@Joseibz este finde pensaba cambiar mi botonera, si no te corre prisa pensaba preparar un mini brico de como desmontarlo y cambiar la botonera por una de wv de Aliexpress que vale sobre10€ y cambiar los led de blanco a rojo.
Recopilación de Bricos
- Seguidores: 149
- Favoritos: 50
- Vistas: 196.722
Favoritos: rugargar, neraka, ositoerik, Alexleon11, dmesanun, sebastianbarcala, ROBERTO206, Dthedeep, dani90, centicol, norchugo, erizo-man, migcc, Juun, JOTTA, mimomo, Master21, boreal nit, Myvodoo, Samueleitor, Tomcat7733, ephreon, sbarri, garrafa2, Pedrost, fre_19, Omarballes, Jkirk, little bastard, jotavc, Gus-Gus, tonnety, Juantxu, voxyman, damsolu, nifer, Pepeulo, barrosdepor, daf, toniRG, Jastur, david_97mk3, Nikobellic, josefrc, fistrocupra, Danisisa_cupra, Jonathanstleon, arberto, vipeyays, ClintSanti
Seguidores: coco2612, callonco, ablepm20, AlvaroFR, msmdraven, Hovig, barris31, Anyel01, tokedj1989, Josepo79, Kikote8, Mike28, garruz666, hardcoderpt, davidbj, Platanot, Rasekfighter, kaiman1991, Brunold, ramargo75, the-game-310, Ragnar93, ncx, Per3zo, jmfcoto, KivoMK3, yujakantabro, Kike77, jrm82, inamarlo, Dandy_gsi, trekam, solanomor01, sagatsm, yak54, Jorge75016, JoseCa, csabafr2013, El3ndil, pirly, car212121, josemag, garrafa2, faser, Master21, clavelstreet, khris, juanmaroger, Juun, Aguelo, picard14, carrasco13, Edu1589, Holin, kevin 215, mikyeah69, Montydaka, carlosgzlez, Bettor, aironsam14, dghlb, javinho10, Cantona, leonfr76, Kete32, pables9, edumachuca, LeoST, borgio, DBS83, tecnoyito, Thrasher, Pedrost, MORKAS, kijute, jairin13, osjamil, LuichiFR, Agobo, aguscalderon, jande, Westy, aleeexx, Charlysspain, bailyibz, Gsclosada, genialsoft, utopia95, bronce702, kennit0, Llisus, cuenka16, Tonivn, kawaner13, TITO CORUÑA, Ferrs2, chikiojeda, progchild, Dconnect, cocorolito, jd_zuri, VapaV, barret, bird4, triguero, Guillen222, Niko07, Alvi, victor david, Gus-Gus, dRoXe, djcastle, jdiego75, kaisermig, nitro_g4074, Ignacioign, nifer, barubita, navi_7, joao.albano, joao.albano, Tello19, Rober_SR, MartinLeon, jviela, davidap13, Piro25, consumatica, Abraham Morin, nanomdz19, JDMG, funaghi, Ivanbustelo, SantiPMI, loeches, rubendelcano, rpv, Joseibz, SantiagoSanchez, javier.cuencamotoso, RuJe, Vagabundo, guardiola89, recio2303, AlvaroRamlo, danieleon, profile, Jonathanstleon, vipeyays
Re: Recopilación de Bricos
Aunque ahora con culo(st) desde 2003 enamorado de la fiera de seat
Se agradece dándole al
Pedrost - Aqui + que con la novi@
- Agradecido: 281 veces
Pedrost escribió:@Joseibz este finde pensaba cambiar mi botonera, si no te corre prisa pensaba preparar un mini brico de como desmontarlo y cambiar la botonera por una de wv de Aliexpress que vale sobre10€ y cambiar los led de blanco a rojo.
Ok perfecto. Espero ese brico.... se me ha roto el botón del cristal del conductor y quiero saber por donde le he de meter mano para no liarla mucho....
Joseibz - Nuev@ por aqui
+1 con el problema del pulsador de la ventana del conductor,se ha roto algo y no puedo hacer lo de bajarla con un toque.Pedrost escribió:@Joseibz este finde pensaba cambiar mi botonera, si no te corre prisa pensaba preparar un mini brico de como desmontarlo y cambiar la botonera por una de wv de Aliexpress que vale sobre10€ y cambiar los led de blanco a rojo.
Y prefiero cambiarlo antes de que me deje de funcionar.
La referencia del original la sabéis??
Enviado desde mi Mi 9 Lite mediante Tapatalk
aironsam14 - Asidu@ en la selva
- Agradecido: 24 veces
No sé si llamarlo brico pero si a alguno os viene bien, aquí os lo dejo, saludos!
viewtopic.php?f=40&t=132493
- Agradecido: 409 veces
Agonza86 escribió:No sé si llamarlo brico pero si a alguno os viene bien, aquí os lo dejo, saludos!
Actualizado y añadido al apartado de Iluminación
LeonFR.Gz - Moderador Global
- Agradecido: 1173 veces
Echo en falta el "Reequipamiento del LineAssist" en el listado de BRICOS: viewtopic.php?f=40&t=117487
- Agradecido: 3610 veces
Para los que os fallanlo de subir de un toke, habéis echo el respeto? Osea lo de subir y mantenerlo apretado 10 segundos y bajarlo y seguir apretando otros 10 segundos, normalmente se arregla así, a veces se suelen desconfiguraraironsam14 escribió:+1 con el problema del pulsador de la ventana del conductor,se ha roto algo y no puedo hacer lo de bajarla con un toque.Pedrost escribió:@Joseibz este finde pensaba cambiar mi botonera, si no te corre prisa pensaba preparar un mini brico de como desmontarlo y cambiar la botonera por una de wv de Aliexpress que vale sobre10€ y cambiar los led de blanco a rojo.
Enviado desde mi SM-G975F mediante Tapatalk
javier.cuencamotoso - Nuev@ por aqui
Dejo esto por aquí por si queréis añadirlo al listado, quizás a alguien le interese.
viewtopic.php?p=2139600#p2139600
Saludos!!
Saludos!!
Agonza86 escribió:Dejo esto por aquí por si queréis añadirlo al listado, quizás a alguien le interese.
Saludos!!
Actualizado y añadido al apartado de Varios
Añadido al apartado de Varios el brico de cambio del tapón del depósito de limpiaparabrisas creado por @mgrondona
Busco un mod que vi hace un tiempo y no encuentro. En la guantera va el filtro de aire del habitaculo, pero por la parte del motor creo recordar que los leones llevan una especia de rejilla y punto mientras que los A3, y creo que los golf, lleva otro filtro. Vi que alguien lo hizo y me interesa.
Alguien tiene ese mod localizado?
Gracias.
Gracias.
garruz666 - Leoner@ habitual
- Agradecido: 38 veces
garruz666 escribió:Busco un mod que vi hace un tiempo y no encuentro. En la guantera va el filtro de aire del habitaculo, pero por la parte del motor creo recordar que los leones llevan una especia de rejilla y punto mientras que los A3, y creo que los golf, lleva otro filtro. Vi que alguien lo hizo y me interesa.
Gracias.
Hola, ¿este?
viewtopic.php?f=40&t=134704&p=2139859&hilit=Filtro#p2139859
Hola, a ver si me podéis ayudar
Mi coche es un MK3 mayo 2016 , hace una semana me arrancaron el espejo retrovisor izquierdo y he comprado uno nuevo y parece bastante frágil , no he encontrado un tutorial de cómo montarlo. No he encontrado tutorial en ningún sitio de mi coche, no sé si alguno de vosotros no puede decir como es , probablemente no sea nada más que empujar hasta que hagan clic las patillas pero no doy con la tecla.
Carlosrvp - Nuev@ por aqui
Añadido al apartado de Interior el brico de tomas USB en apoyabrazos para plazas traseras creado por @mabeko
¿Dónde comprar neumáticos baratos y de buena calidad? Foro: General Autor: Olenda12 Respuestas: 0 |
Cambiar junta interna de la puerta Foro: Leon IV - Mecánica / Electricidad / Electrónica Autor: Martinastut Respuestas: 2 |
Presentación/Motor se me paró de repente Foro: Leon I - Mecánica / Electricidad / Electrónica Autor: Hildenbrand95 Respuestas: 3 |
Problema inusual de temperatura motor Foro: Leon II - Mecánica / Electricidad / Electrónica Autor: titular5 Respuestas: 4 |
Usuarios navegando por este Foro: AmazonBot y 14 invitados
