Accesorios aliexpress mk3
- Seguidores: 160
- Favoritos: 30
- Vistas: 432.054
Favoritos: ositoerik, ROBERTO206, Stealnick, asaltacunas, tsi125, Alleya, Qore, tonnety, Juantxu, mk3Granaino, dani10s, damsolu, clotza, Levanius, pjdelburgo, frigolin, drnrd, Bass8V, Joali, toniRG, Jastur, morat86, _warcry_, Nikobellic, Lopagan666, Lyern, basuvi, rob3r7o, Lady, Danisisa_cupra
Seguidores: jose007dt, adri.f1, adrii18600, IronTor21, toniespejolara719, Hovig, trazas, drnrd, Chuskon, ecolibra, Gus-Gus, suarez22, TomH30, danone10, viktor_ct_95, pozyano, ChusTj, kennit0, Lopess85, er_trompe, rfaus, Gsclosada, djcastle, sergi303, DBS83, Ivensound, Hectoor57, JoseDel, agus_piscis10, jagman, warcryrivas, carrasco13, Triple R, luigi323, digital77, PuertoLeon, El Gonzo, LeonComeIbiza, dRoXe, osjamil, xjuliox, Per3zo, dPintos, VapaV, Igor, kukikukarron, Sanz, fur, chisyelamos, diegoporta97, carlosgzlez, leonfr76, smpxque, inamarlo, R1k4rd0, iviHDR, Moigijon, jd_zuri, surgeon, mk3Granaino, jajereal, ncx, juancete, Pokayoke, Jorge75016, DESMOCHEEE!!!, Guillen222, V de Viana, D83, riclanico, tonnety, lead, rrttrr, CuPra3004Drive, jguirao, Brandenor, triguero, Pedrost, perikolu, Alvi, Edu1589, victor david, aironsam14, Chema Sat, Josepo79, Senuto, sesmero87, Rapiru, Sergt, Llisus, richard_11, vanscampa, nifer, BEDIA, SantiagoSanchez, nachomart, quimiko, barrosdepor, Eohn94, Flow-Rider, puskas65, Snooker83, Angeleitor, Morales92, Rober_SR, Piro25, cucci, RamonLaC, erlanz, Raaz, DiegoR, Brunozp, Fofio, pablomus85, kwatto, msmdraven, iNFeCTeD, MartinLeon, antelo85, Maikermx, josean-opc, El_pelos44, Mr.Chuflas, SantiPMI, Chrohu, LuigiVisio, joga, Atajunen, lafu1988, daniel.velarde77, galelir, rpv, tsi125, Link, jose.a.llamas, eyebee, D.Acuña, Manzi, bluesbreaker88, Lady, higuerashxc, Warelio, St17, carlitos24, ginyu 83, Jastur, talanito, victorvOrtiz, Alf68, AlvaroRamlo, Yagadri, ebcuatro, MaNDuN, Davidv, Andertxu7, garruz666, antoniofdezpas, josearillaperez., MaximusRoco, ezanchi
Re: Accesorios aliexpress mk3
Muchas gracias compañero , mañana pondré la cinta de doble cara, tengo la clásica blanca....
ALRID79 - Asidu@ en la selva
- Agradecido: 13 veces
Si ves que es muy fina ponle más de una capa. En mi caso puse solo una por que la que yo tenia era gordita. Le puse tanto en la parte superior como en la inferior
Chimguy - Leoner@ avanzad@
- Agradecido: 76 veces
ALRID79 escribió:Hola compañeros, me llegaron los chismes estos del aire, el problema es q no me pegan y caen, los pegasteis con algo especial vosotros?
Perdonad la ignorancia, pero no consigo saber dónde se se colocan esas piezas
nifer - Primeros Pasos
Debajo de los asientos.nifer escribió:ALRID79 escribió:Hola compañeros, me llegaron los chismes estos del aire, el problema es q no me pegan y caen, los pegasteis con algo especial vosotros?
- Agradecido: 354 veces
Son para cubrir los aireadores traseros que van al aire , justo debajo de los asientos delanteros vistos desde los asientos traseros
Hola, quedan perfectos como me dijiste ,cinta arriba y abajo, con el grosor q puse valió una capa, muchísimas gracias ahora a esperar el resto de cositas.... hoy pedí esto...
Los tapones fr claro.... me gustan negros con la llanta q tiene el limites Edition q tiene negro también....
Por cierto , ya podían hacer también los chinos el portagafas de la guantera....10 euros lo veo exagerado
Que son lo de las últimas dos fotos?ALRID79 escribió:Hola, quedan perfectos como me dijiste ,cinta arriba y abajo, con el grosor q puse valió una capa, muchísimas gracias ahora a esperar el resto de cositas.... hoy pedí esto...
osjamil - Asidu@ en la selva
- Agradecido: 19 veces
El aro de aluminio rojo y brillante denoche va pegado en el arranque para proteger de rayazos ..., tb los hay de aluminio solo, os otros son tapones negros de las ruedas .... con el fr
ZiFFeL escribió:Compré un cable USB - USB Con qué va perfectamente, pero al ser L en ambos lados me deja el otro USB inutilizado, alguno que hayáis comprado que lleve la L al otro lado o que sea L sólo de la parte USB C?
El cable tipo c acodado no tiene izquierda o derecha,puedes conectarlo de las dos formas,no tienesolo un sentido para conectsrlo si no k puedes conectarlo de los dos lados igualmente
leon 2.0 tdi cr 110kw (150cv) start/stop fr plus 2018
litri59 - Nuev@ por aqui
fernandomg escribió:Mr.Nobody escribió:[ Imagen ]
Muy buena idea , ya vienen volando las pegatinas. Tengo pendiente que esta semana que viene me pinten las pinzas de freno (y se vaya un poco este calorazo) y me pongo con todas las cosillas que ya he ido comprando antes de que me llegara el coche.LEANOSPA escribió:PROTECTOR BISAGRA PUERTA
https://es.aliexpress.com/item/Door-Sto ... 63c0leSZVx
Otra cosa que buscaba y que es muy útil a largo plazo. Pa casita!LEANOSPA escribió:LUCES AL ABRIR LAS PUERTAS
https://es.aliexpress.com/item/2-unids- ... 3c006kR3OD
Si no fueran parpadeantes (vamos, como las que llevan muchos coches de serie) me las pillaba. Pero eso de que se parpadeen me parece un poco quillo (opinión personal, claro).
Juraría que el mio trae las bisagras protegidas con una goma que encaja al cerrar la puerta... tomo nota de tomas formas por si no.
Seat León ST Xcellence Advanced 2.0 TDI 150CV Plata Urban + gancho remolque.
jd_zuri - Leoner@ habitual
- Agradecido: 44 veces
El compañero se refiere a que no sea en L el extremo "USB" pero si sea en L el extremo "USB-C" ya que el que molesta es el primerolitri59 escribió:ZiFFeL escribió:Compré un cable USB - USB Con qué va perfectamente, pero al ser L en ambos lados me deja el otro USB inutilizado, alguno que hayáis comprado que lleve la L al otro lado o que sea L sólo de la parte USB C?
dRoXe - Leoner@ avanzad@
- Agradecido: 90 veces
jd_zuri escribió:Juraría que el mio trae las bisagras protegidas con una goma que encaja al cerrar la puerta... tomo nota de tomas formas por si no.
Es posible, el mío las trae. La bisagra queda algo a la vista pero no me atrevo a quitar esa goma no sea que después no pueda ponerla. Y tampoco tiene cabezas de tornillos a la vista en el lateral de las puertas para ponerle esos taponcitos negros que se listan en el primer mensaje.
Menos mal que me dió por revisar el coche antes de pedirlo todo a los chinos.
Fernando
Mi gatito: León MK3 SC FR 1.8 blanco nevada
fernandomg - Asidu@ en la selva
- Agradecido: 37 veces
Efectivamente, puede que dependa del equipamiento o si es pre-restyling.fernandomg escribió:jd_zuri escribió:Juraría que el mio trae las bisagras protegidas con una goma que encaja al cerrar la puerta... tomo nota de tomas formas por si no.
Enviado desde mi Nexus 5 mediante Tapatalk
dRoXe escribió:El compañero se refiere a que no sea en L el extremo "USB" pero si sea en L el extremo "USB-C" ya que el que molesta es el primerolitri59 escribió:ZiFFeL escribió:Compré un cable USB - USB Con qué va perfectamente, pero al ser L en ambos lados me deja el otro USB inutilizado, alguno que hayáis comprado que lleve la L al otro lado o que sea L sólo de la parte USB C?
ok,no lo habia pillado,en ese caso quizas le valga este otro:
https://www.amazon.es/C-Carlcoo-Cargado ... dado&psc=1
Usuarios navegando por este Foro: Google [Bot] y 7 invitados
