Seguidores: golf_1990, josusanchez5b, Jastur, r11ourense, MerioE, davidddgt, jose.a.llamas, gato125, Pkt, byChule, Hovig, SorianoFco, jygalvan, CubanPitbull, corderazo, israher, iDavid9669, nyro, pirulo79, Edu1589, ramargo75, javi.ferrer, kikelin, aleejandroogm, Trimmer, car212121, LeoST, Besaygf, kinipc, Rasekfighter, Romera, MartinLeon, camamaleon, Aceroinox1a, jramis, Juanquique, josele77, marlop, Peje, Pedrost, bailyibz, wiki88, teltronik, gogua, sirkez, carlosgzlez, mcecho, genialsoft, aironsam14, JoseCa, Dandy_gsi, vanscampa, Joseibz, trekam, La_jungla, jorgecrackets, aigort, msmdraven, IRO, Jorge75016, alejandro_javier, ivan0909, jmfcoto, viktor_ct_95, maxxg2, olgalberto1, danifusi, Josepo79, er_trompe, miyobe, jande, Petri, itz18, jagman, serguey79, rafapadilla93, Mate, undernok, lead, lead, csabafr2013, jluis, olmeras, LeidenSpain, osjamil, Valerofr150, flope63, Herrdoktor, pocososinos, carrasco13, pichonclv, C.reina, Daner84, inamarlo, aguscalderon, BaZZ, yujakantabro, Fonek, LARABA, juanmaroger, juanmac, Kipu, IvanMc2, garrafa2, Linker89, mihai G, Igor, bronce702, creasy1977, Gsclosada, lebowski, jaro_84, charly425, leonfr76, DBS83, joseanvazquez501, M3rs, borgio, NOCIVOX, FcoJ.M.N., VillaSB, t4alberto, lytry32.hc, david_gz, Kasky, diegol147, jasoriab, jninomo, jmiturbe, chetelopez, utopia95, Dreziel, jonatan1988, xsoldadito, Illan, Fernandoestrada, jd_zuri, Juande667, xjuliox, Bettor, solanomor01, Chinyero, volkov, braulioT, Maikermx, iNowack, D83, MORKAS, dRoXe, JaviMarquez, danitre, Davi_TGI, DiegoR, ertate, cuenka16, nicotzioras, Spok68, urbion, linxes, kukikukarron, Talnoseque, Hyperr, VapaV, jfermar, Moigijon, slyjay73, DuckToy, nachomart, Iosu21, sbarri, sebasresa, Beiró, Llisus, agus_piscis10, Action SVG, Alc16, Trivi83, eyebee, riclanico, Per3zo, Qore, lolorm, abollao, Alvi, sergi303, Xilenos, barret, Gus_Fring, malloc, TomH30, jmofcb, paco_22_22, luigi323, Chelazo, dani10s, victor david, Yeiem93, Luiggi7, Guillen222, yoflipo, nenazojuanma, nitro_g4074, Senuto, gabivvamesia, javichu312, richard_11, Yery, Ivensound, El_pelos44, rvicario76, Mr.Chuflas, subaru_3, eruizm, Gomez89, barubita, Nicoplas, javibmw, el_noi_80, kapi21, satoo, barrosdepor, camaon99, craken, Flow-Rider, Castro87, Kikedecefe, xexpir, Cristian2014mx, _Juansp, jornefra, cucci, Pablitofr, Pablitofr, Rober_SR, kevinhtbs, chocoleitos, RamonLaC, cesarsl, drnrd, conquepoquico, hectordrums, Neuw84, bertoco, dondani96, cupralex, Octacon, pablomus85, josean-opc, davidap13, Raaz, erlanz, canijo82, MarcosRG86, Alianma, SinName, mSx, evomaoleon, BertopenST, a.cuadros71, Lumara, Gendos22, borjayadri2, litllevill, Jandrew, galelir, Josep20, borjiguez, THC77, di360, Juanjocantabria, grijan 2.0, copii92, JDMG, Morales92, nadiia.bcn93, yo_javi89, yurkli, Atajunen, carlo13, Desertcuervo, floppy666, amg129, manjerico, Franr50, iNFeCTeD, Rotemburgero, Link, kivamz, dj_ferrix, manu5, Vagabundo, aaronfdez, Manzi, Perilla, juanaco, pepetgi, pistoleromtb, cp_jj, diepecu2, Freddy169, Welmonk, JaquetónST, alrodri, LuisNM, Rekoba, bizu, ginyu 83, ephreon, rr7mo, Def89, CrisFRST5F, Mohoska, gilen44, ayl, SantiPMI, Jesús Peinado, 05kar, Lata8, Adrián pcg, Warelio, carlosVACA, trazas, barris31, danieleon, enriquevalera, antonioagui95, tito68, Sarge86, victorvOrtiz, bigpicha, ericoperico, JulinM, AlvaroRamlo, josermancol, Davidv, flotter, V de Viana, zainao, LeónST, rubiotuning, RacingSport
Re: OBDeleven - Dudas y Mods para León MK3
Notapor D83 el 29 Feb 2020, 17:27
miceor escribió:
D83 escribió:Señores de qué puede ser este fallo?
Falta el mensaje del bus de datos...
Ya he revertido las 2 últimas codificaciones de la 09... Y sigue saliendo.
Cuando tengais problemas de este tipo y no deis con la solución lo mejor es que compareis con alguna otra copia de la unidad en cuestión o que la envieis por privado a algún miembro del foro para que la compare.
Así por ciencia infusa no es muy probable dar con la solución.
Podeis mandarme cualquier backup para revisarlo y con mucho gusto os lo miro.
Eso si indicarme en el privado que problemas teneis y año del coche para ir a tajo hecho.
La forma de compararlas? Linea a linea?
:shock:
D83
Agradecido: 68 veces
Notapor Lito69 el 29 Feb 2020, 17:28
jasoriab escribió:Yo tampoco lo consigo. Sólo me funciona el color blanco al abrir el coche, o al sacar la llave, y el resto de modos en rojo, no salen los que incluyo en Fahrprofil_x
Puede ser que sea por versiones de BCM y/o Gateway. Estas son las mías.
Unidad de Control: 09 Centralita eléctrica electrónica
Descripción del sistema: BCM MQBAB H
Número de software: 5Q0937084CQ
Versión de software: 0253
Número de hardware: 5Q0937084CG
Versión de Hardware: H36
Número de serie: 01001717901097
Nombre ODX: EV_BCMMQB
Versión ODX: 018001
Unidad de Control: 19 Interfaz de diagnosis para bus de datos
Descripción del sistema: GW MQB High
Número de software: 3Q0907530G
Versión de software: 4303
Número de hardware: 3Q0907530C
Versión de Hardware: 433
Número de serie: 0006545814
Nombre ODX: EV_GatewNF
Versión ODX: 013023
Nombre de copia de seguridad:
Codificación extendida:
030100F42F085900FB0002D8880F00010001070000000000000000000000
Sub sistemas:
Sub sistema: E221__MFL-PR6
Codificación extendida: 002000
También comentar que tengo una MIB2 High hackeada, por lo que me aparecen los distintos colores en todas las pantallas del infotainment y VC en función del que seleccione de forma manual. Y no me han aplicado la campaña de actualización de la BCM por el problema de los intermitentes delanteros. ¿Os han aplicado esa campaña, tanto a los que le funciona, como a los que no?
A mi me aplicaron la campaña pero la versión de software es la misma que antes.
Adjuntos
Lito69
Agradecido: 236 veces
Notapor jasoriab el 29 Feb 2020, 18:19
miceor escribió:@Lito69 He leido la modificación que has puesto y no entiendo porqué a ti no te separa colores entre normal y eco.
Según la configuración que puse al principio a nosotros nos funciona perfectamente el cambio de colores en cada modo.
El coche no lleva luces en los reposapies.
Sistema BCM MQBAB H
Hardware 5Q0937084CG
Software 5Q0937084CQ
Version 0253
@miceor, ¿Sabes que versión de gateway tiene montada @Julianpalencia ? Porque tanto @lito69 como yo tenemos la misma (el con la campaña de los intermitentes aplicada y yo no, por lo que eso no es significativo) y @cp_jj tiene incluso una superior en nuestras BCM.
A ver si lo que marca la diferencia es la versión del gateway.
jasoriab
Agradecido: 2018 veces
Notapor miceor el 29 Feb 2020, 18:37
Los datos de la centralita de Julian son estos:
Versión de Hardware: H34
Versión ODX: 018001
Otra más que también funciona:
Número de software: 5Q0937084DH
Versión de software: 0312
Versión de Hardware: H40
Versión ODX: 020001
La otra que también funciona no la tengo por aquí.
En este mensaje, miceor ha recibido un agradecimiento de:
jasoriab (29 Feb 2020, 18:43)
miceor
Agradecido: 1256 veces
Notapor jasoriab el 29 Feb 2020, 18:45
miceor escribió:Los datos de la centralita de Julian son estos:
Versión ODX: 018001
Versión ODX: 020001
Pues la versión de Julián es similar a la mía en cuanto SW, lo único diferente es que el su HW es el H34 y el mío H36, que no debe afectar.
¿Tienes la info de las unidades 19 en las que funciona el mod? A ver si las diferencias están ahi.
jasoriab
Notapor miceor el 29 Feb 2020, 18:47
No lo tengo, sólo me pasó el backup de la 09.
La semana que viene hago uno yo en persona. Me voy a esplayar de lo lindo con el coche. Me han dado carta libre para tocar lo que quiera.
En este mensaje, miceor ha recibido 3 agradecimientos de:
jasoriab (29 Feb 2020, 18:50), JDMG (01 Mar 2020, 14:56), MORKAS (29 Feb 2020, 19:36)
miceor
Notapor cp_jj el 29 Feb 2020, 18:51
Versión ODX: 018001
Versión ODX: 020001
Por eso comentaba si es posible que nos pasen un backup para comparar, porque si el mod funciona no se me ocurre otra cosa mas para poder comparar....a menos que hayan cambiado algo segun MY
cp_jj
Agradecido: 58 veces
Notapor jasoriab el 29 Feb 2020, 18:54
miceor escribió:No lo tengo, sólo me pasó el backup de la 09.
De acuerdo, quedamos a la espera entonces :ok:
Si ese coche tuviese DCC, podrías probar el si Fahrprofil_1 es el que se corresponde al modo Confort (exclusivo del equipamiento DCC), al menos en un volcado de la unidad 09 de un Skoda MY19 que he encontrado es así, además que el modo individual tiene el Fharprofil_7 (a través del valor de Ambiente_Farbwahl_Individual, incluso al modo snow le asignan el 11).
Si creéis que es interesante ese backup de Skoda, lo subo aquí en un archivo comprimido.
jasoriab
Notapor miceor el 29 Feb 2020, 18:55
El backup que yo tengo es de antes de hacer la modificación. No creo que te valga.
Ponte en contacto con Julián a ver si te lo puede pasar actualizado.
miceor
Notapor miceor el 29 Feb 2020, 18:57
jasoriab escribió:Si creéis que es interesante ese backup de Skoda, lo subo aquí en un archivo comprimido.
Me interesa tenerlo. Yo todo lo que sea leer e investigar a la saca.
miceor
Notapor jasoriab el 29 Feb 2020, 19:00
Por supueto, aquí lo tienes :ok:
Adjuntos
Skoda_bcm.zip
(26.47 KiB) 13 veces
En este mensaje, jasoriab ha recibido 2 agradecimientos de:
cp_jj (29 Feb 2020, 20:41), miceor (29 Feb 2020, 19:14)
jasoriab
Notapor jasoriab el 29 Feb 2020, 19:03
miceor escribió:El backup que yo tengo es de antes de hacer la modificación. No creo que te valga.
@Julianpalencia ¿Podrías por favor subir un backup de tus unidades 09 y 19 tras aplicar el mod de la iluminación ambiental en función del modo de conducción seleccionado?
Así podríamos hacer un diff y descubrir que nos está faltando a la codificación de nuestros coches.
¡Gracias por adelantado! :ok:
jasoriab
Notapor Lito69 el 29 Feb 2020, 19:10
Sistema BCM MQBAB H
Version 0253
Yo sé que simplemente poniendo la unidad 5f de my19 o my20 cuando eliges colores te cambian en radio y cuadro sin tocar nada por obdeleven, un conocido se cambió la unidad de guantera 5f
Lito69
Notapor Lito69 el 29 Feb 2020, 19:17
Es un backup de un skoda con luces ambiente automaticas de serie? Si es así investigaré, muy interesante.
Vengo con más noticias, si me voy al modo eco y le apreto al botón info me sale lo que tiene asignado, motor eco, acc eco..... Y luces ambientales normales, sin poderlo cambiar claro, por eso me coge la luz ambiental del modo normal, en el individual como es configurable me deja elegir blanco o rojo, que al ser apretado poner normal o sport, lo miré ayer y es verdad que coge el color que haya puesto en normal o en sport, pero claro, si yo no he puesto por obd eleven que el normal sea blanco y el sport sea rojo pasa que al apretar a blanco me sale el color del modo normal, que no tiene por que ser blanco si yo no puse el blanco por obdeleven.
Parece que todos los modos quieren coger luz ambiental normal o sport pero ninguno más, donde le dirá la radio que sólo intente coger esos dos o donde se cambiarian? Si a la radio le saliera de los cojones querer coger en luz ambiental el fahrprofile 5 pues ya estaría, pero en algún lado estarán los perfiles de conducción y sus configuraciones. Me he mirado de todo y quizá sea firmware no modificable por obdeleven en mi caso.
Adjuntos
Lito69
Notapor jasoriab el 29 Feb 2020, 19:28
Sistema BCM MQBAB H
Version 0253
Sí, eso es cierto. Tengo cambiada la 5F por una Plus hackeada, y me permite cambiar los colores que comentas tanto en la pantalla como VC, viene de serie ya con esa versión.
Pero ni así me va, me pasa como a ti. No puedo seleccionar un color por cada modo.
Salduos,
jasoriab
