Recopilación de Bricos
Favoritos: rugargar, neraka, ositoerik, Alexleon11, dmesanun, sebastianbarcala, ROBERTO206, Dthedeep, dani90, centicol, norchugo, erizo-man, migcc, Juun, JOTTA, mimomo, Master21, boreal nit, Myvodoo, Samueleitor, Tomcat7733, ephreon, sbarri, garrafa2, Pedrost, fre_19, Omarballes, Jkirk, little bastard, jotavc, Gus-Gus, tonnety, Juantxu, voxyman, damsolu, nifer, Pepeulo, barrosdepor, daf, toniRG, Jastur, david_97mk3, Nikobellic, josefrc, fistrocupra, Danisisa_cupra, Jonathanstleon, arberto, vipeyays, ClintSanti
Seguidores: coco2612, callonco, ablepm20, AlvaroFR, msmdraven, Hovig, barris31, Anyel01, tokedj1989, Josepo79, Kikote8, Mike28, garruz666, hardcoderpt, davidbj, Platanot, Rasekfighter, kaiman1991, Brunold, ramargo75, the-game-310, Ragnar93, ncx, Per3zo, jmfcoto, KivoMK3, yujakantabro, Kike77, jrm82, inamarlo, Dandy_gsi, trekam, solanomor01, sagatsm, yak54, Jorge75016, JoseCa, csabafr2013, El3ndil, pirly, car212121, josemag, garrafa2, faser, Master21, clavelstreet, khris, juanmaroger, Juun, Aguelo, picard14, carrasco13, Edu1589, Holin, kevin 215, mikyeah69, Montydaka, carlosgzlez, Bettor, aironsam14, dghlb, javinho10, Cantona, leonfr76, Kete32, pables9, edumachuca, LeoST, borgio, DBS83, tecnoyito, Thrasher, Pedrost, MORKAS, kijute, jairin13, osjamil, LuichiFR, Agobo, aguscalderon, jande, Westy, aleeexx, Charlysspain, bailyibz, Gsclosada, genialsoft, utopia95, bronce702, kennit0, Llisus, cuenka16, Tonivn, kawaner13, TITO CORUÑA, Ferrs2, chikiojeda, progchild, Dconnect, cocorolito, jd_zuri, VapaV, barret, bird4, triguero, Guillen222, Niko07, Alvi, victor david, Gus-Gus, dRoXe, djcastle, jdiego75, kaisermig, nitro_g4074, Ignacioign, nifer, barubita, navi_7, joao.albano, joao.albano, Tello19, Rober_SR, MartinLeon, jviela, davidap13, Piro25, consumatica, Abraham Morin, nanomdz19, JDMG, funaghi, Ivanbustelo, SantiPMI, loeches, rubendelcano, rpv, Joseibz, SantiagoSanchez, javier.cuencamotoso, RuJe, Vagabundo, guardiola89, recio2303, AlvaroRamlo, danieleon, profile, Jonathanstleon, vipeyays
Re: Recopilación de Bricos
Notapor Pedrost el 28 Feb 2020, 18:05
@Joseibz este finde pensaba cambiar mi botonera, si no te corre prisa pensaba preparar un mini brico de como desmontarlo y cambiar la botonera por una de wv de Aliexpress que vale sobre10€ y cambiar los led de blanco a rojo.
Aunque ahora con culo(st) desde 2003 enamorado de la fiera de seat :enamorado:
Se agradece dándole al :ok:
Pedrost
Agradecido: 281 veces
Notapor Joseibz el 28 Feb 2020, 22:34
Pedrost escribió:@Joseibz este finde pensaba cambiar mi botonera, si no te corre prisa pensaba preparar un mini brico de como desmontarlo y cambiar la botonera por una de wv de Aliexpress que vale sobre10€ y cambiar los led de blanco a rojo.
Ok perfecto. Espero ese brico.... se me ha roto el botón del cristal del conductor y quiero saber por donde le he de meter mano para no liarla mucho....
Joseibz
Coche: Leon MK4 2.0 TDI CR 150cv
Notapor aironsam14 el 01 Mar 2020, 11:38
+1 con el problema del pulsador de la ventana del conductor,se ha roto algo y no puedo hacer lo de bajarla con un toque.
Y prefiero cambiarlo antes de que me deje de funcionar.
La referencia del original la sabéis??
Enviado desde mi Mi 9 Lite mediante Tapatalk
aironsam14
Coche: Leon MK3 1.5 TGI 130cv
Agradecido: 24 veces
Notapor Agonza86 el 02 Mar 2020, 17:04
No sé si llamarlo brico pero si a alguno os viene bien, aquí os lo dejo, saludos!
viewtopic.php?f=40&t=132493
Mi misil: viewtopic.php?f=43&t=112454
Life on the road, V8 POWER :bandit: :bandit: :bandit:
Agonza86
Agradecido: 409 veces
Notapor LeonFR.Gz el 02 Mar 2020, 20:36
Agonza86 escribió:No sé si llamarlo brico pero si a alguno os viene bien, aquí os lo dejo, saludos!
Actualizado y añadido al apartado de Iluminación
LeonFR.Gz
Moderador Global
Agradecido: 1173 veces
Notapor cvillajos el 20 May 2020, 13:21
Echo en falta el "Reequipamiento del LineAssist" en el listado de BRICOS: viewtopic.php?f=40&t=117487
cvillajos
Agradecido: 3610 veces
Notapor javier.cuencamotoso el 13 Jul 2020, 11:12
Para los que os fallanlo de subir de un toke, habéis echo el respeto? Osea lo de subir y mantenerlo apretado 10 segundos y bajarlo y seguir apretando otros 10 segundos, normalmente se arregla así, a veces se suelen desconfigurar
Enviado desde mi SM-G975F mediante Tapatalk
javier.cuencamotoso
Notapor Agonza86 el 17 Dic 2020, 20:40
Dejo esto por aquí por si queréis añadirlo al listado, quizás a alguien le interese.
viewtopic.php?p=2139600#p2139600
Saludos!!
Agonza86
Notapor LeonFR.Gz el 18 Dic 2020, 21:49
Agonza86 escribió:Dejo esto por aquí por si queréis añadirlo al listado, quizás a alguien le interese.
Saludos!!
Actualizado y añadido al apartado de Varios
LeonFR.Gz
Moderador Global
Notapor LeonFR.Gz el 12 Oct 2021, 20:41
Añadido al apartado de Varios el brico de cambio del tapón del depósito de limpiaparabrisas creado por @mgrondona
LeonFR.Gz
Moderador Global
Notapor garruz666 el 24 Feb 2023, 19:55
Busco un mod que vi hace un tiempo y no encuentro. En la guantera va el filtro de aire del habitaculo, pero por la parte del motor creo recordar que los leones llevan una especia de rejilla y punto mientras que los A3, y creo que los golf, lleva otro filtro. Vi que alguien lo hizo y me interesa.
Alguien tiene ese mod localizado?
Gracias.
Leon 2018 FR Line 1.4 125CV Red Desire
---> viewtopic.php?f=43&t=125774 <---
garruz666
Agradecido: 38 veces
Notapor Agonza86 el 28 Feb 2023, 18:18
garruz666 escribió:Busco un mod que vi hace un tiempo y no encuentro. En la guantera va el filtro de aire del habitaculo, pero por la parte del motor creo recordar que los leones llevan una especia de rejilla y punto mientras que los A3, y creo que los golf, lleva otro filtro. Vi que alguien lo hizo y me interesa.
Gracias.
Hola, ¿este?
viewtopic.php?f=40&t=134704&p=2139859&hilit=Filtro#p2139859
Agonza86
Notapor garruz666 el 02 Mar 2023, 19:15
Si, justo.
garruz666
Notapor Carlosrvp el 11 Dic 2023, 21:05
Hola, a ver si me podéis ayudar
Mi coche es un MK3 mayo 2016 , hace una semana me arrancaron el espejo retrovisor izquierdo y he comprado uno nuevo y parece bastante frágil , no he encontrado un tutorial de cómo montarlo. No he encontrado tutorial en ningún sitio de mi coche, no sé si alguno de vosotros no puede decir como es , probablemente no sea nada más que empujar hasta que hagan clic las patillas pero no doy con la tecla.
Carlosrvp
Notapor LeonFR.Gz el 24 Abr 2025, 22:58
Añadido al apartado de Interior el brico de tomas USB en apoyabrazos para plazas traseras creado por @mabeko
LeonFR.Gz
Moderador Global
