Accesorios aliexpress mk3
Favoritos: ositoerik, ROBERTO206, Stealnick, asaltacunas, tsi125, Alleya, Qore, tonnety, Juantxu, mk3Granaino, dani10s, damsolu, clotza, Levanius, pjdelburgo, frigolin, drnrd, Bass8V, Joali, toniRG, Jastur, morat86, _warcry_, Nikobellic, Lopagan666, Lyern, basuvi, rob3r7o, Lady, Danisisa_cupra
Seguidores: jose007dt, adri.f1, adrii18600, IronTor21, toniespejolara719, Hovig, trazas, drnrd, Chuskon, ecolibra, Gus-Gus, suarez22, TomH30, danone10, viktor_ct_95, pozyano, ChusTj, kennit0, Lopess85, er_trompe, rfaus, Gsclosada, djcastle, sergi303, DBS83, Ivensound, Hectoor57, JoseDel, agus_piscis10, jagman, warcryrivas, carrasco13, Triple R, luigi323, digital77, PuertoLeon, El Gonzo, LeonComeIbiza, dRoXe, osjamil, xjuliox, Per3zo, dPintos, VapaV, Igor, kukikukarron, Sanz, fur, chisyelamos, diegoporta97, carlosgzlez, leonfr76, smpxque, inamarlo, R1k4rd0, iviHDR, Moigijon, jd_zuri, surgeon, mk3Granaino, jajereal, ncx, juancete, Pokayoke, Jorge75016, DESMOCHEEE!!!, Guillen222, V de Viana, D83, riclanico, tonnety, lead, rrttrr, CuPra3004Drive, jguirao, Brandenor, triguero, Pedrost, perikolu, Alvi, Edu1589, victor david, aironsam14, Chema Sat, Josepo79, Senuto, sesmero87, Rapiru, Sergt, Llisus, richard_11, vanscampa, nifer, BEDIA, SantiagoSanchez, nachomart, quimiko, barrosdepor, Eohn94, Flow-Rider, puskas65, Snooker83, Angeleitor, Morales92, Rober_SR, Piro25, cucci, RamonLaC, erlanz, Raaz, DiegoR, Brunozp, pablomus85, kwatto, msmdraven, iNFeCTeD, MartinLeon, antelo85, Maikermx, josean-opc, El_pelos44, Mr.Chuflas, SantiPMI, Chrohu, LuigiVisio, joga, Atajunen, lafu1988, daniel.velarde77, galelir, rpv, Link, jose.a.llamas, eyebee, D.Acuña, Manzi, bluesbreaker88, Lady, higuerashxc, Warelio, St17, carlitos24, ginyu 83, Jastur, talanito, victorvOrtiz, Alf68, AlvaroRamlo, Yagadri, ebcuatro, MaNDuN, Davidv, Andertxu7, garruz666, antoniofdezpas, josearillaperez., MaximusRoco, ezanchi
Re: Accesorios aliexpress mk3
Notapor erlanz el 28 Ago 2019, 19:53
shaume escribió:
erlanz escribió:
shaume escribió:Buenas, alguien ha cambiado la luz del maletero en un leon ST? O la bombilla.
Veo que tiene poca luminosidad lo que no se si lleva la misma luz que el leon normal, en aliexpress indican leon mk3 solamente. Gracias!
Yo he cambiado el plafon entero pero de Masiled el de AliExpress no se si valdrá.
Para el st? Cogiste el modelo largo o corto? Gracias!
Para el ST el plafon mide lo que se ve en el maletero 5.5 cm
erlanz
Notapor erlanz el 28 Ago 2019, 20:52
Aqui esta la foto con las medidas
http://imgbox.com/W7A2mr3q
erlanz
Notapor shaume el 28 Ago 2019, 21:30
Gracias! Si, he bajado al coche a medirlo, a veces nos olvidamos de lo mas sencillo. 5.5cm hace. Muchas gracias.
shaume
Agradecido: 18 veces
Notapor angeljimenez el 31 Ago 2019, 19:47
He visto por aliexpress el mechero del audi a3 pero me da que es solo la carcasa... alguien sabe donde conseguirlo?
angeljimenez
Coche: Leon MK3 1.5 TGI 130cv
Agradecido: 17 veces
Notapor Lito69 el 10 Sep 2019, 12:28
Lito69
Agradecido: 240 veces
Notapor little bastard el 12 Sep 2019, 10:11
jasoriab escribió:
Warelio escribió:
jasoriab escribió:Gracias por las fotos @Warelio
La verdad es que quedan muy bien, y es una solución muy fácil e ingeniosa para tener luz ahí en las plazas traseras.
Lástima que el mio no lo tenga :zoquete:
¿El tuyo no lleva atrás salidas de aire ni tomas USB? ¿Qué versión es?
Las salidas de aire traseras sí. Lo que no tienen son las tomas USB traseras, que se incluyeron a primeros de 2018, unos meses después de comprarlo, junto a las estriberas delanteras iluminadas (al menos en los FR).
Exacto en mi Cupra ST de Abril de 2018 llego con 2 USB traseros y estriberas con la bandera iluminada. :ok:
little bastard
Agradecido: 82 veces
Notapor little bastard el 12 Sep 2019, 10:14
Yo lo cambie por este;
https://es.aliexpress.com/item/32888280 ... 63c0NuIJYt
Es impresionante la diferencia de Luz. Antes no se veia nada y ahora tengo que abrir el maletero con gafas de sol. :si: :si:
little bastard
Notapor Mr.Chuflas el 12 Sep 2019, 13:16
tu coche trae dos puntos de luz en el maletero? (lo digo por el link que has puesto, que te venden dos juntos)
Mr.Chuflas
Agradecido: 257 veces
Notapor jawepe el 12 Sep 2019, 13:22
Alguno puede recomendarme alguna funda de llave rigida?
y si puede subir una foto de como es mejor.
Muchas gracias.
saludos!
jawepe
Notapor Warelio el 12 Sep 2019, 13:41
jawepe escribió:Alguno puede recomendarme alguna funda de llave rigida?
Muchas gracias.
saludos!
Yo compré esta, rígida imitación fibra de Carbono y hasta la fecha muy contento.
Un saludo,
Warelio
Moderador de Racing
Agradecido: 1182 veces
Notapor antelo85 el 12 Sep 2019, 15:29
Muchas gracias.
saludos!
Un saludo,
Donde la compraste?
antelo85
Coche: Leon MK3 2.0 TSI 190cv
Notapor Warelio el 12 Sep 2019, 15:47
Muchas gracias.
saludos!
Un saludo,
Donde la compraste?
La compré en Aliexpress en este enlace:
https://es.aliexpress.com/item/32921901 ... 63c03ARunp
Me costó unos 8,5 € creo más portes, pero por la calidad que tiene prefiero pagar ese importe a una de 1 € y que me dure 2 días contados. La tengo desde el mes de Mayo y está perfecta. Además como es rígida no se deforma para nada.
Un saludo,
Última edición por cvillajos el 12 Sep 2019, 16:16, editado 2 veces en total
Razón: Edición quotes
Warelio
Moderador de Racing
Notapor jawepe el 12 Sep 2019, 17:32
Muchas gracias.
saludos!
Un saludo,
Muchas gracias compañero, justamente era la que estaba mirando así que me decantare por cogerla que odio el desgaste que sufren las llaves!
jawepe
Notapor Warelio el 12 Sep 2019, 17:57
Muchas gracias.
saludos!
Un saludo,
De nada, un placer. Es cierto que las llaves son bastante delicadas y enseguida el plástico se afea y si se te caen al suelo se rompen con relativa facilidad. No está de más ponerles una funda para que queden más protegidas y de paso buscar alguna que sea bonita.
Un saludo,
Warelio
Moderador de Racing
Notapor Jastur el 12 Sep 2019, 18:14
@warelio y como va la funda?¿ pegada con algo o se cierra con unos clicks o como?¿
Jastur
Agradecido: 35 veces
Usuarios navegando por este Foro: AhrefsBot, Semrush y 11 invitados
