https://s.click.aliexpress.com/e/o574WHY9N
https://s.click.aliexpress.com/e/Z11LEcK3v
Enviado desde mi SM-N950F mediante Tapatalk
Accesorios aliexpress mk3
- Seguidores: 160
- Favoritos: 30
- Vistas: 431.154
Favoritos: ositoerik, ROBERTO206, Stealnick, asaltacunas, tsi125, Alleya, Qore, tonnety, Juantxu, mk3Granaino, dani10s, damsolu, clotza, Levanius, pjdelburgo, frigolin, drnrd, Bass8V, Joali, toniRG, Jastur, morat86, _warcry_, Nikobellic, Lopagan666, Lyern, basuvi, rob3r7o, Lady, Danisisa_cupra
Seguidores: jose007dt, adri.f1, adrii18600, IronTor21, toniespejolara719, Hovig, trazas, drnrd, Chuskon, ecolibra, Gus-Gus, suarez22, TomH30, danone10, viktor_ct_95, pozyano, ChusTj, kennit0, Lopess85, er_trompe, rfaus, Gsclosada, djcastle, sergi303, DBS83, Ivensound, Hectoor57, JoseDel, agus_piscis10, jagman, warcryrivas, carrasco13, Triple R, luigi323, digital77, PuertoLeon, El Gonzo, LeonComeIbiza, dRoXe, osjamil, xjuliox, Per3zo, dPintos, VapaV, Igor, kukikukarron, Sanz, fur, chisyelamos, diegoporta97, carlosgzlez, leonfr76, smpxque, inamarlo, R1k4rd0, iviHDR, Moigijon, jd_zuri, surgeon, mk3Granaino, jajereal, ncx, juancete, Pokayoke, Jorge75016, DESMOCHEEE!!!, Guillen222, V de Viana, D83, riclanico, tonnety, lead, rrttrr, CuPra3004Drive, jguirao, Brandenor, triguero, Pedrost, perikolu, Alvi, Edu1589, victor david, aironsam14, Chema Sat, Josepo79, Senuto, sesmero87, Rapiru, Sergt, Llisus, richard_11, vanscampa, nifer, BEDIA, SantiagoSanchez, nachomart, quimiko, barrosdepor, Eohn94, Flow-Rider, puskas65, Snooker83, Angeleitor, Morales92, Rober_SR, Piro25, cucci, RamonLaC, erlanz, Raaz, DiegoR, Brunozp, Fofio, pablomus85, kwatto, msmdraven, iNFeCTeD, MartinLeon, antelo85, Maikermx, josean-opc, El_pelos44, Mr.Chuflas, SantiPMI, Chrohu, LuigiVisio, joga, Atajunen, lafu1988, daniel.velarde77, galelir, rpv, tsi125, Link, jose.a.llamas, eyebee, D.Acuña, Manzi, bluesbreaker88, Lady, higuerashxc, Warelio, St17, carlitos24, ginyu 83, Jastur, talanito, victorvOrtiz, Alf68, AlvaroRamlo, Yagadri, ebcuatro, MaNDuN, Davidv, Andertxu7, garruz666, antoniofdezpas, josearillaperez., MaximusRoco, ezanchi
MartinLeon - Primeros Pasos
- Agradecido: 19 veces
Re: Accesorios aliexpress mk3
Hay muchos enlaces de esos con infinidad de precios, seguro que todos van bien, yo cogí ese por el comentario de un comprador que indicaba que era válido para la llave de nuestro coche y traía la llave de Torx incluida y tornillo de recambio. Así me aseguraba que iría bien.
Warelio - Moderador de Racing
- Agradecido: 1140 veces
MartinLeon escribió:https://s.click.aliexpress.com/e/o574WHY9N
De los dos que has pasado, uno con envio se te queda en 4,96 y diria que no lleva llave. Por 6 céntimos lo compro con llave.
El otro es la goma de los botones.
JOOAAAN - Leoner@ habitual
- Agradecido: 38 veces
Otra chorradita pedida a Alliexpress... Voy a ver qué tal es cuando la reciba pero me ha parecido original y tenía buena pinta.
https://es.aliexpress.com/item/33026357 ... 2e0eccByWh
Warelio escribió:Otra chorradita pedida a Alliexpress... Voy a ver qué tal es cuando la reciba pero me ha parecido original y tenía buena pinta.
Tiene buena pinta cuando te llegue ya nos contaras que tal!
Q.
Seat León 2.0 TDI ST DSG 184cv blanco nevada (link hilo proyecto) <-- página 1 con todos los links de chuches
QaSaR - Leoner@ habitual
- Agradecido: 75 veces
QaSaR escribió:Warelio escribió:Otra chorradita pedida a Alliexpress... Voy a ver qué tal es cuando la reciba pero me ha parecido original y tenía buena pinta.
Q.
En principio lo he de recibir en un par de semanas, os cuento y pongo fotos cuando me llegue.
Hola, sabeis si este pomo DSG vale para nuestro Leon MK3? Alguna experiencia?
https://s.click.aliexpress.com/e/kbgdIEkhN
Nandete - Aun con la L
- Agradecido: 11 veces
Bueno, a ver si me podéis ayudar. Para la luz de día de mi ST de 2015, puesto que fundió una de las bombillas y al desmontar vi el oscurecimiento por calentamiento del portalámpara, compré dos portalámparas nuevos y dos P21W led...
https://www.amazon.es/gp/product/B07211 ... UTF8&psc=1
…que una vez montadas dan buena cantidad de luz peeeeeero… AZULADA, y me gusta blanca.
¿Alguien tiene referencia de alguna que cumpla en cantidad de luz y blanca?
sjreggy - Asidu@ en la selva
Nandete escribió:Hola, sabeis si este pomo DSG vale para nuestro Leon MK3? Alguna experiencia?
En teoría debería servir, en los comentarios indica que sirve. Pero yo paso de desmontar nada de la palanca del cambio y más aún del DSG que tiene pinta de ser muy delicada para ponerle un pomo.
Montados en St y perfecto separan el portón lo necesario para abrirlo desde la parte inferior, genial y montaje en 2 minutos.arlot escribió:lafu1988 escribió:Acabo de ir a seat y dos unidades 20€ con iva por lo que ya están pedidos y llegan en 3 días. En AliExpress y Ebay son más caros 25-30€ con gastos de envío y tardan 1 mes. Ya comentaré que tal van.lafu1988 escribió:Si ese es el mismo vídeo que vi yo. Tiene buena pinta y no creo que haga mucha fuerza para cerrar los muelles y además se puede ajustar la altura y si lo montaba vw en el sirocco... Yo el lunes pregunto en seat y comento el precio que me dicen pero en aliexpress ronda los 25€ la pareja.Agonza86 escribió:Aquí os dejo el vídeo que os dije, estaba equivocado, la referencia es de un Scirocco, cierto, y no, no impulsa el maletero tanto como dije, eso lo hacía con añadiendo unos muelles al amortiguador:
https://youtu.be/jls1XU7FR0Q
Si vais a pedirlo hay que decir que es una referencia de VW ya que lo monta el sirocco
Esperaré tu valoración para lanzarme a comprarlos para un ST,
josean-opc - Asidu@ en la selva
- Agradecido: 29 veces
acabo de ver esto y me preguntaba si alguien lo ha comprado y montado. Se trata de un cargador inalambrico para el móvil, que por lo que parece, podría encajar en nuestros leones.
https://es.aliexpress.com/item/33035694 ... fd0b4e65bd
kwatto - Asidu@ en la selva
- Agradecido: 58 veces
kwatto escribió:Hola,
Es lo que estoy viendo, pero no veo nada claro. Por que no pone nada para nuestro Leon, es más si seleccionas el tipo de cargador inalamabrico no viene el Seat leon...
A ver si alguien sabe algo más por que sería un puntazo... Ya que ese extra lo he tenido en otros coches por que venia de serie, Pero pagar 200€ me parece excesivo , sabiendo que la carga es mínima y no todos los coches tienen carga Inalambrica.
luis8920 - Leoner@ habitual
- Agradecido: 24 veces
luis8920 escribió:kwatto escribió:Hola,
Cierto, 200 Eurazos es un atraco para una pieza que no costará más de 20 o 30 euros, pero también viene con el amplificado de señal GSM de móvil y dicen que si se nota el aumento de la cobertura, si esto lo juntas a que tienes que tener todo el día el BT conectado del móvil y repercute directamente en la batería, con el cargador inalambrico mantienes la batería cargando lo suficiente para que no te baje y te carge algo, no mucho por lo que he leído pero necesario si quieres tener el móvil operativo cuando conduces y librarte de una multa.
Por este precio podían haber pues un cargador de 10w para que pudieras cargar el móvil realmente pero yo creo que un extra imprescindible, si es verdad que puedes cargarlo por cable pero menudo coñazo, al final dejaras de enchufarlo.
1: Ibiza Mk3 1.9 TDI FR 130cv Negro (Stage 1 - 165cv)
2: León Mk3 1.5 TSI ST FR+ 150cv Rojo Desire
parre21 - Asidu@ en la selva
Posiblemente si me hubieran dicho que tambien amplificaba la señal GSM , lo hubiera puesto. Pensaba que solo cargaba el movil.
Por cierto nuestro coche es plastico plastico, que parece mentira que un coche del 2019 y marca que quiera ser premium pos eso. La cuestion no hay nada de efecto fibra de carbono para las puertas ,, guanteras y demás? Es que ver el plastico así , encima mazo de duro y soso pues da pena.
