Seguidores: golf_1990, josusanchez5b, Jastur, r11ourense, MerioE, davidddgt, jose.a.llamas, gato125, Pkt, byChule, Hovig, SorianoFco, jygalvan, CubanPitbull, corderazo, israher, iDavid9669, nyro, pirulo79, Edu1589, ramargo75, javi.ferrer, kikelin, aleejandroogm, Trimmer, car212121, LeoST, Besaygf, kinipc, Rasekfighter, Romera, MartinLeon, camamaleon, Aceroinox1a, jramis, Juanquique, josele77, marlop, Peje, Pedrost, bailyibz, wiki88, teltronik, gogua, sirkez, carlosgzlez, mcecho, genialsoft, aironsam14, JoseCa, Dandy_gsi, vanscampa, Joseibz, trekam, La_jungla, jorgecrackets, aigort, msmdraven, IRO, Jorge75016, alejandro_javier, ivan0909, jmfcoto, viktor_ct_95, maxxg2, olgalberto1, danifusi, Josepo79, er_trompe, miyobe, jande, Petri, itz18, jagman, serguey79, rafapadilla93, Mate, undernok, lead, lead, csabafr2013, jluis, olmeras, LeidenSpain, osjamil, Valerofr150, flope63, Herrdoktor, pocososinos, carrasco13, pichonclv, C.reina, Daner84, inamarlo, aguscalderon, BaZZ, yujakantabro, Fonek, LARABA, juanmaroger, juanmac, Kipu, IvanMc2, garrafa2, Linker89, mihai G, Igor, bronce702, creasy1977, Gsclosada, lebowski, jaro_84, charly425, leonfr76, DBS83, joseanvazquez501, M3rs, borgio, NOCIVOX, FcoJ.M.N., VillaSB, t4alberto, lytry32.hc, david_gz, Kasky, diegol147, jasoriab, jninomo, jmiturbe, chetelopez, utopia95, Dreziel, jonatan1988, xsoldadito, Illan, Fernandoestrada, jd_zuri, Juande667, xjuliox, Bettor, solanomor01, Chinyero, volkov, braulioT, Maikermx, iNowack, D83, MORKAS, dRoXe, JaviMarquez, danitre, Davi_TGI, DiegoR, ertate, cuenka16, nicotzioras, Spok68, urbion, linxes, kukikukarron, Talnoseque, Hyperr, VapaV, jfermar, Moigijon, slyjay73, DuckToy, nachomart, Iosu21, sbarri, sebasresa, Beiró, Llisus, agus_piscis10, Action SVG, Alc16, Trivi83, eyebee, riclanico, Per3zo, Qore, lolorm, abollao, Alvi, sergi303, Xilenos, barret, Gus_Fring, malloc, TomH30, jmofcb, paco_22_22, luigi323, Chelazo, dani10s, victor david, Yeiem93, Luiggi7, Guillen222, yoflipo, nenazojuanma, nitro_g4074, Senuto, gabivvamesia, javichu312, richard_11, Yery, Ivensound, El_pelos44, rvicario76, Mr.Chuflas, subaru_3, eruizm, Gomez89, barubita, Nicoplas, javibmw, el_noi_80, kapi21, satoo, barrosdepor, camaon99, craken, Flow-Rider, Castro87, Kikedecefe, xexpir, Cristian2014mx, _Juansp, jornefra, cucci, Pablitofr, Pablitofr, Rober_SR, kevinhtbs, chocoleitos, RamonLaC, cesarsl, drnrd, conquepoquico, hectordrums, Neuw84, bertoco, dondani96, cupralex, Octacon, pablomus85, josean-opc, davidap13, Raaz, erlanz, canijo82, MarcosRG86, Alianma, SinName, mSx, evomaoleon, BertopenST, a.cuadros71, Lumara, Gendos22, borjayadri2, litllevill, Jandrew, galelir, Josep20, borjiguez, THC77, di360, Juanjocantabria, grijan 2.0, copii92, JDMG, Morales92, nadiia.bcn93, yo_javi89, yurkli, Atajunen, carlo13, Desertcuervo, floppy666, amg129, manjerico, Franr50, iNFeCTeD, Rotemburgero, Link, kivamz, dj_ferrix, manu5, Vagabundo, aaronfdez, Manzi, Perilla, juanaco, pepetgi, pistoleromtb, cp_jj, diepecu2, Freddy169, Welmonk, JaquetónST, alrodri, LuisNM, Rekoba, bizu, ginyu 83, ephreon, rr7mo, Def89, CrisFRST5F, Mohoska, gilen44, ayl, SantiPMI, Jesús Peinado, 05kar, Lata8, Adrián pcg, Warelio, carlosVACA, trazas, barris31, danieleon, enriquevalera, antonioagui95, tito68, Sarge86, victorvOrtiz, bigpicha, ericoperico, JulinM, AlvaroRamlo, josermancol, Davidv, flotter, V de Viana, zainao, LeónST, rubiotuning, RacingSport
Notapor carlos_tm el 09 Dic 2019, 12:30
Gendos22 escribió:
carlos_tm escribió:Hola. No consigo desactivar el star-stop
Entro en el modulo 19 - Adaptación - Límite tensión inicial star-stop y cambio de valor a 12V.
Luego el start-stop requirimient ambient temperature no le deja modificar nada.
Cuando le doy al botón de start-stop me sigue apareciendo activado/desactivado
[ Imagen ] [ Imagen ]
Botón en si funciona y te aparece en la pantalla pero start stop no debe funcionar. Osea el motor no para
Enviado desde mi SM-N960F mediante Tapatalk
Entiendo. Muchas gracias.
Alguien sabe como puedo quitar el fallo tras cambiar las luces cruce/carretera de halógenas a led ? Da fallo con el can-bus
carlos_tm
Notapor MartinLeon el 11 Dic 2019, 02:48
Leuchte7 y leuchte6 cambiar valor a ( LED Ligtmodul ) y a 127 el dimmwer
Enviado desde mi SM-N950F mediante Tapatalk
MartinLeon
Agradecido: 19 veces
Notapor carlos_tm el 11 Dic 2019, 14:41
MartinLeon escribió:Leuchte7 y leuchte6 cambiar valor a ( LED Ligtmodul ) y a 127 el dimmwer
Muchas gracias.
No tengo muy claro que pasos a seguir, soy nuevo en el obdeleven y no se que en módulo están esos parámetros.
Edito:
Creo que son los mismos pasos que para quitar el fallo de los led en la matrícula, pero cambiando el nombre de la luz. Más o menos sería:
1 - Módulo 09 - Centralita electrónica. Code (31347)
2 - Adaptación
3 - Leuchte7
4 - Lasttyp 25 -- ( cambiar valor a LED Ligtmodul)
5 - Dimmwert -- (Cambiar valor a 127)
Y repetir el proceso para leuchte6
Corregidme si me equivoco por favor! Gracias!
carlos_tm
Notapor MartinLeon el 11 Dic 2019, 14:54
Muchas gracias.
Edito:
2 - Adaptación
3 - Leuchte7
Correcto compañero mismos pasos en cualquier lámpara led que cambies en el coche , yo tampoco soy un pro pero alguito me defiendo poco a poco vamos aprendiendo
MartinLeon
Notapor Gendos22 el 11 Dic 2019, 14:56
Muchas gracias.
Edito:
2 - Adaptación
3 - Leuchte7
A ver si alguien me puede decir que leuchte es para luces ambientales de las puertas. Un saludo
Gendos22
Agradecido: 82 veces
Notapor cvillajos el 11 Dic 2019, 15:21
Muchas gracias.
Edito:
2 - Adaptación
3 - Leuchte7
En los pre-restilyng eran 16 y 17 para rojo/blanco.
En los restilyng lo desconozco, pero por el hilo debe haber MODs que las enumeren. Y si no hay varios post en la primera página que explican el tema luces, no sé si ahí encontrarás algo.
cvillajos
Agradecido: 3572 veces
Notapor carlos_tm el 11 Dic 2019, 17:08
Muchas gracias.
Edito:
2 - Adaptación
3 - Leuchte7
Cuando lo tenga modificado para LED, si luego quiero poner una bombilla halogena (por ejemplo cuando vaya a pasar la ITV), tengo que volver a codificarlo y dejarlo como antes o no hace falta?
Estando modificado para poner las LED, si esta se funda, saltara el aviso de luz fundida?
En este mensaje, carlos_tm ha recibido un agradecimiento de:
MartinLeon (11 Dic 2019, 17:09)
carlos_tm
Notapor MartinLeon el 11 Dic 2019, 17:11
Muchas gracias.
Edito:
2 - Adaptación
3 - Leuchte7
Eso la verdad que aún no lo he probado , será lo mismo pero a la inversa ,cuestión de investigar para ver lo que sucede
MartinLeon
Notapor YeSL el 13 Dic 2019, 16:17
Hola chicos, la última vez que use el Obdeleven para resetear el cambio de aceite se me calló al suelo, no le di mucha importancia porque el golpe fue desde una altura de metro y medio. Pero hoy he ido a ponerlo para activar algunas cosas de cara a la ITV y resulta que me pone conexión no disponible... El aparato luce con la luz roja. A si que no se si es un problema del sistema o del aparato que se ha roto. La aplicación la he desinstalado y vuelto a instalar etc e incluso he probado con otros móviles.
En el caso de que estuviera roto, tendría que pedir uno nuevo e introducir mi clave pro? Muchas gracias!
YeSL
Notapor cvillajos el 13 Dic 2019, 22:00
YeSL escribió:Hola chicos, la última vez que use el Obdeleven para resetear el cambio de aceite se me calló al suelo, no le di mucha importancia porque el golpe fue desde una altura de metro y medio. Pero hoy he ido a ponerlo para activar algunas cosas de cara a la ITV y resulta que me pone conexión no disponible... El aparato luce con la luz roja. A si que no se si es un problema del sistema o del aparato que se ha roto. La aplicación la he desinstalado y vuelto a instalar etc e incluso he probado con otros móviles.
La licencia se asocia al usuario registrado, ni a la APP/teléfono, ni (entiendo) que al interfaz, por lo que pudieras comprar otro OBDeleven y usar tu usuario PRO:
viewtopic.php?f=8&t=116700&p=1886384&hilit=Licencia+usuario#p1886384
De todas formas, puedes consultar con el soporte técnico de OBDeleven para salir de dudas.
YeSL (13 Dic 2019, 22:05)
cvillajos
Notapor YeSL el 13 Dic 2019, 22:06
Muchas gracias! Ya les he enviado un correo a ver si me dan una solución, ya que es raro porque lucir luce... A ver si tengo suerte!
YeSL
Notapor nenazojuanma el 14 Dic 2019, 02:31
A mi de repente me dejo de funcionar, me puse en contacto con ellos y me enviaron otro, eso si, tuve que enviarles el mio.También te digo que estuve peleando con ellos un buen tiempo.
nenazojuanma
Agradecido: 15 veces
Notapor Nandete el 15 Dic 2019, 19:41
Hola, ¿hay constancia de que mods no son compatibles entre los my19 y my20 con los fabricados en años anteriores? He visto que hay algunos mods que cambia el proceso y no quisiera liarla en mi MY20...
Nandete
Notapor JOOAAAN el 16 Dic 2019, 11:14
Nandete escribió:Hola, ¿hay constancia de que mods no son compatibles entre los my19 y my20 con los fabricados en años anteriores? He visto que hay algunos mods que cambia el proceso y no quisiera liarla en mi MY20...
Me sumo a la pregunta :cafe:
JOOAAAN
Agradecido: 38 veces
Notapor Jglez3 el 16 Dic 2019, 18:38
De los que he probado yo, el único que no funciona es el de apertura de retrovisores solo cuando se da el contacto.
Jglez3
Coche: Leon MK3 2.0 TSI 190cv
