León Mk3 - Actualización infotainment
Seguidores: kenny_fonseca, ncx, Lavadora, juancete, jesusFR, Hysteria, MaximusRoco, Manu1986, Jorge75016, davidbj, bIxu, miyobe, MORKAS, aironsam14, jramis, kimudj, Maikermx, Javizormo, gogua, Melonkid, Kikote8, maxinew, aigort, carlosgzlez, corderazo, Lionxp, jande, Edu1589, msmdraven, Arkan7, jeroc, inamarlo, edumachuca, Josepo79, lead, camamaleon, davidmd, carrasco13, clavelstreet, mikomiko, josele77, car212121, itz18, golf_1990, LeidenSpain, vecnte, Andy_G, csabafr2013, leonfr76, Trimmer, genialsoft, Enerts, leonfrrojito, Horus, paco_22_22, ruben88, Valerofr150, molvi_mabad, Pekee69, Dav2k6, IbiFR, il_munyo, craken, ruben91mad, papo-182, el_padrino, zeratul, kaiserssosse, lytry32.hc, sbarri, ghitus, DesmoSimon, ruli68, Mramos1985, tonielfilas, braulioT, davidalba, JaviMarquez, osjamil, egarense69, fexposru, Pedrost, Illan, chetelopez, juanacho21, cuenka16, pepeiyo69, VapaV, balbu, juan7777, mams69, Helrique, Kike77, volkov, jluis, loeches, Tom70, Dconnect, Trivi83, MilleMiglia, linxes, sergi303, hector37, D83, quiquito30lv, ElFon, DALOFER17, davidap13, kigua, JOTTA, Senuto, jd_zuri, Alvi, damsolu, Leon pucelano, javi_archi, danihd, alcoleazgz, miguel23and, xarlio, jdieztec, mitxuni, Kisszabo, Gendos22, xexpir, canijo82, Brandenor, cenkkaya, kennit0, Chelazo, bertoco, benitogomez, carlosVACA, Peje, NOECUBI1, AAAJDA, trazas, martija, borjiguez, JoseXS, ferbarroso14, Wespa, Cloud_ganora, Berbe15, Valengti, Chrohu, Atajunen, Victorzabal, jrm82, carlo13, iNFeCTeD, paralaxon, ateopoeta, pepo55, ribasxisco, Raulribarroja, ivanti, lopezm0, Rubén Flp, Warelio, Vagabundo, Rekoba, Octacon, matiaso, Alianma, Raulportela, Éugen91, Rivesgti, Mcm90, DaniR86, Gravilhas75, JuanNur78, el_Asturiano, Mr.Chuflas, albert_naga, juanfrancia, Seket, algabe, pistoleromtb, ebcuatro, [GuErRa], Mario Leon, tito68
Re: Actualización infotainment
Notapor Noltari el 22 Jul 2020, 15:42
jasoriab escribió:@Noltari para que no haya equívocos o brickeos, ¿Puedes poner para que referencia son válidas dichos ficheros?
Por supuesto, la instalación de esa actualización de bajo responsabilidad del quien lo haga, hay que tener claro que te puedes cargar la unidad si no sabes hacerlo, y luego no se venga a pedir responsabilidades al foro.
Ya somos todos mayorcitos...
Acabo de solicitar la edición del post añadiendo las referencias.
Noltari
Notapor jasoriab el 22 Jul 2020, 21:24
Listo, ya está aprobada la edición del mensaje .
Gracias por subir los firmwares, exclusivos para la unidad MIB 2GEN 6,5" HW:024 FW:0245 :ok:
jasoriab
Agradecido: 2019 veces
Notapor Adrian Anton el 23 Jul 2020, 07:44
Hola, he actualizado mi unidad con los archivos proporcionados por Noltari y todo salió bien.
Primero hice la actualización de 252 a 330 y luego de 330 a 346.
Ahora me quedé atascado con el error 1555 y esperando a que un amigo con OBDEleven lo arreglara.
Además, el enlace completo Full Link desapareció del menú.
¿Alguien sabe cómo traerlo de vuelta? :ayuda:
¡Gracias a todos!
Si alguien más tiene esta unidad, puede usar los archivos de Noltari:
Device part number: 5AQ035824
HW: H24
SW: 0252
Adjuntos
Before
Updating
After
Última edición por jasoriab el 23 Jul 2020, 09:02, editado 1 vez en total
Razón: Editado para corregir el término Full Link
Adrian Anton
Notapor cvillajos el 23 Jul 2020, 15:12
Adrian Anton escribió:Hola, he actualizado mi unidad con los archivos proporcionados por Noltari y todo salió bien.
¡Gracias a todos!
HW: H24
SW: 0252
Tienes la solución a ambos problemas en la página 41 del hilo (tanto 1555 como desaparición de menús de FullLink: MirrorLink+Apple CarPlay+Android Auto).
jasoriab (23 Jul 2020, 19:41)
cvillajos
Agradecido: 3575 veces
Notapor Adrian Anton el 24 Jul 2020, 08:55
Sí, un amigo vino con un Obdeleven y logramos solucionar el error y recuperar el menú FullLink.
Gracias a todos por toda la información.
En este mensaje, Adrian Anton ha recibido un agradecimiento de:
jasoriab (24 Jul 2020, 12:54)
Adrian Anton
Notapor Rubén Flp el 30 Jul 2020, 10:36
Hola.
Alguien tiene el MIB 1 DESCARGADO y puede subirlo o pasarlo por privado.
Tengo un Seat León con software 0425 y me gustaría actualizarlo alsoftware 480.
Muchas Gracias
Adjuntos
Rubén Flp
Notapor Djplu el 31 Jul 2020, 07:54
Hola a todos, hay alguien de barcelona o alrededores que sepa hacer esto y me cobre algo por ello ?? Tengo un st del 2014 con pantalla 6,5" y para mi todo esto que comentais es una liada jajaja, gracias y un saludo
Djplu
Notapor juanbb el 31 Jul 2020, 17:33
Djplu escribió:Hola a todos, hay alguien de barcelona o alrededores que sepa hacer esto y me cobre algo por ello ?? Tengo un st del 2014 con pantalla 6,5" y para mi todo esto que comentais es una liada jajaja, gracias y un saludo
Si es de 2014 es la de 5.8 y esa nadie te la querra hacer, se puede quedar frita. Lo suyo es que actualices y po gas una unidsd con full link
Enviado desde mi SM-N960F mediante Tapatalk
En este mensaje, juanbb ha recibido un agradecimiento de:
chaiser (10 Ene 2021, 17:44)
juanbb
Agradecido: 354 veces
Notapor Djplu el 31 Jul 2020, 20:35
Gracias por responder juanbb, es la de 6,5 " eso estoy seguro jaja y juraria q el coche es de 2014, lo volverr a mirar pero la pantalla es 6,5, mirare a ver q modelo de firmware lleva y a ver si encuentro a alguien, un saludo
Djplu
Notapor kuki_cbr el 31 Jul 2020, 20:41
Muy buenas , solo se puede hacer aparecer el icono de full link desde la app de OBDeleven y de la de VAG?? no tengo nada ni nadie que me lo haga, podría alguien de Zaragoza decirme algo o si me lo podría hacer ? tampoco se si twngo el error este famoso que sale "ERROR 1555", alguien que me pueda ayudar? las actualizaciones las he hecho de la 241 a la 330 y de la 330 a la 346.
Gracias por adelantado.
kuki_cbr
Notapor juanbb el 01 Ago 2020, 10:56
kuki_cbr escribió:Muy buenas , solo se puede hacer aparecer el icono de full link desde la app de OBDeleven y de la de VAG?? no tengo nada ni nadie que me lo haga, podría alguien de Zaragoza decirme algo o si me lo podría hacer ? tampoco se si twngo el error este famoso que sale "ERROR 1555", alguien que me pueda ayudar? las actualizaciones las he hecho de la 241 a la 330 y de la 330 a la 346.
Si es necesario vagcom o el obd11.
Mira la lista de la gente que tienen obd/vagcom/ odis por provincia, quizas alla alguno de zaragoza y pueda ayudarte.
viewtopic.php?t=113374
juanbb
Notapor Nano_ el 04 Ago 2020, 11:37
yokin escribió:¿Teniendo estos datos en Info del sistema podría actualizar?
Número de pieza del dispositivo: 5QA035824
Hardware: H24
Software: 0241
Codec de media: 2101.0.0.8
Muchas gracias
Hola yokin,
¿Has podido actualizar? Tengo la misma que tu.
Un saludo y gracias de antemano.
Nano_
Notapor Djplu el 04 Ago 2020, 16:32
Holaa, tengo esta version, sabeis hasta donde puedo actualizar y si me compensa esa actualizacion?? Es decir, que ganaria al actualizar?? Muchas gracias a todos
Adjuntos
Djplu
Notapor aprietatuercas1974 el 04 Ago 2020, 20:55
Djplu escribió:Gracias por responder juanbb, es la de 6,5 " eso estoy seguro jaja y juraria q el coche es de 2014, lo volverr a mirar pero la pantalla es 6,5, mirare a ver q modelo de firmware lleva y a ver si encuentro a alguien, un saludo
te paso privado
aprietatuercas1974
Coche: Leon MK1 2.8 Cupra 4 V6 204cv
Agradecido: 356 veces
Notapor Nano_ el 05 Ago 2020, 08:38
Desde hace algun tiempo se me reinicia solo el sistema, ultimamente demasiado a menudo, antes era una vez al mes y ahora casi diariamente...
LOs datos:
Hardware: H24
Software: 0241
¿Se solventaria este problema actualizando? Es compatible mi sistema con la actualizacion que se explica en la pagina 41? Esq ahi el sw que aparece es el 0245.
Gracias y perdonar...
Nano_
