Seguidores: golf_1990, josusanchez5b, Jastur, r11ourense, MerioE, davidddgt, jose.a.llamas, gato125, Pkt, byChule, Hovig, SorianoFco, jygalvan, CubanPitbull, corderazo, israher, iDavid9669, nyro, pirulo79, Edu1589, ramargo75, javi.ferrer, kikelin, aleejandroogm, Trimmer, car212121, LeoST, Besaygf, kinipc, Rasekfighter, Romera, MartinLeon, camamaleon, Aceroinox1a, jramis, Juanquique, josele77, marlop, Peje, Pedrost, bailyibz, wiki88, teltronik, gogua, sirkez, carlosgzlez, mcecho, genialsoft, aironsam14, JoseCa, Dandy_gsi, vanscampa, Joseibz, trekam, La_jungla, jorgecrackets, aigort, msmdraven, IRO, Jorge75016, alejandro_javier, ivan0909, jmfcoto, viktor_ct_95, maxxg2, olgalberto1, danifusi, Josepo79, er_trompe, miyobe, jande, Petri, itz18, jagman, serguey79, rafapadilla93, Mate, undernok, lead, lead, csabafr2013, jluis, olmeras, LeidenSpain, osjamil, Valerofr150, flope63, Herrdoktor, pocososinos, carrasco13, pichonclv, C.reina, Daner84, inamarlo, aguscalderon, BaZZ, yujakantabro, Fonek, LARABA, juanmaroger, juanmac, Kipu, IvanMc2, garrafa2, Linker89, mihai G, Igor, bronce702, creasy1977, Gsclosada, lebowski, jaro_84, charly425, leonfr76, DBS83, joseanvazquez501, M3rs, borgio, NOCIVOX, FcoJ.M.N., VillaSB, t4alberto, lytry32.hc, david_gz, Kasky, diegol147, jasoriab, jninomo, jmiturbe, chetelopez, utopia95, Dreziel, jonatan1988, xsoldadito, Illan, Fernandoestrada, jd_zuri, Juande667, xjuliox, Bettor, solanomor01, Chinyero, volkov, braulioT, Maikermx, iNowack, D83, MORKAS, dRoXe, JaviMarquez, danitre, Davi_TGI, DiegoR, ertate, cuenka16, nicotzioras, Spok68, urbion, linxes, kukikukarron, Talnoseque, Hyperr, VapaV, jfermar, Moigijon, slyjay73, DuckToy, nachomart, Iosu21, sbarri, sebasresa, Beiró, Llisus, agus_piscis10, Action SVG, Alc16, Trivi83, eyebee, riclanico, Per3zo, Qore, lolorm, abollao, Alvi, sergi303, Xilenos, barret, Gus_Fring, malloc, TomH30, jmofcb, paco_22_22, luigi323, Chelazo, dani10s, victor david, Yeiem93, Luiggi7, Guillen222, yoflipo, nenazojuanma, nitro_g4074, Senuto, gabivvamesia, javichu312, richard_11, Yery, Ivensound, El_pelos44, rvicario76, Mr.Chuflas, subaru_3, eruizm, Gomez89, barubita, Nicoplas, javibmw, el_noi_80, kapi21, satoo, barrosdepor, camaon99, craken, Flow-Rider, Castro87, Kikedecefe, xexpir, Cristian2014mx, _Juansp, jornefra, cucci, Pablitofr, Pablitofr, Rober_SR, kevinhtbs, chocoleitos, RamonLaC, cesarsl, drnrd, conquepoquico, hectordrums, Neuw84, bertoco, dondani96, cupralex, Octacon, pablomus85, josean-opc, davidap13, Raaz, erlanz, canijo82, MarcosRG86, Alianma, SinName, mSx, evomaoleon, BertopenST, a.cuadros71, Lumara, Gendos22, borjayadri2, litllevill, Jandrew, galelir, Josep20, borjiguez, THC77, di360, Juanjocantabria, grijan 2.0, copii92, JDMG, Morales92, nadiia.bcn93, yo_javi89, yurkli, Atajunen, carlo13, Desertcuervo, floppy666, amg129, manjerico, Franr50, iNFeCTeD, Rotemburgero, Link, kivamz, dj_ferrix, manu5, Vagabundo, aaronfdez, Manzi, Perilla, juanaco, pepetgi, pistoleromtb, cp_jj, diepecu2, Freddy169, Welmonk, JaquetónST, alrodri, LuisNM, Rekoba, bizu, ginyu 83, ephreon, rr7mo, Def89, CrisFRST5F, Mohoska, gilen44, ayl, SantiPMI, Jesús Peinado, 05kar, Lata8, Adrián pcg, Warelio, carlosVACA, trazas, barris31, danieleon, enriquevalera, antonioagui95, tito68, Sarge86, victorvOrtiz, bigpicha, ericoperico, JulinM, AlvaroRamlo, josermancol, Davidv, flotter, V de Viana, zainao, LeónST, rubiotuning, RacingSport
Re: OBDeleven - Dudas y Mods para León MK3
Notapor t.vazquez el 14 May 2020, 13:25
cvillajos escribió:
t.vazquez escribió:Chicos una consulta rapida,acabo de recibir mi Obd eleven con activacion PRO, me mandaron un correo con el codigo y a traves del enlace de ese correo he activado supuestamente la version PRO pero en mi aplicacion no veo donde lo pone ni como ver si esta correcto,como puedo ver eso??
Comentar que en la aplicacion no me aparece ningun icono de pro ni nada.
Gracias!!
Deberías verlo en letras dentro del menú de la aplicación debajo de la foto de avatar.
Si no, fuerza el cierre de la aplicación y vuele a abrir.
Por último, sigue las instrucciones que indica el compañero @theoldboy aquí: viewtopic.php?f=8&t=132218&start=90#p2117833
Solucionado,les mande un correo y ya lo tengo funcionando,gracias!
En este mensaje, t.vazquez ha recibido un agradecimiento de:
YeSL (14 May 2020, 19:49)
t.vazquez
Notapor Romera el 14 May 2020, 13:32
Mr.Chuflas escribió:
Romera escribió:Comentando con otro my17, hemos comparado el modulo 9 y faltan opciones, por ello no se puede en my17 o anteriores.
El problema radica en la version de software y version de hardware del modulo 9.
En esta centralita no es posible activarlo al menos con sensor de lluvia de 1 punto, My17:
Versión de hardware: H34
Versión de software: 0236
En cambio, en MY18 y posteriores, con versiones superiores a las que dejo, si se puede:
Versión de hardware: H36
Versión de software: 0253
Probado en MY18, MY19 y MY20, funciona correctamente. Solo en los MY20 no aparece en Menú Car, ajustes, Cierre y apertura, la opcion para activar o desactivar pero funciona correctamente.
En los que se ha probado todos tienen sensor de lluvia de 1 solo punto. No se ha requerido cambiarlo por el famoso de 4 puntos.
Quizas en my17 y anteriores si se requiera tener sensor de lluvia de 4 punto, ahí ya lo desconozco.
Un detalle, es que en los que no le funcionaba el bit 6 del byte 0 lo tienen desactivado en cambio en el resto que se ha probado no siendo my17, lo tenían activado.
Enviado desde mi LG-G7 Thinq mediante Tapatalk
buenas te vuelvo a citar por si se te pasó mi anterior mensaje, en el cual me preguntabas por el año de mi león:
gracias de antemano, ya que no sé cual es ese componente ni donde buscarlo :avergonzado:
Romera escribió:Alguna opción habrá por ahí oculta.... Cuestion de investigar.... Yo no tengo techo por lo que no puedo...
por cierto que es el punto 7? es que no sé que es el componente RLFSS (en mi caso)
Gracias por adelantado :ok:
De que año es tu león?
es un my18
Buenas @Mr.Chuflas , perdona se me pasó.
Cuando entras en el Módulo 9, ves una opcion que es Sub Sistemas, al entrar, es ahí dónde encontrarás la opcion G397_RLFSS en tu caso al ser MY18. Entras dentro de esta función y luego en codificación extendida y aquí es dónde en el byte 0 activaras el bit 1 y el 2, en mi caso ya me venía activado el 1, solo activé el 2.
Por asi decirlo, es una configuración mas detallada del Modulo 9
En este mensaje, Romera ha recibido un agradecimiento de:
Mr.Chuflas (15 May 2020, 04:37)
Romera
Agradecido: 316 veces
Notapor jasoriab el 14 May 2020, 19:14
Hola @Romera
He visto el vídeo de youtube del mod del cambio de colores en función del modo de conducción.
Dices que has optado por el blanco como color de bienvenida, y en el vídeo se ve cierto tono morado, aunque es cierto, que en vivo no se nota tanto. Supongo que habrás codificado ese blanco con sus valores RGB, (255,255,255) ¿no?
Yo hice la misma adaptación, pero no estaba con ese tinte morado del color, y mirando los colores que traen los Skoda de serie, traen esta codificación para blanco. Al ver los números de la codificación del color, no parece que es un blanco, pero, supongo por el tipo de leds rgb que montamos, el resultado final es mucho mejor que con el tipico FF,FF,FF
Ambience_lightning_color_list_2
Rotwert Farbe 15: 217
Gruenwert Farbe 15: 221
Blauwert Farbe 15 235
Ambience_lightning_color_list_lin_2:
Rotwert_Farbe_15_lin: 120
Gruenwert_Farbe_15_lin: 231
Blauwert_Farbe_15_lin: 71
Yo lo llevo así en mi coche. Por supuesto, sustituye el nº de color que tengas asignado al blanco por este, o créalo en el siguiente que tengas libre. Ya me dices el resultado :ok:
En este mensaje, jasoriab ha recibido un agradecimiento de:
Romera (14 May 2020, 19:33)
jasoriab
Agradecido: 2019 veces
Notapor Romera el 14 May 2020, 19:32
jasoriab escribió:Hola @Romera
Merci @jasoriab en cuanto pueda bajo al parking y pruebo, lo tengo en el valor 8 y tengo listado de 30 colores.
Puse a ojo, tal que así y es un blanco frio. En persona como digo en el video se ve un blanco frio 6500k, pero en el video, con la oscuridad y tal la camara lo capta con tono morado/azulado
Rotwert_Farbe_8_lin: 220
Gruenwert_Farbe_8_lin: 220
Blauwert_Farbe_8_lin: 210
Romera
Notapor jose.a.llamas el 15 May 2020, 00:24
Muchísimas gracias Romera!!!!
Por fin lo he podido hacer!!!!
Llevo muchos muchos intentos de hacer este mod en mi leon Fr fast edition plus entregado en marzo de este año (no se si será de los últimos MY19 o MY20 porque ya lo tenían en stock y no se desde cuando)
Tengo dificultades con otros como la luz ambiente en blanco al poner marcha atrás, activar alarma, y algunos otros...
Por cierto, después de poner este mod, al cerrar con un toque el mando, se cierran las ventanas y el techo, antes tenía que mantenerlo pulsado, con un toque cerraba solo las puertas. ¿Es normal o he tocado o cambiado que no debía?
Enviado desde mi SM-A515F mediante Tapatalk
jose.a.llamas
Coche: Leon MK3 1.5 TGI 130cv
Agradecido: 10 veces
Notapor Rotemburgero el 15 May 2020, 01:12
Vuelve atrás revisando los pasos y revisa cada campo. Ese mod de subir las ventanas con un solo toque lo estuve buscando y no lo encontre, pensaba que no se podía hacer
Enviado desde mi VOG-L29 mediante Tapatalk
Rotemburgero
Agradecido: 23 veces
Notapor miceor el 15 May 2020, 03:35
jose.a.llamas escribió:Muchísimas gracias Romera!!!!
Si el coche es de este año llevarás luces RGB. El Mod de luz blanca con marcha atrás sólo funciona con luces de dos colores, o sea anteriores al tuyo. Lo pone en el mod. Date una vuelta por la pagina 1 de este hilo y repasa los mods que no te funcionan, ESTÁN ACTUALIZADOS casi todos (Sólo faltan los mods de intermitentes).
Lo que comentas de cerrar ventanillas y techo con un toque. Yo ya me vuelvo loco con los bandazos que da SEAT con sus centralitas. En modelos antiguos , el techo formaba parte del sistema de puertas. Luego lo independizó. Ahora se conoce que lo vuelve a implementar como al principio. Con el sensor de lluvia lo mismo.
Sería muy interesante para estudio que hicieses una copia de seguridad de la 09 tal y como la tienes ahora mismo, a ver si sacamos algo en claro. Y que no pongas como tienes (Bytes-Bits) del subsistema RLFSS. Si pudieses , ponlo aqui, en este hilo y lo vamos viendo.
Yo llevo como dos años intentando hacer eso precisamente y lo más que he conseguido es que se cierren la ventanillas en un momento indeterminado dejando el coche todo el dia abierto. Puse hasta una camara con detector grabando y cerrando el coche con ventanillas abajo a la misma hora durante toda la noche, unos dias lo hacia a una hora y otros a otra. No pude sacar conclusiones. Probé a tapar los sensores del cristal por si fuese por tema de luz, pero tampoco conseguí nada. Sin embargo un dia en el trabajo, me la dejé un poco bajada aposta y a la media hora tuve que salir al coche a por el movi y se habia cerrado. Una locura vamos.
miceor
Agradecido: 1256 veces
Notapor Mr.Chuflas el 15 May 2020, 04:39
es un my18
No sé si será por mirar los menús sin estar conectado al coche, pero no tengo disponible esa opción de "sub sistemas".... :o
Mr.Chuflas
Agradecido: 257 veces
Notapor jose.a.llamas el 15 May 2020, 07:10
Esta tarde o el finde pongo esa información.
Aclarar para evitar confusión, cuando detecta lluvia solo cierra las ventanas, el techo no hace nada.
Es al usar el cierre con el mando a distancia, al darle un toque cierra todo, eso antes no lo hacía, para cerrar todo tenía que mantener pulsado el mando y ahora cierra siempre todo ¿?
jose.a.llamas
Notapor YeSL el 15 May 2020, 14:53
No eres el único, un compi con un leon nuevo igual después de activarlo se le cierran las ventanas con un clik, yo tampoco te sabría decir por qué.
YeSL
Notapor Romera el 15 May 2020, 15:26
@jasoriab joven, finalmente he dejado un color blanco más a mi gusto, seguía siendo un blanco menos frio el que me indicas del skoda, por tanto, dejo foto del blanco conseguido, se ve aun con un pequeño tono azulado/morado en la foto, es por la oscuridad, en persona se ve blanco normal y me ha quedado muy a gusto el tono, a juego con las botoneras que llevo en blanco.
La combinacion es la siguiente.
Rotwert_Farbe_8_lin: 130
Gruenwert_Farbe_8_lin: 250
Blauwert_Farbe_8_lin: 85
Dejo fotos, se ve en la segunda foto la botonera que la llevo en blanco y es el mismo tono.ImagenImagenImagenImagen
jasoriab (15 May 2020, 16:01)
Romera
Notapor Octacon el 15 May 2020, 15:32
Como has echo para poner en blanco?
Octacon
Agradecido: 87 veces
Notapor jasoriab el 15 May 2020, 16:01
Me apunto el código del color para probarlo en el coche cuando pueda, y si queda un tono más frío, ahí se quedará. :ok:
Romera (15 May 2020, 16:18)
jasoriab
Notapor Romera el 15 May 2020, 16:22
Buenas, en el modulo 9, adaptación. Buscas estos apartados y dejas los valores tal cual
Luz ambiental, lista de colores:
Rotwert Farbe x: 255
Gruenwert Farbe x: 255
Blauwert Farbe x: 255
Pulsar check verde para guardar
Luz ambiental, lista de colores Lin:
Rotwert_Farbe_x_lin: 130
Gruenwert_Farbe_x_lin: 250
Blauwert_Farbe_x_lin: 85
Pulsar check verde para guardar.
X corresponde al numero en orden de izq a derecha del 0 al 9 de tu listado de colores. Si quieres que el cuarto color sea el blanco, pones en la x siempre un 4 en lo descrito arriba.
Rotemburgero (15 May 2020, 17:01)
Romera
Notapor theoldboy el 15 May 2020, 16:52
¿Alguien sabe lo que significan estos valores por favor? Sé que en el Audi, el MMI muestra el nivel de aceite y las advertencias si es bajo, pero no se ve algo así en la codificación de Leon.
Adjuntos
2014 Modified Seat Cupra 280
Mi Fiera Y mi Construir sitio
Uso de OBD11 Siempre realice una copia de seguridad antes de codificar y NUNCA use el Restablecimiento de fábrica
theoldboy
Agradecido: 287 veces
