino que la última versión disponible para que actualicemos es la que ha puesto el compañero en la página 41, o han sacado alguna nueva actualización?
Un saludo y gracias!
tram_R - Nuev@ por aqui
SEAT Leon 1.0 TSI S&S Style XS 81 kW 110CV Foro: Presentaciones Autor: Waltry Respuestas: 0 |
León Cupra 290 Foro: Presentaciones Autor: Beet Respuestas: 2 |
