Accesorios aliexpress mk3
Favoritos: ositoerik, ROBERTO206, Stealnick, asaltacunas, tsi125, Alleya, Qore, tonnety, Juantxu, mk3Granaino, dani10s, damsolu, clotza, Levanius, pjdelburgo, frigolin, drnrd, Bass8V, Joali, toniRG, Jastur, morat86, _warcry_, Nikobellic, Lopagan666, Lyern, basuvi, rob3r7o, Lady, Danisisa_cupra
Seguidores: jose007dt, adri.f1, adrii18600, IronTor21, toniespejolara719, Hovig, trazas, drnrd, Chuskon, ecolibra, Gus-Gus, suarez22, TomH30, danone10, viktor_ct_95, pozyano, ChusTj, kennit0, Lopess85, er_trompe, rfaus, Gsclosada, djcastle, sergi303, DBS83, Ivensound, Hectoor57, JoseDel, agus_piscis10, jagman, warcryrivas, carrasco13, Triple R, luigi323, digital77, PuertoLeon, El Gonzo, LeonComeIbiza, dRoXe, osjamil, xjuliox, Per3zo, dPintos, VapaV, Igor, kukikukarron, Sanz, fur, chisyelamos, diegoporta97, carlosgzlez, leonfr76, smpxque, inamarlo, R1k4rd0, iviHDR, Moigijon, jd_zuri, surgeon, mk3Granaino, jajereal, ncx, juancete, Pokayoke, Jorge75016, DESMOCHEEE!!!, Guillen222, V de Viana, D83, riclanico, tonnety, lead, rrttrr, CuPra3004Drive, jguirao, Brandenor, triguero, Pedrost, perikolu, Alvi, Edu1589, victor david, aironsam14, Chema Sat, Josepo79, Senuto, sesmero87, Rapiru, Sergt, Llisus, richard_11, vanscampa, nifer, BEDIA, SantiagoSanchez, nachomart, quimiko, barrosdepor, Eohn94, Flow-Rider, puskas65, Snooker83, Angeleitor, Morales92, Rober_SR, Piro25, cucci, RamonLaC, erlanz, Raaz, DiegoR, Brunozp, Fofio, pablomus85, kwatto, msmdraven, iNFeCTeD, MartinLeon, antelo85, Maikermx, josean-opc, El_pelos44, Mr.Chuflas, SantiPMI, Chrohu, LuigiVisio, joga, Atajunen, lafu1988, daniel.velarde77, galelir, rpv, tsi125, Link, jose.a.llamas, eyebee, D.Acuña, Manzi, bluesbreaker88, Lady, higuerashxc, Warelio, St17, carlitos24, ginyu 83, Jastur, talanito, victorvOrtiz, Alf68, AlvaroRamlo, Yagadri, ebcuatro, MaNDuN, Davidv, Andertxu7, garruz666, antoniofdezpas, josearillaperez., MaximusRoco, ezanchi
Re: Accesorios aliexpress mk3
Notapor LuigiVisio el 21 May 2020, 11:46
Warelio escribió:
LuigiVisio escribió:
Tchakal escribió:
SLST escribió:
zakk_hevia escribió:
SLST escribió:
zakk_hevia escribió:Acabo de comprarme una red de maletro, está en rebajas, sale por 4,38€ por si os interesa.
#Aliexpress € 4,38 17%de DESCUENTO | 70*70cm bolsa de cuerda de arranque de coche elástica para mercedes w204 w211 vw t5 asiento ateca vw golf 4 golf mk2 asiento León mk3 nissan qashqai
https://a.aliexpress.com/_BOfeiS
Orgullo Valor y Garra!
¿Es para el ST?
Si, o eso me pareció. De todas formas es elastica
Comprada, gracias
Alguno la usó con la bandeja en la posición baja?
Buenas
Yo compré exactamente esta pata el ST
#Aliexpress € 5,02 22%OFF | Red trasera de almacenamiento de maletero de coche para Acura MDX RDX asiento TSX Leon Ibiza Altea Toledo Saab 9-3 9-5 93 900 Infiniti q50 FX35
https://a.aliexpress.com/_dSZGWF1
En posición baja es como mas tensado queda. Eso si si llevas pocas cosas la red hace poco por mucho que tenses la cuerda... Por ejemplo para llevar un paquete de agua de 6 botellas prefiero ponerla en el suelo de los asientos dd atras que este dando bandazos por el maletero.
Por cierto, estoy buscando un foam protector para el maletero pero no encuentro ninguno que quede clavado sobretodo para la posición más baja. Alguien ha comprado alguno?
Gracias!
Yo compré una bandeja para el maletero pero en Amazon (obviamente más cara), para la posición baja de la bandeja en un ST y estoy encantado, es de goma flexible no es de FOAM, gruesa, no huele nada y encaja perfectamente, además lleva relieves en algunas zonas para poder colocar cosas en el maletero y que no se muevan y te aseguro que bien colocadas entre los relieves no se mueven a no ser que vayas haciendo rallies.
Que bueno! Recuerdas el producto de amazon exacto? Tal vez puedas mirar el historial de pedido me harías un favor porque no se cuál exactamente pedir. Gracias!
LuigiVisio
Notapor tuthankamenn el 21 May 2020, 17:25
Yo compré una bandeja para el maletero pero en Amazon (obviamente más cara), para la posición baja de la bandeja en un ST y estoy encantado, es de goma flexible no es de FOAM, gruesa, no huele nada y encaja perfectamente, además lleva relieves en algunas zonas para poder colocar cosas en el maletero y que no se muevan y te aseguro que bien colocadas entre los relieves no se mueven a no ser que vayas haciendo rallies.[/quote]Que bueno! Recuerdas el producto de amazon exacto? Tal vez puedas mirar el historial de pedido me harías un favor porque no se cuál exactamente pedir. Gracias!
Enviado desde mi SM-G935F mediante Tapatalk[/quote]
Tb me interesa el tema , después de leer comentarios de unos q dicen q va perfecta y otros que no,siendo el mismo artículo en Amazon.Hablo del protector maletero.
Sdos
SEAT LEON ST FR 1.5 ECOTSI AUT. 150CV
Mi cacharro viewtopic.php?f=43&t=132699
tuthankamenn
Agradecido: 17 veces
Notapor Warelio el 22 May 2020, 09:15
tuthankamenn escribió:Yo compré una bandeja para el maletero pero en Amazon (obviamente más cara), para la posición baja de la bandeja en un ST y estoy encantado, es de goma flexible no es de FOAM, gruesa, no huele nada y encaja perfectamente, además lleva relieves en algunas zonas para poder colocar cosas en el maletero y que no se muevan y te aseguro que bien colocadas entre los relieves no se mueven a no ser que vayas haciendo rallies.
Sdos[/quote]
Si correcto, hablo del protector para el maletero. El que compré yo al menos a mí me va genial y encaja a la perfección en la posición baja de la bandeja, si pones la bandeja en posición alta ya no encaja tan exacto. Hay que tener claro en qué posición quieres llevar la nadeja del maletero antes de comprarte un protector de esos porque después a veces se hacen reseñas negativas cuando el problema nos es del protector si no de que no se ha usado en la forma correcta que se indica.
Warelio
Moderador de Racing
Agradecido: 1140 veces
Notapor tuthankamenn el 22 May 2020, 09:46
Sdos[/quote]
Si correcto, hablo del protector para el maletero. El que compré yo al menos a mí me va genial y encaja a la perfección en la posición baja de la bandeja, si pones la bandeja en posición alta ya no encaja tan exacto. Hay que tener claro en qué posición quieres llevar la nadeja del maletero antes de comprarte un protector de esos porque después a veces se hacen reseñas negativas cuando el problema nos es del protector si no de que no se ha usado en la forma correcta que se indica.[/quote]
Enlace?
tuthankamenn
Notapor SLST el 23 May 2020, 15:47
¿Es para el ST?
Comprada, gracias
Yo estoy esperandola, pero siempre la llevo en la posición alta, salvo que necesite el extra de litros del maletero. No hay cosa que mas me moleste que tener que salvar el escalón del maletero para guardar las cosas
SLST
Agradecido: 9 veces
Notapor luis8920 el 23 May 2020, 23:13
Muy buenas chicos!!
Mirad que he encontrado!!
#Aliexpress € 11,92 15%OFF | LFOTPP para Leon MK3 Leon Cupra 5F 2017 2018 2019, pasamanos de puerta delantera y trasera para coche, caja de almacenamiento, accesorios de Interior de coche
https://a.aliexpress.com/_dSSJZ45
Joe me parece la mar de interesante! Lo he pillado jajaja
luis8920
Coche: Leon MK3 1.5 TGI 130cv
Agradecido: 24 veces
Notapor basuvi el 30 May 2020, 13:53
luis8920 escribió:Muy buenas chicos!!
La verdad que tiene muy buena pinta, así se puede aprovechar ese hueco que hay.
basuvi
Notapor luis8920 el 31 May 2020, 15:55
Sisisi,a ver si me llega!
A ver sinceramente en todos los coches que he tenido, ahí tenia recipiente para dejar cosas, tantos en las puertas traseras como delanteras... Menos en el Leon ajaja.
luis8920
Notapor eldelpueblo el 01 Jun 2020, 13:10
Anda que me va a durar la poca extra que me pagan.. :zoquete: :zoquete: , ya estan pedidos los recicipentes para los tiradores de las puertas, los protectores de aire de bajo los asientos, la luz led para la marcha atras y una linternita recargable para el mechero...ahora que lleguen prontito y a ver que tal queda todo. :D :D :D
Leon fr. 1.5 TSI. 150 caballos vienen de bonanzaaaaaaaaa
eldelpueblo
Notapor Manzi el 05 Jun 2020, 08:01
Hola buenas, no sé si es el hilo correspondiente.
Compre el cubre maletero para el 5f en Amazon de la marca proline.
No encaja ni arriba ni abajoImagen
Manzi
Notapor Warelio el 05 Jun 2020, 08:59
Manzi escribió:Hola buenas, no sé si es el hilo correspondiente.
No encaja ni arriba ni abajo[ Imagen ]
Es que ese no sirve para el León, fíjate en su forma. Hay uno que es el válido de la misma marca que es el que llevo yo.
https://www.amazon.es/gp/product/B075V8 ... UTF8&psc=1
Este es el que has de comprar para la posición baja del maletero de un ST. Para la psición alta también podrás colocarlo pero ya no te encajará igual. Si no tienes un ST no sé si te servirá pero creo que también lo tenían para el 5P.
Warelio
Moderador de Racing
Notapor Manzi el 05 Jun 2020, 09:12
El mío no es st, valdría en todo caso para el león 5f normal? si alguien sabe le estaré muy agradecido, suelo ir a la huerta y a pescar ,para mi es obligatorio.
Manzi
Notapor Warelio el 05 Jun 2020, 09:20
Para el León 5P tienes ésta de la misma marca que en las preguntas acerca del productos confirman que es para el León 5P.
https://www.amazon.es/Pro-Line-59073775 ... 7621375031
Warelio
Moderador de Racing
Notapor Manzi el 05 Jun 2020, 09:24
Ese el que había comprado y te aseguro que no encaja ni en posición alta ni baja.
Manzi
Notapor Manzi el 05 Jun 2020, 09:30
El mío está fabricado en diciembre del 19, 1.5 tsi.
Pero mi maletero me parece diferente, las esquinas del fondo que hace con la parte trasera de los asientos no tiene esa curva suave y tampoco esos chaflanes laterales para todas las formas del cubre maletero
Manzi
Quitar fallo presion neumaticos Seat Leon Mk3
Foro: Informática / Interfaces / Diagnosis
Autor: dannynavarroo
Respuestas: 25
León Mk3 - Full Link inalámbrico
Foro: AudioCar y MultimediaCar
Autor: Cloud_ganora
Respuestas: 444
Programar ventanillas MK3
Foro: General
Autor: rojas
Respuestas: 8
Seat Leon Fr Mk3 2016
Foro: Presentaciones
Autor: Panii
Respuestas: 5
Consumos MK3
Foro: General
Autor: Ivi140mk3
Respuestas: 3770
Usuarios navegando por este Foro: Majestic-12 [Bot] y 9 invitados
