Seguidores: golf_1990, josusanchez5b, Jastur, r11ourense, MerioE, davidddgt, jose.a.llamas, gato125, Pkt, byChule, Hovig, SorianoFco, jygalvan, CubanPitbull, corderazo, israher, iDavid9669, nyro, pirulo79, Edu1589, ramargo75, javi.ferrer, kikelin, aleejandroogm, Trimmer, car212121, LeoST, Besaygf, kinipc, Rasekfighter, Romera, MartinLeon, camamaleon, Aceroinox1a, jramis, Juanquique, josele77, marlop, Peje, Pedrost, bailyibz, wiki88, teltronik, gogua, sirkez, carlosgzlez, mcecho, genialsoft, aironsam14, JoseCa, Dandy_gsi, vanscampa, Joseibz, trekam, La_jungla, jorgecrackets, aigort, msmdraven, IRO, Jorge75016, alejandro_javier, ivan0909, jmfcoto, viktor_ct_95, maxxg2, olgalberto1, danifusi, Josepo79, er_trompe, miyobe, jande, Petri, itz18, jagman, serguey79, rafapadilla93, Mate, undernok, lead, lead, csabafr2013, jluis, olmeras, LeidenSpain, osjamil, Valerofr150, flope63, Herrdoktor, pocososinos, carrasco13, pichonclv, C.reina, Daner84, inamarlo, aguscalderon, BaZZ, yujakantabro, Fonek, LARABA, juanmaroger, juanmac, Kipu, IvanMc2, garrafa2, Linker89, mihai G, Igor, bronce702, creasy1977, Gsclosada, lebowski, jaro_84, charly425, leonfr76, DBS83, joseanvazquez501, M3rs, borgio, NOCIVOX, FcoJ.M.N., VillaSB, t4alberto, lytry32.hc, david_gz, Kasky, diegol147, jasoriab, jninomo, jmiturbe, chetelopez, utopia95, Dreziel, jonatan1988, xsoldadito, Illan, Fernandoestrada, jd_zuri, Juande667, xjuliox, Bettor, solanomor01, Chinyero, volkov, braulioT, Maikermx, iNowack, D83, MORKAS, dRoXe, JaviMarquez, danitre, Davi_TGI, DiegoR, ertate, cuenka16, nicotzioras, Spok68, urbion, linxes, kukikukarron, Talnoseque, Hyperr, VapaV, jfermar, Moigijon, slyjay73, DuckToy, nachomart, Iosu21, sbarri, sebasresa, Beiró, Llisus, agus_piscis10, Action SVG, Alc16, Trivi83, eyebee, riclanico, Per3zo, Qore, lolorm, abollao, Alvi, sergi303, Xilenos, barret, Gus_Fring, malloc, TomH30, jmofcb, paco_22_22, luigi323, Chelazo, dani10s, victor david, Yeiem93, Luiggi7, Guillen222, yoflipo, nenazojuanma, nitro_g4074, Senuto, gabivvamesia, javichu312, richard_11, Yery, Ivensound, El_pelos44, rvicario76, Mr.Chuflas, subaru_3, eruizm, Gomez89, barubita, Nicoplas, javibmw, el_noi_80, kapi21, satoo, barrosdepor, camaon99, craken, Flow-Rider, Castro87, Kikedecefe, xexpir, Cristian2014mx, _Juansp, jornefra, cucci, Pablitofr, Pablitofr, Rober_SR, kevinhtbs, chocoleitos, RamonLaC, cesarsl, drnrd, conquepoquico, hectordrums, Neuw84, bertoco, dondani96, cupralex, Octacon, pablomus85, josean-opc, davidap13, Raaz, erlanz, canijo82, MarcosRG86, Alianma, SinName, mSx, evomaoleon, BertopenST, a.cuadros71, Lumara, Gendos22, borjayadri2, litllevill, Jandrew, galelir, Josep20, borjiguez, THC77, di360, Juanjocantabria, grijan 2.0, copii92, JDMG, Morales92, nadiia.bcn93, yo_javi89, yurkli, Atajunen, carlo13, Desertcuervo, floppy666, amg129, manjerico, Franr50, iNFeCTeD, Rotemburgero, Link, kivamz, dj_ferrix, manu5, Vagabundo, aaronfdez, Manzi, Perilla, juanaco, pepetgi, pistoleromtb, cp_jj, diepecu2, Freddy169, Welmonk, JaquetónST, alrodri, LuisNM, Rekoba, bizu, ginyu 83, ephreon, rr7mo, Def89, CrisFRST5F, Mohoska, gilen44, ayl, SantiPMI, Jesús Peinado, 05kar, Lata8, Adrián pcg, Warelio, carlosVACA, trazas, barris31, danieleon, enriquevalera, antonioagui95, tito68, Sarge86, victorvOrtiz, bigpicha, ericoperico, JulinM, AlvaroRamlo, josermancol, Davidv, flotter, V de Viana, zainao, LeónST, rubiotuning, RacingSport
Notapor cvillajos el 10 Ene 2019, 09:11
xantia333 escribió:
cvillajos escribió:
xantia333 escribió:Hola chicos,
a ver si alguien puede echarme una manilla porque estoy un poco asustado.
Tengo un tdi 184 my17 y gracias a este hilo he conseguido realizar algunos ajustes para dejarlo a mi gusto y nunca he tenido el mas mínimo problema.
Pero esta mañana he cambiado en el modulo 44 (Dirección asistida) el valor
Rampenverhalten bei Motorstopp de activado a inactivo y lo he hecho sin problemas.
Todo esto era para probar si este parámetro desactivaba el tacto que tiene el coche al soltar el embrague (que lo acelera el solo), he ido por aquí porque la traducción era algo asi como comportamiento en rampa y lo del motorstopp pues pensaba que era para evitar que se calara.
En fin, que he hecho la adaptación y al volver a meter la llave (no he llegado ni arrancar el coche) veo que no se enciende la luz del start-stop, con lo cual he deducido que eso solo eliminaba el start-stop (y no es eso lo que buscaba), total que he vuelto a meter el obdeleven para deshacer el cambio y no me deja me dice que función no disponible (31).
Es la primera vez que no me deja revertir un cambio, ¿le ha pasado a alguien más?, estoy un poco acojonado.
Muchas gracias !!
Borra caché de aplicación y/o datos o reinstala. A ver si el error (31) deja de aparecerte.
Mil gracias cvillajos,
lo pruebo esta tarde, en cuanto al parámetro "Rampenverhalten bei Motorstopp" la verdad es que el nombre aparentemente no tiene nada que ver con el start-stop, mas bien comportamiento para no calarse en cuesta ó algo similar. Lo habías escuchado alguna vez.
Nunca antes...
La verdad es que suelo echar un vistazo a algunos módulos de vez en cuando, pero solo "me quedo" con las adaptaciones/codificaciones que están en español o en inglés.
cvillajos
Agradecido: 3575 veces
Notapor Valerofr150 el 10 Ene 2019, 14:05
Hola buenas tardes, queria hacer una pregunta a ver si alguien sabe como se hace. Llevo los pilotos del reestyling y he visto que hay gente por internet que ha conseguido hacer una "imitacion" a lo que hacen los Audis pero sin ser correlativo dl intermitente. En plan que se enchufa primero el intermitente interior y despues exterior. No se si hay codificacion por aqui, llevo tiempo sin estar puesto en este tema y hay muchas paginas por leer y por mas que use el buscador sigo sin encontrar nada. Muchas gracias !!
Enviado desde mi MI 6 mediante Tapatalk
Valerofr150
Notapor El_pelos44 el 10 Ene 2019, 20:05
Hola, Miceor una pregunta, en este mod:
Ajustar la sensibilidad del sensor de luz Todos los modelos
Con esta modificación podrás ajustar la sensibilidad del sensor de luz.
1 - Módulo 09 - Centralita electrónica. Code (31347)
2 - Adaptación
3 - Funciones de luz de asistencia
4 - Lichtsensorempfindlichkeit -- (Cambiar valor al deseado - Normal por defecto)
https://www.youtube.com/watch?v=oJos231Elkk
Hay tres opciones disponibles, sensitive- normal - non sensitive, para lograr q las luces se enciendan mas tarde o cuando hay menos luz cual habria q seleccionar?
Imagen----------Imagen----------Imagen
El_pelos44
Notapor Genzo el 10 Ene 2019, 21:24
Valerofr150 escribió:Hola buenas tardes, queria hacer una pregunta a ver si alguien sabe como se hace. Llevo los pilotos del reestyling y he visto que hay gente por internet que ha conseguido hacer una "imitacion" a lo que hacen los Audis pero sin ser correlativo dl intermitente. En plan que se enchufa primero el intermitente interior y despues exterior. No se si hay codificacion por aqui, llevo tiempo sin estar puesto en este tema y hay muchas paginas por leer y por mas que use el buscador sigo sin encontrar nada. Muchas gracias !!
que yo sepa no hay codificación, solo hay forma de hacerlo fisicamente. un saludo.
:nekora:
Genzo
Agradecido: 61 veces
Notapor xantia333 el 11 Ene 2019, 09:38
Muchas gracias !!
Nunca antes...
Muchas gracias cvillajos, funcionó, para vuestra info deciros que ese parámetro no tiene absolutamente nada que ver con el start-stop, fue un fallo mio. De hecho no tengo claro que hace así que lo he vuelto a dejar como estaba.
xantia333
Agradecido: 74 veces
Notapor rvicario76 el 11 Ene 2019, 15:30
Muchas gracias !!
Nunca antes...
Pues yo sigo sin poder entrar en algunos módulos hoy he intentado modificar la tensión para el s&s y no me ha deja, sin embargo he podido poner los litros a repostar.
He borrado el cache y borrado la APP.
Voy a BORRAR TODA LA tablet y solo voy a poner el OBDELEVEN a ver qué pasa.
Leon MK3 ST FR 1.4 ACT 150cv. :nekora:
rvicario76
Agradecido: 23 veces
Notapor Krynn el 11 Ene 2019, 16:26
Yo estado trasteando con el tema del cierre de ventanillas en caso de lluvia. He activado todo como en el post o vídeo que hay de este Foro, pero cierra todo menos el techo. Alguno que lo tenga activado me puede decir si os cierra también el techo? Muchas gracias.
Krynn
Agradecido: 20 veces
Notapor cvillajos el 11 Ene 2019, 17:16
Krynn escribió:Yo estado trasteando con el tema del cierre de ventanillas en caso de lluvia. He activado todo como en el post o vídeo que hay de este Foro, pero cierra todo menos el techo. Alguno que lo tenga activado me puede decir si os cierra también el techo? Muchas gracias.
viewtopic.php?f=8&t=114823&hilit=Cierre+lluvia+techo#p1842971
Olvidate de que cierre el techo.
En este mensaje, cvillajos ha recibido 2 agradecimientos de:
craken (12 Ene 2019, 21:58), Krynn (11 Ene 2019, 22:30)
cvillajos
Notapor grijan 2.0 el 12 Ene 2019, 11:00
Impresionante hilo!! Sencillamente el OP se lo ha currado de manera colosal. Voy a comprar el cacharro y ya iré exponiendo mis sensaciones. La idea es tocar lo de las señales de tráfico, el driver profile y demás
grijan 2.0
Notapor chocoleitos el 13 Ene 2019, 01:32
Hoy he conseguido hacer funcionar la alarma OEM, muchas gracias a todos. Ya se puede sumar a velocidad del ventilador en auto, litros a repostar, cierre de retrovisores con un toque, parkpilot, reconocimiento de señales.
No consigo cambiar el número de intermitencias con un toque, le pongo 5 y me sigue haciendo 3.
También me gustaría, pero no se cómo, activar el control de crucero en atascos (no sé si se llama así) tengo lane asist y radar delantero de proximidad
Enviado desde mi ANE-LX1 mediante Tapatalk
Seat León 1.4 TGI Style Plus Blanco
chocoleitos
Notapor El_pelos44 el 13 Ene 2019, 01:34
chocoleitos escribió:Hoy he conseguido hacer funcionar la alarma OEM, muchas gracias a todos. Ya se puede sumar a velocidad del ventilador en auto, litros a repostar, cierre de retrovisores con un toque, parkpilot, reconocimiento de señales.
Lo de los intermitentes, tienes que restablecer las luces a ajustes de fabrica despues de hacer el mod con OBDeleven, si no, no funciona.
En este mensaje, El_pelos44 ha recibido un agradecimiento de:
craken (13 Ene 2019, 13:29)
El_pelos44
Notapor chocoleitos el 13 Ene 2019, 01:47
En el menú de ajustes? Mañana lo pruebo, muchas gracias
chocoleitos
Notapor aleejandroogm el 13 Ene 2019, 09:10
Alguien sabe que puedo modificar a mi Seat Leon mk1 con el obdeleven desde la centralita confort? Tipo pitido al abrir y todo eso , si podría ponerle para subir las ventanas y esa cosas. Un saludo muchas gracias
aleejandroogm
Agradecido: 17 veces
Notapor IsmaESP el 13 Ene 2019, 20:03
Buenas noches, alguien puede pasar una backup de un my19 fr plus, el modulo 4b el de multifuncion, y el 17 del cuadro, no se que toque pero me da un error 101400 y el del multifuncion pone error desconocido pero es algo de las luces, porque cuando lo borro se mueven las luces, aunque si teneis backup de todos mejor para asi empezar de 0 y hacer la copia de seguridad completa. Muchas Gracias.
* Ex: León MKII 1.9 Tdi Bxe:
- Repro Stage I
- EGR OFF
* Leon MY19 5f Fr 1.5 Ecotsi 130cv.
- Brico Guantera Refrigerada.
- Brico Neumáticos para Capó.
- Pedales Aluminio FR Personalizados.
- MoDs: Barrido Agujas, Antinieblas con Marcha atrás y ráfagas largas, alarma OEM...
En este mensaje, IsmaESP ha recibido un agradecimiento de:
DVD_1982 (06 Feb 2019, 19:52)
IsmaESP
Agradecido: 9 veces
Notapor Iosu21 el 13 Ene 2019, 20:47
Como se restablece de fábrica? Yo lo cambié en un Ibiza a 4 y sólo me hace 2!! Y no puedo cambiarlo de ninguna manera, ni a más ni a menos.
Iosu21
