Accesorios aliexpress mk3
Favoritos: ositoerik, ROBERTO206, Stealnick, asaltacunas, tsi125, Alleya, Qore, tonnety, Juantxu, mk3Granaino, dani10s, damsolu, clotza, Levanius, pjdelburgo, frigolin, drnrd, Bass8V, Joali, toniRG, Jastur, morat86, _warcry_, Nikobellic, Lopagan666, Lyern, basuvi, rob3r7o, Lady, Danisisa_cupra
Seguidores: jose007dt, adri.f1, adrii18600, IronTor21, toniespejolara719, Hovig, trazas, drnrd, Chuskon, ecolibra, Gus-Gus, suarez22, TomH30, danone10, viktor_ct_95, pozyano, ChusTj, kennit0, Lopess85, er_trompe, rfaus, Gsclosada, djcastle, sergi303, DBS83, Ivensound, Hectoor57, JoseDel, agus_piscis10, jagman, warcryrivas, carrasco13, Triple R, luigi323, digital77, PuertoLeon, El Gonzo, LeonComeIbiza, dRoXe, osjamil, xjuliox, Per3zo, dPintos, VapaV, Igor, kukikukarron, Sanz, fur, chisyelamos, diegoporta97, carlosgzlez, leonfr76, smpxque, inamarlo, R1k4rd0, iviHDR, Moigijon, jd_zuri, surgeon, mk3Granaino, jajereal, ncx, juancete, Pokayoke, Jorge75016, DESMOCHEEE!!!, Guillen222, V de Viana, D83, riclanico, tonnety, lead, rrttrr, CuPra3004Drive, jguirao, Brandenor, triguero, Pedrost, perikolu, Alvi, Edu1589, victor david, aironsam14, Chema Sat, Josepo79, Senuto, sesmero87, Rapiru, Sergt, Llisus, richard_11, vanscampa, nifer, BEDIA, SantiagoSanchez, nachomart, quimiko, barrosdepor, Eohn94, Flow-Rider, puskas65, Snooker83, Angeleitor, Morales92, Rober_SR, Piro25, cucci, RamonLaC, erlanz, Raaz, DiegoR, Brunozp, Fofio, pablomus85, kwatto, msmdraven, iNFeCTeD, MartinLeon, antelo85, Maikermx, josean-opc, El_pelos44, Mr.Chuflas, SantiPMI, Chrohu, LuigiVisio, joga, Atajunen, lafu1988, daniel.velarde77, galelir, rpv, tsi125, Link, jose.a.llamas, eyebee, D.Acuña, Manzi, bluesbreaker88, Lady, higuerashxc, Warelio, St17, carlitos24, ginyu 83, Jastur, talanito, victorvOrtiz, Alf68, AlvaroRamlo, Yagadri, ebcuatro, MaNDuN, Davidv, Andertxu7, garruz666, antoniofdezpas, josearillaperez., MaximusRoco, ezanchi
Re: Accesorios aliexpress mk3
Notapor Warelio el 25 Abr 2019, 17:21
el_mengue escribió:Cómo norma general los Diesel van a tener bateria de mayor capacidad que un gasolina a igualdad de equipamiento y versión.
Si, eso ya lo tenía entendido que las baterías de los vehículos diésel solían ser de mayor potencia.
Un saludo,
Warelio
Moderador de Racing
Agradecido: 1140 veces
Notapor ZXVolcane el 25 Abr 2019, 18:20
@Warelio yo llevo la misma tapa de la bateria en mi Leon, la recibi hace 1 mes y queda genial y proteje.
La tapa queda encajada en los bordes de la bateria por unas pestañas que lleva la tapa. Yo como el plastico es maleable doble un poco los bordes hacia el interior donde van las pestañas para que quedara bien sujeta.
Ya te digo que vibraciones ninguna.
Lo unico que comprobe es que no se derritiera con el calor que produce el motor, se calienta la tapa pero no se derrite.
ZXVolcane
Agradecido: 64 veces
Notapor Warelio el 25 Abr 2019, 18:31
ZXVolcane escribió:@Warelio yo llevo la misma tapa de la bateria en mi Leon, la recibi hace 1 mes y queda genial y proteje.
¡Fenomenal @ZXVolcane ! Ya me quedo más tranquilo, gracias. Luego trataré de encajar la tapa tal y como me has dicho para asegurarme de que quede bien sujeta. Por el tema del calor, estas tapas suelne estár fabricadas en Polipropileno y estos materiales normalmente aguantan altas temperaturas sin problema.
Un saludo,
Warelio
Moderador de Racing
Notapor Mr.Chuflas el 25 Abr 2019, 22:51
Yo llevo esa tapa desde hace meses y sin problemas, no se mueve nada y la temperatura sin problemas, y ya ha tenido días de candela...
Mr.Chuflas
Agradecido: 257 veces
Notapor diavliyo el 25 Abr 2019, 23:47
Alguien sabe si vale para León Cupra
diavliyo
Notapor Warelio el 26 Abr 2019, 08:02
diavliyo escribió:Alguien sabe si vale para León Cupra
Mide la batería de tu coche, si mide 280-290 mm de largo y 170-180 mm. de ancho debería servir.
Un saludo,
Warelio
Moderador de Racing
Notapor El_Palas el 26 Abr 2019, 14:40
Respecto a los alargadores de levas, cuales soléis comprar, las negras o las de color aluminio
El_Palas
Notapor Mr.Chuflas el 27 Abr 2019, 00:48
Yo la llevo en un león st Cupra, eso sí, mira que sea para el motor de 2 litros
Mr.Chuflas
Notapor Mr.Chuflas el 27 Abr 2019, 00:49
El_Palas escribió:Respecto a los alargadores de levas, cuales soléis comprar, las negras o las de color aluminio
Yo he pillado las negras, el canto sigue siendo de aluminio y queda guay
Mr.Chuflas
Notapor Alexr3i el 27 Abr 2019, 12:08
Las mismas que este compi y geniales. La verdad es que porque sé que no vienen de serie, porque dan el pego.
Seat Leon Mk3 Cupra ST 300 4drive (BnD)
Seat Leon Mk1 Fr TDI 150 (TLR Gold 193cv)
Alexr3i
Agradecido: 79 veces
Notapor arlot el 29 Abr 2019, 15:06
Pues yo llevo la tapa de la funda de tela
arlot
Agradecido: 975 veces
Notapor Warelio el 29 Abr 2019, 16:12
arlot escribió:Pues yo llevo la tapa de la funda de tela
Es que me venía sin la parte de arriba de la funda de tela, por eso he comprado la tapa rígida en Aliexpress, para proteger la batería. Si me hubiera venido con la tapa de tela no la hubiera comprado en principio.
Warelio
Moderador de Racing
Notapor erlanz el 29 Abr 2019, 21:10
Esa es la misma que tengo yo en el toledo creo, que dimensiones tiene? Es por si me valdría la de mi toledo que voy a quitar para ponérselo al León cuando venga, por lo menos hasta que me decida por la tapa de plástico.
erlanz
Notapor diavliyo el 29 Abr 2019, 23:15
Compañero dónde has comprado la funda de tela
diavliyo
Notapor Agonza86 el 30 Abr 2019, 06:11
diavliyo escribió:Compañero dónde has comprado la funda de tela
Viene de serie en los 1.6 y los 2.0TDI creo. El mío es un 1.6 TDI y también trae la de tela "completa".
Mi misil: viewtopic.php?f=43&t=112454
Life on the road, V8 POWER :bandit: :bandit: :bandit:
Agonza86
Agradecido: 403 veces
Quitar fallo presion neumaticos Seat Leon Mk3
Foro: Informática / Interfaces / Diagnosis
Autor: dannynavarroo
Respuestas: 25
León Mk3 - Full Link inalámbrico
Foro: AudioCar y MultimediaCar
Autor: Cloud_ganora
Respuestas: 444
Programar ventanillas MK3
Foro: General
Autor: rojas
Respuestas: 8
Seat Leon Fr Mk3 2016
Foro: Presentaciones
Autor: Panii
Respuestas: 5
Consumos MK3
Foro: General
Autor: Ivi140mk3
Respuestas: 3770
Usuarios navegando por este Foro: Majestic-12 [Bot] y 7 invitados
